Obviously the same as with any more advanced display, a more complex signal processing chain.
That's the marketing answer, not the detailed technical answer.
It does not have 25ms of input lag, pretty much all of TFT Central's input lag #'s are way off.
How would you test it properly? Best test I've seen is to connect two monitors (one CRT the other the monitor you want to test) to the same type of output on the same card then run a full screen stopwatch on both at the same time.
CRTs max out at 2048x1536. All of the tests are questionable due to being run at non native resolution for any IPS panel higher than 1200P.
This. The input lag numbers at TFT are a joke because they do their testing at non native resolution - non native resolution always adds significant input lag.
I understand WHY they do it (to use a CRT as baseline), but it is not accurate. I don't know how they can fix this, or if they ever will since they're using a CRT as baseline, but always take 2560 IPS panel input lag adjustments with a grain of salt. User experiences are much more useful in this respect. The 2713HM is obviously not as responsive as a CRT but the input lag isn't an issue for gaming or movie watching - as a sidenote, when I attempt running a non native resolution for fast action games I can actually see ghosting during gameplay. That isn't the case at the proper resolution.
Talk about making mountains out of mole hills... let's go through these point by point (and since I own one).
I literally stuck my ear to the back and couldn't hear a thing. I do have low fan noise emanating from my computer nearby. Under normal environmental conditions it doesn't seem to be an issue. Simon even says as much in his review.
Luminance over the screen may vary by up to 20%, but if you take a look, it's pretty uniform in its non-uniformity, with the uniformity actually being a gradient, extending outward in rings. I'll take this over other monitors whose luminance uniformity is in pits and spikes all over the screen. That said, what really matters is white-point uniformity, and the U2713H's is pretty darn excellent.
This is an IPS, not a PLS panel, nor any other kind of panel. We've known this for how many years? And against what- the U2713HM? There's only a fraction difference. It's quite a bit better than its actual predecessor, the U2711.
Input lag is 25ms, with the HM being 22ms. A 3ms difference is not really something to write home about. The U2711 was in the 30ms range, so it's a nice decrease in lag when compared to that.
can't vouch for other colorimeters, but the panel the U2713H uses is GB-LED. This isn't your standard LED implementation, nor is it the same as WCG-CCFL. Sometimes new tech requires newer tech.
Sorry, but sometimes overblown FUD needs to be squashed...
Dude, calm down. I am merely summarizing someone ELSE'S review. And no one is making mountains out of mole hills.
And what about using a 1:1 scaling mode?
There is no 1:1 scaling. All non native resolutions are pixel multiplied and blurred to fit full screen.
This was slightly slower overall than the U2713HM (also tested using the same SMTT method). Prad.de have also tested the U2713HM with their oscilloscope based method and identified a signal processing lag of 15.5ms and a further 7.1ms of response time accounted for to give them an overall display lag of 22.6ms. We can probably assume that the U2713H has a very similar signal processing lag (~15.5ms) which is probably related to the internal scaler. The slightly higher overall display lag is probably down to the slightly slower response times we've experienced on the U2713H as compared with the U2713HM.
Pretty sure he added the bit about PRAD's review after the review was originally published.
Nein, the 22ms value was obtained via sheer randomness.
It doesn't make since that his methods would be accurate for the U2713HM when most of the other values are way off.
The U2713H has a 1:1 mode :S
Except, their review had a positive conclusion. You really sounded like were you trying to make a mountain of a molehill, to be honest. I'm not really sure where you got some of those data points.
You obviously didn't read the review's conclusion, either that or you work for Dell. You also obviously didn't read my post. Try again, this time look under the pro's column. How you came to the conclusion my post was negative and making mountains out of molehills is beyond me. TFT Central's conclusion was rather mixed, as was my summary. Simon thinks the U2713H is a worthy successor to the U2711 overall. So in that sense it is generally positive, as most of his reviews are.
Actually I share his sentiment, your post DID sound negative - pros and cons by themselves, without a full review or at least the conclusions always sound blown out of proportion.
It only sounds negative or blown out of proportion to those expecting a particular conclusion, or to those who have an emotional investment in how the product is perceived.
My summary listed 7 positives and 5 negatives. Yet your mind still managed to spin something negative out of it. Fascinating.
Sorry, but your criticisms of my post might have been better aimed at TFT Central. You've done nothing more than shoot the messenger. And your hysterical claims about my "FUD" is pretty silly.
Simon said:This buzzing noise is a minor issue and quite hard to actually produce. You're unlikely to hear it during normal uses so don't let it put you off.
I understand that you are a man without any ability to make sense of context and its finer implications but hey, don't be angry at us, it's just you...
No, I know exactly what Simon at TFT said in his review, since I read it, and your overblown bullet points don't summarize either Simon's review, nor the monitor, fairly because context and comparison are absent. I'll just point to the so-called buzzing issue. No where does Simon call it a con. There's one brief paragraph about it tucked away, in which he wraps it up with the following:
Yea, what an issue. In fact, he was so concerned about it, it didn't even make the cons list at the end, nor even the conclusion summary preceding that. But it did manage to make your con list. I'm curious, do you own one?
Funny how you called me a Mac Zealot. Mac Zealots nitpick and obsess over small imperfections. Everyone who uses IPS these days knows what to expect when going in... luminance uniformity and latency among them.
"Dim your monitor or put it into sleep mode with Dynamic dimming" (at bottom of Dell's product page)...?1)The color seems to change from light to dark, dark to light
2)One timei saw one window through another window like its a little transparent, then it goes away
3)One time i closed the window and it left like an imprint on my desktop where it was for a second (it just changed the color of my background where it was)
its really goofy, and I do not know how to explain it
