WEll after beating Diablo last night (on Normal) I'm not even sure I'll play it on nightmare/inferno.
Not only does it seem that the ENTIRE game was built on forcing players to use the AH, as I never once my entire playtime to lv 33 got a single set/legendary) which in D2 you would have gotten most likely. It makes no sense why they wouldn't have set pieces (for those lower lv's) be able to drop in normal, except if they want people to b eforced to go on the AH.
It seems the entire game was built to shift players from "finding" good loot to having only a few players actually find it while the majority of players (and the majority of diablo players will most likely play normal then be done with it) are forced to use the AH to get decent gear so they aren't underpowered.
I know going into the end of Act 3, it seemed that virtually EVERY yellow that I actually came across was for a lower lv of items. Where the White/blues that dropped were for my lv range usually, all the yellows that droped were for lower lv's. So I hopped onto the AH and bought some of my lv and it made a HUGE difference in both my dmg and survivability.
Also since I finished the game, I have to say Blizzard really fucked up classes. Taking out the ability to build your class and having it be streamlined with skills you can easily switch in/out an daugments, it gives 0 reason to try something new/roll a new character. That was the reason I stuck around in D2 for a year+ after it was out, trying one class build, then trying a different one, it was fun and provided new things.
