Itchy_Lettuces
- Mar 11, 2017
WD Black 256GB on the backWhat drives are you going with?
Samsung 960 Evo 1TB on the front
Im in Kansas, I got my case early last week.
I transplanted my 5820K X99 ITX system into the Dan A4 yesterday and a AXP100H Muscle cooler didn't fit, even with 4mm standoffs. It's a few millimeters too tall and when I bent the heatpipes to make it shorter, the blades of the underslung fan started rubbing on the retention screws. This is with Thermalright's Narrow ILM kit, which requires standoffs that raises the height of the cooler. As seen in this thread, Meccabolix didn't have the same issues with a LGA 1151 system.
I did a quick and dirty, 10 minute Intel XTU benchmark of the AXP100H with the side panel off with a Noctua NF-A9x14, a Scythe Slipstream SY1212SL12H, and Thermalright TY 100, all blowing out. The Noctua was the quietest but hottest, topping out at 80C, the Scythe was louder but livable and hit 75C, while the Thermalright was a bit quieter than the Scythe and cooled best with 71C. Maybe a draw-through orientation of the fans would have worked better, but I stopped testing after confirming the cooler was too tall.
I switched back to the Dynatron T318, paired it with the TY100 fan, and after 10 minutes of XTU it only reached 65C. So it's a clear winner temperature-wise and it fits. The TY100 fan is a gem too - I can barely tell that the computer is on at idle and it's easily masked by speakers or headphones during load.
EDIT: Added more details to make it clear this is an X99 system and as Meccabolix shows, it fits with LGA1151 motherboards.
what app did you use for stress test?He said 7700 not 7700K.
I have a 7700 (non-K) in my case with an L9i and while running stress tests the temp goes between 77-89ish Celsius. I think the fluctuation is due to my fan curve.
double sided adhessiveHow did you get the fan to stay up there and what is the noise like with it?
okay, i decided to get the cryorig c7 heatsink and replace the fan with noctua's. but how do i attach the noctua fan on the cryorigs heatsink? ziptie?
Ozymandias, I've been doing some benchamrking with the t318 and 5820k and I've determined that with the fan turned upsidedown in "PULL" configuration temperature lowers by 5º/9º. Have you tried?
I'm jealous but WTF that is messed up. I'm in the mid west and my tracking hasn't updated since German custom's notified USPS. I figured the delivery would have been chronological from east coast to west coast. It's mid March now. I'm growing unhappy about the time it's taking to get this in my hands.
thanks for this! so i guess zipties would do the job.There are a few ways but this is how i did it
Couldn't install the Cryorig C7 using the backplate as it seems to be incompatible with the Asus Strix Z270I. Luckily they included washers.... but my temperatures seem to be pretty bad (?) sitting in the low-mid 40's on idle and under stress testing it throttles pretty much straight away (Intel 7700K at stock clocks). What have other people experienced with the 7700k? I might try reapplication of the thermal paste tomorrow but so far pretty disappointed with the noise and temps from the cooler.
Other thing I noticed was the bottom of the heatsink pushes up against the RAM module, installation is super tight, pretty much had to jam it in there.
Well i finally bought and put together my system this afternoon.
Specs:
Intel 7700K (stock) w/ Cryorig C7
Asus Strix Z270I
Gigabyte 1080Ti FE
GSkill Trident Z RGB 16GB 3200
Samsung 960 EVO 500GB m.2
Corsair SF600
In both scenarios. I've tried with three different fans but not with ty100 because I haven´t received it yet. Two of them were 25mm fans and one was 20mm so I have tried the closed configuration only with the third. It gets so close to the case that it forces the air to go directly out through the holes, I don´t know if the ty100 would be the same as it is thinner and the air may get stuck inside the case. All in all, the pull configuraton was always better even in closed config with the fans that I've tried.I haven't tried that. Just to be clear, is that with the heatsink in the case or open air? I know a lot of people are still waiting for their A4...
Specs:
Asus Strix Z270I
Gigabyte 1080Ti FE
Corsair SF600
View attachment 19335 View attachment 19336 View attachment 19334
Mine weighs 322 gHas anyone weighed the LP53 heatsink without fans, and has anyone compared the performance of the LP53 and the Cryorig C7 with the same components?
