seriously? returning 14 freaking panels?
Zepharus, I guess you misunderstood. He didn't exchange the same monitor 14 times. Check earlier in this thread here.
Guys, I have to say something. The quality control of this panel is remarkably inconsistent. I have one out of the 14 I've seen that is brighter and clearer than the rest. The coating is amazingly transparent. The worst I've seen is a lot less vibrant.
Though, with that said, I see that the right side of the screen is brighter than the left. I see this on all of the samples. Could someone please check their panel for me?
Estimated Delivery Date:11/30/2010
I haven't bought from Dell in awhile, I forgot how slow they are. :-/
I was exporting a film for distribution the other day, so I was sanity checking things with this monitor with the SMPTE color bars http://en.wikipedia.org/wiki/SMPTE_color_bars. I flip the monitor to custom color mode, set the gain for R/G/B to 0/0/100 respectively to get blue only, and the center bars and strips all match up with the same blue levels. Then the monitor goes into power saving mode and when it turns back on, the main center two bars' blue levels no longer match the castellation blue levels! If I then switch the monitor to a different preset mode and then back to custom mode, the blue levels then once again match up!
I thought the driver or application must somehow be screwing up, so I tested different applications, all 3 major desktop OSes: (OSX, linux, windows), and even different video cards and interfaces (displayport and dvi). In all cases, the same result - after the display wakes up from energy saving mode, the colors in custom mode are off!
I know what you're thinking, maybe the CCFL tube cooled off, but no, this happens even when energy saving mode is entered just long enough for the power light to flash brown.
Some DDC/CI bug with this monitor?
I've also noticed that custom mode sometimes wacks out completely (for lack of a better term after waking up from power saving mode. In this case the colors seem to somewhat invert. For example if I leave custom mode with RGB levels set to 0/0/100, switch to a different preset mode, let the monitor enter power saving mode and then back on, then switch back to custom mode, I may see all red colors instead of blue. Yet the gain settings for custom mode are still at 0/0/100. When the monitor is in such an inconsistent state the gain controls don't have the expected effect either. In the above case, adjusting red had no visible effect, lowering blue actually reduced the brightness of the red.
Had this confusing problem with my first u3011 as well.
The simplest fix I've found for the custom color mode setting problem is to use:I have to physically disconnect power. Using the "on/off" button on the front does not solve it)
You will of course easily have that problem with any application that is not fully color management aware. (There is a separate thread for wide-gamut applications if you're interested in that, though the thread is a bit cluttered with thread-crap).Clearly there's a problem. I don't use Custom RGB, because I found that the colors were more saturated than in Standard/Adobe RGB modes...what about you??
It's on sale for $1124 hurry~!
http://dealnews.com/Dell-Ultra-Shar...D-Display-for-1-124-free-shipping/404894.html
Help! I checked again, and the serial number indicated on the top right corner of the calibration sheet that came with my U3011 does not fully match the serial number shown on the back of the monitor. The first few letters match, not the rest.
Could anyone check theirs and tell me if they completely match?? Thank you!
Nick
The prefixes don't match, but the last 12 digits do.
So I would not sweat it.
In the "calibration report" the prefix is CN0DYMWD
whereas the s/n on the back of the monitor's prefix is CN-OPH5NY
Interestingly, if you look at the monitor EDID information you get a match on just the last 7 digits, and the prefix is instead just PH5NY
So there you have it, 3 different representations of the serial #.
I still do not get why they removed the CF reader on it.. nearly all pro DSLRs use compactflash. :/
Anyone know about the input lag on this monitor? According to TFTCentral, it's 25ms. How does this compare to the HP ZR30w (which allegedly has low input lag) when it comes to FPS?
I will have mine tomorrow and will be throwing every game I own at it to see if I notice any ghosting or input lag. I will let you know asap.
If I recall correctly the ZR30w has ~10ms input lag, so the U3011 would have 2.5x as much.
10ms is very low for an IPS panel. Would this yield a noticeable advantage in gaming to the average eye?
THANK YOU!!! I ordered as soon as I saw your post. Although, my confirmation letter says December 15th for delivery. Sheesh, do they have a group of oompa loompas making them per order?
ANyway I haven't owned anything but CRT monitors my whole life, so what kinds of things should I look for that might mean replacing the monitor? *(buzzing noise, 1 dead pixel, 3 dead pixels, weird tinged pixels, what exactly should I be concerned about and what's okay to accept and deal with)?
To save costs I bet.
This dude is gonna cum in his pants when he gets his U3011 lol
