- Feb 2, 2005
I've been playing for a few hours now. Resolution is 1920x1200, and I'm using V-Sync. Though there is a tiny bit of lag, it's not bad at all. It's set to 60fps in the config file on my system. I don't know where people are getting the 30fps thing unless it auto-detects based on your system or something like that. It's smooth as silk with everything maxed.
Are you playing on a CRT by chance? FPS are definitely locked at 30FPS on my setup with Vsync enabled, even with tripple buffering enabled.
