Frame less, screen door affect doesn't make sense on a glossy. Do you only notice it on text?
VA type panels have different pixel structure than TN and most newer IPS screens. The screen door effect Frameless describes is likely a by-product of that.
Yeah, MVA is a lot better than TN (I don't know what this one uses either). I think S-IPS is better than MVA/PVA but I also think the "screen door" effect is a little more pronounced with S-IPS and some people are bothered by that.
Frameless, can you say if there is an option to change overdrive settings?
But he is talking about an observation on the S2340L which is an IPS monitor.
someone on another forum.
http://forums.macresource.com/read.php?1,725729
interesting. the 24" mva might be better.
freestone
@ freestone
Did Amazon send you email with an eta on monitor?
But anti-glare should help somewhat, corrent? Ever since I heard and saw the heavy AG of many highend IPS panels while VA panels that did not have it, I did suspect that there must be more to this than just that they want to reduce glare. Although, the screen-door effect doesent necessarily have everything to do with subpixel gap either. It could be some other property like diffraction or whatnot.Some older H-IPS have a slight offset between Red/Green/Blue sub-pixels so this can be seen regardless of anti-glare.
Amazon says the S2440L will be arriving November 7th according to my order status.
Some reviews confirming no PWM on the 24 inch model:
http://pcmonitors.info/reviews/dell-s2440l
http://www.tftcentral.co.uk/reviews/dell_s2440l.htm
I am sure one of the users here did some testing on the 27 inch version and confirmed no PWM. Above sites are also reviewing this model soon.
I think that's just a macro shot. I usually get the same on my Apple Cinema Display when I take macros so don't think it was visible. Might be worth emailing the reviewers to see what they say.
I wonder how the overshoot of the IPS compares to the S2440L.That was me
http://www.youtube.com/watch?v=2k9roCiFc4g
http://wecravegamestoo.com/forums/g...740l-review-1920x1080-edge-ege-glass-ips.html (not finished one section)
I used a fixed shutter speed (1/125) and played with the brightness settings and never saw any flicker. TFT Central will confirm if I was right next week when his S2740L review goes up.
The overshoot with mouse movement would scare me a bit. Did BenQ owners with a similar (or same) panel have the same problem? I'm just wondering if the overdrive issue is Dell's fault, or the panel manufacturer.
I don't mind mild ghosting, since I'm not a big gamer anyway. But if I see ghosting/overshoot/etc from just doing normal things, like moving the mouse around, it'd bother me.
