DAN A4-SFX: The smallest gaming case in the world
Discussion in 'Small Form Factor Systems' started by dondan, Dec 30, 2013.
  1. MintCondition
    MintCondition n00b
    8
    Mar 14, 2016
    Hi. Quick question :
    Why is the internal dust filters shorter than the external ones ?
    My guess is that you can't fit a dust filter between the side panel and the power supply (because it's pretty much flat) ? That's a real bummer if it is...
    Meccabolix likes this.
  2. Diverge
    Diverge Gawd
    536
    Nov 22, 2005
    I had to give up one ram slot to use the 120mm fan. So bought a normal size (physical) 16GB stick to put on the outside slot.
  3. Calysto
    Calysto n00b
    39
    Jan 17, 2017
    Can you provide the link to that?
  4. SideSwiped
    SideSwiped n00b
    46
    Jan 14, 2017
    Are there any pictures of the internal ones installed?
  5. Blackreplica
    Blackreplica Limp Gawd
    205
    May 9, 2016
    Dear fellow singaporeans, the Dan A4 has landed here and is being processed for delivery (finally!!)
  6. Jirbin
    Jirbin n00b
    54
    Sep 22, 2016
    im not singaporean but im staying in singapore, and yeah! WUHOO and it is With Delivery Courier. what cooler are you planning to use? i have managed to get a l9i for 30s$ via carousell XD
  7. JackGLemmon
    JackGLemmon n00b
    30
    Dec 8, 2016
    Fantastic news! (Pictures please)
    What motherboard are you using? I have the Asus Maximus Impact VIiI. Am am using the C7 cooler now, as I need to cut 5 mm off the top of the (excessively-huge) VRM heatsink to get the Nexus Low 7000 R2 to fit. Now I am concerned about the mounting hardware.
    Could four plastic washers be used? I do not have a backplate from a NH-C12P to use. I have the washers from the Cryorig C7. That cooler is loud AF, but it cools well. My guess is the good C7 performance is due to pulling a lot of air from outside the case.
    Could you let us Nexus Low 7000 users know what Home Depot calls the right-sized M3 bolts?
  8. Blackreplica
    205
    May 9, 2016
    Someone at home has already collected the case on my behalf. Im in Japan now and only back tomorrow :( man what shitty timing
    I'm running a delidded 7700K with a Cyrorig C7 heatsink combined with the fan from the L9i...it works great in testing. I have the 7700K overclocked to 4.8GHZ stable running Intel's extreme utility test overnight and its hovering from 70-73degrees. Hopefully the temps dont go up much once it all goes into the case
    Now its another waiting game for a good AIB 1080Ti to be released
  9. okwchin
    okwchin Limp Gawd
    357
    Aug 29, 2013
    Perth, Australia has arrived. I will be setting mine up with the stock cooler on a i5 4750 and an Asus H97I Plus, with stock everything as far as I am aware. Temps with the stock cooler are pretty respectable on the bench (around 60 deg, ambient 25 while playing BF1), but its in the case that matters and I am expecting it to get much warmer. GPU wise, its a 1070 EVGA SC.
    I also have a LP53 and the A9-14 that will eventually go in, but certainly not right away.
    I think someone earlier was asking about stock temps and noise, so I will keep an eye out for this. Im normally very sensitive to noise, so lets see how well the stock cooler works.
    On the desk, I find my 1070 EVGA to be Overall ok, but most of the noise is due to the fan bearings being ball bearing type! At load, air noise and bearing noise is present, but at lower loads, its the bearings are the loudest part of the whole system, producing a fairly indistinct hissing sound that is more audible than the stock cpu cooler. Lets see what its like in the case that I will be setting up tonight :)
  10. Jirbin
    Jirbin n00b
    54
    Sep 22, 2016
    haha, but still, when you get back it is there. hmm have you tried using the l9i heatsink and fan? mine is getting hot at 82c peak while playing csgo. :/ would you really recommend using the c7 heatsink?
