Nice! we'll be able to see if bending the heatpipes has a negative effect or not. great stuff man! all that copper must have been long to cut!
The Lowepro Event Messenger 250 is also a tight AF fit. It is like they made the offical messurments before they added the padding. The A4-SFX does fit the bag, but it takes a little push. It has an exterior pocket that is enough for everything but a keyboard. The internal 13" laptop/tablet pocket can NOT be used, due to the pressure.
My full copper Axp-100 came in and I went a different route with modifying it. I cut off the blades hanging underneath (using a hacksaw with a 32T blade...) instead of bending the heatpipes. I'm still waiting for my case and parts to come in but I'll let everyone know how the temps are once I get it all together. I've also got a LP53 on the way too, so I'll be interested to compare them both using the A9x14 Fan.
http://imgur.com/gallery/YSe15
I'm thinking of cutting off the interior pouch for a tablet, it would then fit without a push. Still need to wait for the case to come though.
I've actually been downsizing my peripherals, or at least getting portable versions of peripherals. My results:Now that the "tower" is so small the peripherals are taking up all the space. A mechanical keyboard, over-the-ear headphones, and necessary cables take up as much volume. I hope someone comes out with a folding 27 inch 144 Hz monitor soon.
Where was yours shipped too? Trying to find out how long til my gets here in SoCal
Like thisHow did you get down the Psu ??
or thisYeah, I guessed it was for vertical stability. If it doesn't have any other purpose could it instead go down, along the side of the PSU?
Reason I'm asking is, I looked at the free space (at least 3cm since a SFX-L fits there) there is when using a SFX PSU and thought how to take advantage of that. One of the biggest drawbacks for this case is that there is no active exhaust which makes the case and components pretty hot - seen by the temp difference when not using the I/O panel.
I figured that there is enough room for a 92mm top fan if you lower the PSU with spacers/extending bracket, that attaches to the stock bracket, to make room for the powercable and airflow. It would also pull air from the GPU side. Below is a quick sketch of it:
Something for A4-SFX v2?
More great pictures by loafidelity.
The PSU bracket is a separate removable piece, right? So I wouldn't even have to do it this way:
I could just lower the whole bracket by drilling new screw holes 3cm lower on the front side and putting spacers to the mb side screws. Or would there be something blocking moving it down 3cm? Is there someone who could test out the temp difference? even just adding a fan outside the case on the top and temporarily lowering the PSU for better airflow?
Dan, could these extra holes be added to v2 and the top of the inner frame made 92mm fan friendly? I wager a lot of people would be interested in adding an active exhaust to the case.
Unfortunately, just measuring based on this pic http://i.imgur.com/9qw1acX.jpg a 92mm fan wouldn't be completely flat against the top panel since the bottom right corner would be against the inner frame.
But we can't see they pictures without signing up for the forum..I cutted the blades of my Thermalright AXP 100 Muscle some weeks ago, as you can see here: https://www.hardwareluxx.de/communi...ehaeuse-der-welt-990144-162.html#post25325774 The cooling performance was very disapointing. Let's hope the copper version is doing better.
Looks like the new Asus strix won't fit. The thickness is 5.25cm
https://i.redd.it/hs72qbn86dly.png
Mine actually arrived in 3 or 4 days after I placed the order to Vancouver, Canada. It seemed fairly quick.
Did your tracking update at all? or was it just delivered?
Has anyone in the US not had any updates to their tracking since feb 27? This is all I see
I called USPS and they said they haven't received it yet from Deutsche Post. Anyone else hearing the same thing?
I contacted Dan but he said shipping takes 2-3 weeks. It has now been 3 weeks and it isn't even out of Germany.
This is shipping to Michigan if that matters at all.
Oh wow - quite a job! It looks really nice - sad that it doesn't perform well. Thanks you for posting the pictures!
Bay Area here - my case arrived yesterday with no updates from beyond the "origin post is preparing" message. I just checked it today, and it still doesn't even say it was ever delivered.I'm in the same boat. (San Francisco.) I bet you the USPS person you talked to just told you that based on looking at the tracking that you are looking at, though. As we have seen from people here, it appears the tracking for these packages is not updated for some reason.
He said 7700 not 7700K.Have you tried undervolting?
Hey, has anyone tried to fit the Thermalright AXP100H in the case ? The height without a fan in the top is 51mm, so maybe it will fit with 4mm motherboard standoffs ?
I really hope it fits, because it's a slightly better version than the regular AXP100, and looks like it doesn't require any modding to fit a fan below.
Thermals and noise test with the Thermalright AXP-100H MUSCLE with its TY-100 fan on a 6700k @ 4.4Ghz:
Idle temps:
Prime 95 temps:
Idle speed: 810 RPM
Full speed: 2500 RPM
Temps are about as good at the C7 with the C7 fan, but not quite as good as the C7 with the TY-100 fan.
But in low usage its SILENT! and at max fan speed its pretty quiet, its got the lowest pitch of any of the other combinations i've tested (probably due to the fan being so far behind the side cover and underneath the heatsink), so it's much easier on the ears.
The axp-100H is ever so slightly too tall (as others have pointed out) with the normal standoffs, i have ordered a number of different length standoffs to see what the ideal standoff length I need is (as people have also suggested) . The side panel very nearly fits on with all 4 clips as it is.
I am sticking with this combo for now as it's quieter than the rest, i ordered a nexus last week but it may take a while to arrive, i will test it with the TY-100 and the other fans if people want me to, I am also waiting on the LP53 + NF a9x14 which should come soon.
http://imgur.com/a/Qesf1
i managed to put NF-A4x10 on top of the board as exhaust, havent really tested yet if it helps with the temperature but i can noticeably feel the hot air blowing out, which i think is better than nothing. =)
Just got my A4 in the mail today! Los Angeles area is getting them now.
Build commencing this weekend. It should be interesting as I've gone:
7700k
Cryorig c7
4mm standoffs
z270i Strix
1080 Strix
M2 600p 256 boot drive
M2 600p 512 secondary
The question I have is I was thinking of putting the smaller boot drive on the back of the mobo and then the larger drive on the front with the heatsink. Reasoning behind this is that I'll mostly be stressing the larger drive when gaming, but am not sure it really matters. Any opinions would be great!
I'm jealous but WTF that is messed up. I'm in the mid west and my tracking hasn't updated since German custom's notified USPS. I figured the delivery would have been chronological from east coast to west coast. It's mid March now. I'm growing unhappy about the time it's taking to get this in my hands.
What drives are you going with?I plan on doing the same thing for the same reasoning. Albeit with different drives. I don't think there will be any issues.
