Not with mine; the tint is everywhere. Your situation seems less pervasive.The green tint is not uniform and affects only part of the screen.
If you say so, but as I've seen, any difference in tint from left to right is in the noise compared to a deltaE error of 6 (as measured in the latest review) or 10-14 as I've shown. What is your deltaE variance from left to right? I'm guessing no worse than:Well honestly, I've seen more of these panels than most people. And believe me there is a spectrum of different degrees of tinting. I've seen green tint, tan/yellow tint, blue tint. I am literally doing quality control for Dell at this point. The funny thing is Dell forum is the easiest place to inspect this defect because of the left and right gray borders.
http://www.anandtech.com/show/3754/a-new-30-contender-hp-zr30w-review/5
I think it's unreasonable to expect better. I'd be happy if that was the biggest issue I could find with the monitor.
Ya, I'm happy with the uniformity. My issue is with the white balance (color and brightness). The lcd tech may be old, but what's new is the price point, promised factory calibration, bit depth, color space. I'm not seeing a white point that is close to where it should be.Higher-end 30" monitors from NEC and Eizo have settings for enhanced color and brightness uniformity across the panel. They have some electronics which perform compensation. This is one of the biggest advantages of those models. Non-uniformity can be very annoying, and it's a big problem with 30" panels. Even with uniformity compensation enabled, there's a lot of variation between units, with some units achieving better uniformity than others. It's a crapshoot...
I was hoping for a new 30" IPS panel from LG, but all these new 30" monitors are using the same old LM300WQ5 panel which suffers from a lot of issues, unfortunately. Much of that was already discussed in detail on this forum 2-3 years ago. The LM300WQ5 has been around for 3 years now, believe it or not.
I'm also aware that there is much better at a ~$4000 price point. I'm not interested.![]()
Another $1000 or so when I'm not having a problem with uniformity? Hardly clearly a better choice for me. I think your argument is really directed to pedophilekillerThe NEC LCD3090WQXi at $2200 or the (hopefully) soon-to-be-released PA301W are better choices if you care about calibration and accuracy. It's still a crapshoot to some extent, but with better chances of landing a good unit.
I bet the zr30w has a better lamp(s) than what dell is using. Going cheap on the lamp could explain the intermittent buzz, the green tint, and even some uniformity issues. Just guessing.I must have gotten lucky, my 3x ZR30w's look identical to each other.It's also not just the panel. My LG 30" had the LM300WQ5 and had bad green tint. The ZR30w's image quality blow's it out of the water. Maybe it's a much better back light, dunno!
I may be likely to get better whites simply by swapping out my existing unit. Chances seem pretty good in fact since white problems aren't being reported unanimously.You're likely to get better whites and a better color calibration overall with the NEC.
I would get better color calibration with a monitor that uses an SDI interface instead of DVI, but no need for me to spend extra on that either.You're likely to get better whites and a better color calibration overall with the NEC.
Again, I think you are arguing with the wrong person, it is pedophilekiller that has been thru a ton of exchanges.Maybe, but exchanges often become an endlessly frustrating game. Been there many times...
I don't know the spyder calibration software. With argyll, the basic tools are all command line driven so not very user friendly. If you want user friendly (kind of), there's the dispcalGUI front-end to argyll.Hi guys!
Also, I downloaded Argyll and I'm stumped! There is an unzipped directory full of exe's but none of the run?
Review up at TFT Central
Built in Dell sRGB profile, no correction on, brightness 0 contrast 50:
Uncalibrated response:
Black level = 0.23 cd/m^2
White level = 148.43 cd/m^2
Aprox. gamma = 2.14
Contrast ratio = 636:1
White chromaticity coordinates 0.3105, 0.3174
White Correlated Color Temperature = 6737K, DE 2K to locus = 2.6
White Correlated Daylight Temperature = 6743K, DE 2K to locus = 6.7
White Visual Color Temperature = 6849K, DE 2K to locus = 2.5
White Visual Daylight Temperature = 7078K, DE 2K to locus = 6.4
Effective LUT entry depth seems to be 10 bits
Target Brightness = 150.00, Current = 148.38, error = -1.1%
Target 50% Level = 31.92, Current = 33.62, error = 1.1%
Target Near Black = 1.48, Current = 2.59, error = 0.7%
Target white = x 0.3128, y 0.3291, Current = x 0.3101, y 0.3177, error = 7.04 DE
Target black = x 0.3128, y 0.3291, Current = x 0.3052, y 0.3083, error = 10.65 DE
Built in Dell sRGB profile, calibrated for screen viewing/web publishing:
Current calibration response:
Black level = 0.17 cd/m^2
White level = 148.68 cd/m^2
Aprox. gamma = 2.15
Contrast ratio = 856:1
White chromaticity coordinates 0.3096, 0.3167
White Correlated Color Temperature = 6798K, DE 2K to locus = 2.4
White Correlated Daylight Temperature = 6804K, DE 2K to locus = 6.6
White Visual Color Temperature = 6905K, DE 2K to locus = 2.3
White Visual Daylight Temperature = 7139K, DE 2K to locus = 6.3
Target Brightness = 130.00, Current = 132.24, error = 1.7%
Target 50% Level = 28.36, Current = 29.51, error = 0.9%
Target Near Black = 1.32, Current = 1.43, error = 0.1%
Target white = x 0.3128, y 0.3291, Current = x 0.3136, y 0.3295, error = 0.45 DE
Target black = x 0.3128, y 0.3291, Current = x 0.3111, y 0.3194, error = 6.33 DE
Custom Wide Gamut profile, calibrated for inkjet printing.