    update: mine was delivered just a moment ago at my house, but i am still here in my office, cant wait to go home ;)
  11. Blackreplica
    205
    May 9, 2016
    Based on what I've seen in this thread, the C7 heatsink may drop temps a few degrees but it wont change much..i assume you are also using a 7700K? If so, I think as far as managing just gaming loads..not cinebench or prime95 loops..you might do ok but you'd be pushing it. The only way to improve things is to go with more exotic cooling options (like that LP53 + A9 fan combo maybe?) or delid the processor
    Okwchin> i can say for sure the a9x14 fan is really quiet and has a very unoffensive sound signature even running at full speed so you should love it
  12. Jirbin
    Jirbin n00b
    54
    Sep 22, 2016
    im using i7-7700 non k :/
  13. Theelichtje
    Theelichtje n00b
    28
    Jan 10, 2017
    Can confirm, mine clicks aswell :)
    Also, does anyones case act as a heatsink for the GPU? The rear GPU IO and the rear portion of the sidepanel get really hot, does anyone else notice the same?
  14. Theelichtje
    Theelichtje n00b
    28
    Jan 10, 2017
    I do, not sure on temps, only checked them for a brief period.
    As for the noise, i can't hear the CPU fan over the inaudible sf450, i can only hear my GPU fan.
    I5-4440 stock btw, placeholder until its clear what the R5 series can deliver.
    jjsyht and JackGLemmon like this.
  15. HoodedHusky
    HoodedHusky n00b
    42
    Mar 21, 2016
    Yes, which is why many (myself included), run without no rear IO panel.
  16. Blackreplica
    205
    May 9, 2016
    Oh in that case you'll be fine. Noctua themselves say the L9i has no problem handling the 65W TDP 7700
  17. Jann5s
    Jann5s [H]Lite
    98
    Jul 5, 2016
    Be careful that when using only a single slot you are running the memory in single-channel mode instead of dual-channel. Consequently, the memory bandwidth will be lower. From my experience this is not very critical when gaming, but this may change in the future.
    See also this
    mcheddadi likes this.
  18. cowsgomoo2
    cowsgomoo2 Limp Gawd
    144
    Jan 8, 2016
    Someone in this thread recommended the Tenba DYOB 13 camera bag for the case.
    I want to report that it's a very tight fit with no inches to spare.
    [​IMG]
    [​IMG]
    al007, JackGLemmon, jjsyht and 9 others like this.
  19. Horrocko
    Horrocko n00b
    29
    Jan 28, 2017
    Man, that looks really snug! So would you need a separate bag to transport peripherals or can you still fit a slim wireless keyboard/mouse combo in there somehow?
  20. cowsgomoo2
    144
    Jan 8, 2016
    Most likely you need another bag. Or just stuff the camera bag and the peripherals into a bigger backpack.
  21. mcheddadi
    mcheddadi Limp Gawd
    239
    Aug 24, 2015
    when I ordered the full copper axp-100, they forgot to include two ty-100 fans so they sent another package with lots of freebies! :D
    [​IMG]
    loafidelity, MrLahn, Ca11idus and 5 others like this.
  22. Jirbin
    Jirbin n00b
    54
    Sep 22, 2016
    http://imgur.com/a/Qesf1
    i managed to put NF-A4x10 on top of the board as exhaust, havent really tested yet if it helps with the temperature but i can noticeably feel the hot air blowing out, which i think is better than nothing. =)
    Julio Espinosa and Jspr like this.
  23. Hotshot619
    Hotshot619 n00b
    35
    Oct 2, 2016
    That's lucky, any chance you don't need that second TY-100? I'm searching for a 100mm pwm fan with no luck other than buying the AXP-100 and using the TY.
  24. Diverge
    Diverge Gawd
    536
    Nov 22, 2005
    These are all the pictures I have for now. I'll try to take more if/when I delid my cpu. https://goo.gl/photos/RkQLiX9XxbLHA3NMA
    Home Depot has very little selection for M3 bolts. You'll find them in the pull out drawers on the screw/bolt/nut isle. IMO, you're gonna want to use a backplate, unless you don't mind your motherboard being bent.... which could be very bad. Unless you come up with another way of mounting it. You just need to be creative. It's not too difficult to come up with ideas once you play around with the parts. The specs of my parts are in my sig.
    I'm not too concerned about memory speeds or single vs dual channel. IMO, all that has minimal effect on everyday PC use (gaming, browsing, MS Office, etc).
  25. phoxx
    phoxx n00b
    36
    Jun 6, 2016
    Where do you live, and how long was the shipping to you?