When you are done with your test, can you give tell us which fan works best with T318?In both scenarios. I've tried with three different fans but not with ty100 because I haven´t received it yet. Two of them were 25mm fans and one was 20mm so I have tried the closed configuration only with the third. It gets so close to the case that it forces the air to go directly out through the holes, I don´t know if the ty100 would be the same as it is thinner and the air may get stuck inside the case. All in all, the pull configuraton was always better even in closed config with the fans that I've tried.
I'm also waiting for thermal grizzly conductonaut liquid metal paste to try and post my results.
OK so this post is going to be a long but very interesting one.
All tests are done on my 6700K @ 4.4Ghz with the LP53 and Noctua NF a-9x14 PWM fan
i unplugged the titan x pascal because sometimes it makes a little rumble when idle, and the NF a9x14 PWM is so quiet you can slightly hear the graphics card in the background, we don't want to hear that, we just want to hear the CPU fan.
i applied fresh thermal paste when i changed orientation of the cooler, the thermal paste i use is Thermal Grizzly Kryonaut.
The first test i did was with the LP53 heatpipes in a horizontal orientation. i used the 4mm standoffs and the a9x14 fan:
Idle temps:
Prime 95 temps:
Next test was the LP53 heatpipes in a horizontal orientation. i used the 7mm standoffs (the original ones) and the a9x14 fan:
Idle temps:
Prime 95 temps:
Next test was the LP53 heatpipes in a vertical orientation. i used the 4mm standoffs and the a9x14 fan:
Idle temps:
Prime 95 temps:
Next test was the LP53 heatpipes in a vertical orientation. i used the 7mm (the original ones) standoffs and the a9x14 fan:
Idle temps:
Prime 95 Temps:
All fan speeds og the above tests were:
Idle speed: 800 RPM
Full speed: 2200 RPM
As you can see, those temperatures are very very low, but i don't know how, surely they would be higher with a smaller fan than the TY-100?????
Anyway, as you can tell, all noise tests at idle are silent, but i think the 4mm standoff tests are slightly quieter with the side panel on with max fan speed, theres hardly any difference in it, but the 4mm tests have a slightly lower pitch sound.
For fun i did one last test as i was feeling rather confident with those low temps.
I tested the LP53 heatpipes in a vertical orientation. i used the 4mm standoffs and the a9x14 fan AND used the low noise adaptor that came with the fan:
Idle temps:
Prime 95 temps:
Idle speed: 618 RPM
Full speed: 1611 RPM
Not bad! as you can tell from the video it's silent even at full fan speed! this setup is the one to go for if you want a completely silent Dan pc.
if anyone has any questions feel free to ask.
I'm currently using T318+NF-a9x14 on x99+Xeon E5 V4. The fan is really quiet, but the temperature is quite high on full load. I also don't mind fan getting noise because my Asus gtx1080 turbo sounds crazy on full load..
Good to see x99 builds on A4-SFX!
Somebody reported severe temperature improvements with the C7 when adding the backplate, it was a reddit post that was copied here. I'm sorry for not tracing it down for you.I couldn't get the backplate to sit on the the Asus either, so far only one person I know of has done so (without modifying the backplate). Try undervolting your CPU, I've been able to drop my voltage down to 1.2 without adjusting clocks or multipliers at all and it still runs stable. I'm sitting at low 30's in idle and high 70's in prime 95 (ambient temperature is mid 20's)
For noise improvements on the C7, ditch the fan and replace it with an NF-A9*14 PWM, I'm running that at the moment and I saw no temp differences but it's much quieter.
And a 100% guarantee that Kickstarter customers shipment will start before reseller shipment.
Maximum burrito really maximized his dan case!Maybe the most genius build with the A4-SFX. MaximumBurrito is the creator of this build. To activate crossfire he used a Bifurcation riser.
If you use a single slot watercooling heatsink on the 1080 ti with singl slot bracket and second 3M Riser - SLI will be possible too.
Hey Dan to avoid that weld/sauter point, couldnt a custom bracket be made that allows a fan to mount and slide it in the SSD mounting holes?I thought it could work with the bottom fan so I tried to include it, but it will not work. This distance between clips is 92.8mm so very tight but it will work. The problem are the two holding screws of the side panel. So only a 80mm fan will work but I think there is no high quality 80mm fan on the market so we should drop that idea.