Black level = 0.24 cd/m^2
White level = 88.00 cd/m^2
Aprox. gamma = 2.15
Contrast ratio = 371:1
White chromaticity coordinates 0.3113, 0.3283
White Correlated Color Temperature = 6587K, DE 2K to locus = 5.0
White Correlated Daylight Temperature = 6586K, DE 2K to locus = 0.6
White Visual Color Temperature = 6400K, DE 2K to locus = 4.8
White Visual Daylight Temperature = 6567K, DE 2K to locus = 0.5
Target Brightness = 90.00, Current = 88.01, error = -2.2%
Target 50% Level = 19.04, Current = 19.76, error = 0.8%
Target Near Black = 0.88, Current = 1.31, error = 0.5%
Target white = x 0.3128, y 0.3291, Current = x 0.3108, y 0.3286, error = 1.29 DE
Target black = x 0.3128, y 0.3291, Current = x 0.2976, y 0.3136, error = 7.42 DE
Command used was basically dispcal -d1 -yl -gs -b 90 -t 6500 -o C:\whereicmfilesgo.icm
This review claims that white brightness is 179 cd^m2 at brightness/contrast settings of 50/50, yet argyll is reporting more like 247 cd^m2 at that setting, as seen by both of my monitors with the same kind of colorimeter. ittech seems to be seeing similar results as I as his brightness is still high but closer to the target 120 cd^m2 when the brightness setting is cranked down to 0.Review up at TFT Central
Are there no drivers for the 3011? Nothing shipped with the monitor on the CD and I can't find anything on the Dell Support site for drivers.
I'm wondering if this is my issue. A client of mine has a 3007wfp and a u3011. Even though they are both set for 1280x800 (the clients choice for large text) when you drag an e-mail from one screen to the other they look VERY different. The 3007wfp looks normal but the same window, just dragged to the u3011 screen looks like the text is bold and slightly blurry. I have no idea why the text looks so different even though the screens are at the same resolution.
The U3011 has a much better scaler (or rather, the 3007WFP barely has one). Showing and scaling text in a greatly reduced resolution is not recommended.
If you let the graphic card handle the scaling on both monitors you will get the same result. Although increasing the text-size / DPI in the OS is a much better solution (although not without some drawbacks) for readability.
I have the 3008WFP and DisplayPort is noticeably slower when changing resolution, switching inputs or even turning on compared to DVI.
Could someone test this on the U3011? That be pretty awesome.
I might be getting a couple 30 inch monitors for eyefinity after the new AMD 6000 series launches, so I'd like to know how fast it is in regards to switching...
Also I'm wondering what program is used to generate the "Calibration Report" chart&graph?
Maybe Argyll is buggy? Another free software you can use to check calibration is HCFR:
http://www.homecinema-fr.com/colorimetre/index_en.php
It doesn't do any calibration, just checks it.
I have HCFR installed and it shows similar results when checking as my NEC Spectraview II software.
Well what do you really want tested?? It takes me ~5 seconds to switch the input source between dvi and displayport with the menu shortcut, and maybe 1 second for the screen to appear...I have the 3008WFP and DisplayPort is noticeably slower when changing resolution, switching inputs or even turning on compared to DVI.
Depends upon the OS, the video card.Thanks - how do I change whether the graphics card is doing the scaling vs. the monitor?
Your uncalibrated deltaE numbers look better than mine for "correlated color" and "visual color" white measurements. Congrats. At least with my replacement monitor, deltaE for white seems within the margin of error in those two modes, and I've calibrated custom mode to be within bounds.I don't think I'm doing anything wrong, but I could be, since I've never used argyll before. Seems to look better and be more accurate than the colormunki software though so far... will have to play around a bit more before i try and make inkjet calibrations with it...