  26. illram
    illram [H]ard|Gawd
    1,447
    Sep 19, 2011
    I was thinking of doing the same. How noisy is that little thing?
    mcheddadi are those Gears of War pajamas?? :D Amazing.
    repentsinner likes this.
  27. Jann5s
    Jann5s [H]Lite
    98
    Jul 5, 2016
    Cool, just wanted to make sure that you (and anybody reading) was informed.
    Your post triggered some renewed interest on my part and I researched it again. My findings confirm your opinion, only in memory intensive cases (e.g. zip, x264) you will find a moderate improvement (~5%) using dual-channel DDR (~20% for quad-channel). I can't seem to find if dual-channel memory actually allows two cpu's to interact with the memory simultaneously, and thus reducing latency. Cores typically have their own MMU's (probably these only operate on the cache), but I don't know how these are connected to the memory controller. Anyway, the benchmarks show that it doesn't really matter.
  28. absolut_zero
    absolut_zero [H]Lite
    77
    Sep 2, 2014
    You can email Thermalright if you want to buy the TY-100 fan alone.
  29. Jspr
    Jspr Limp Gawd
    163
    Mar 28, 2016
    That is looking really nice! I am looking for something similar, though maybe cheaper, as I will "just" use it was a sleeve during transportation in my backback.
    How about noise? :)
    And to those who mount a9x14 on the LP-53:
    HOW THE **** AM I SUPPOSED TO DO THIS?! :mad:
    I've used maybe 2½ hours fiddling with this, and the best I could do was rubberbands which 1: looks like rubbish 2: interfere with the fans airflow.
  30. Jonas Mellkvist
    Jonas Mellkvist Limp Gawd
    159
    Dec 18, 2016
    I think Akassa 80 mm fan slim should fit in the roof to.
    http://www.akasa.com.tw/search.php?seed=AK-FN076
  31. HoodedHusky
    HoodedHusky n00b
    42
    Mar 21, 2016
    I used the TY100 100mm fan above PSU + lowered PSU. Fits also fine.
  32. wanako
    wanako n00b
    3
    Nov 12, 2015
    Just got my A4 in the mail today! Los Angeles area is getting them now.
  33. mcheddadi
    mcheddadi Limp Gawd
    239
    Aug 24, 2015
    yep email them, and you can ask for the black and white, black and red or brown and green
    6 days, each time, from taiwan to montreal
    oh yeah! cole train baby!
  34. Jonas Mellkvist
    159
    Dec 18, 2016
    How did you get down the Psu ??
  35. drklu
    drklu 2[H]4U
    2,174
    Jul 15, 2013
    Case just arrived today, looks fantastic! amazing job Dan !
  36. MostComfortable
    MostComfortable Limp Gawd
    426
    Jan 27, 2013
    My case just arrived in SoCal. Looks great, can't wait to start my build this week, thank you Dan!
  37. phoxx
    phoxx n00b
    36
    Jun 6, 2016
    Did your tracking info every get updated?
  38. JackGLemmon
    JackGLemmon n00b
    30
    Dec 8, 2016
    The Lowepro Event Messenger 250 is also a tight AF fit. It is like they made the offical messurments before they added the padding. The A4-SFX does fit the bag, but it takes a little push. It has an exterior pocket that is enough for everything but a keyboard. The internal 13" laptop/tablet pocket can NOT be used, due to the pressure.
    https://smile.amazon.com/Lowepro-Event-Messenger-Camera-Shoulder/dp/B0077B403S/
    Most non-gaming wireless keyboards do not have multi-key rollover of any kind. You cannot run, strafe, slide, and reload at the same time.
    Now that the "tower" is so small the peripherals are taking up all the space. A mechanical keyboard, over-the-ear headphones, and necessary cables take up as much volume. I hope someone comes out with a folding 27 inch 144 Hz monitor soon.
    javidan, jjsyht and MintCondition like this.
  39. Horrocko
    Horrocko n00b
    29
    Jan 28, 2017
    Thanks for the tip!
    I'm actually looking for something super basic in terms of peripherals on this occasion; planning to use the case as a mobile VR machine. When in use at my desk, I have a full setup right there.
    darksable likes this.
  40. Jspr
    Jspr Limp Gawd
    163
    Mar 28, 2016
    A little about ram compatibility:
    Corsair dominator platinum fits without the top bar without a problem. I was afraid I had to mod them, but it wasn't needed.
    RemoteDoc and MintCondition like this.
