So far my biggest issues with the game is the cashshop is fucking absurd, with gear that has stats on it (regardless if its minor or not) and the fact that fullscreen mode is broken and sets my monitor to 24hz. I need fullscreen mode, not fullscreen window mode.
Borderless Window mode@ Medium/Medium: 35 FPS
Fullscreen mode @24hz High/Very High (no high-end): 134 FPS
I gain over 100 FPS, standing in the same spot, just turning on Fullscreen mode and can up the settings drastically. It's just far too cinematic for my taste.
Well, after playing a few hours in CBT1 and now in CBT2, I just don't like the game.
did you try forcing vsync off in full screen mode?
But i think part of the problem is it is doing what ever hz is the minimum for your monitor, if you can edit your monitors accepted hz settings to only be 60 or 120 or 144 which ever you are looking for, it would run at the desired hz, but that is a lot of hoops to jump through lol
Full Screen mode seems to be working fine for me atm, but i have no idea if its freesync which is allowing it to work full screen
Yep. You can lean on things too.I feel like it looks better with the vibrancy filter off as well, i had it on before.
Also i do like that you can randomly back into rocks or other objects and sit on them lol.
It uses whatever the minimum refresh rate is. Your freesync is probably helping you not notice it.
I tried using CRU and stuff to cut out all the non 3840x2160@60 but it just doesn't work. Hell BDO is changing the refresh rate of users at their desktop even. FPS Problems
I checked it, and it was giving me 60fps solid full screen.
Same as full screen windowed mode, i dont have vsync forced off, but freesync is on.
Only using a single 290 atm since i doubt it has a crossfire profile.......and have high end mode off, if i turn i
1920x1080
Freesync range is 30-144hz
Monitor properties list:
144hz
120hz
60hz
30hz
29hz
25hz
I know its running 60hz in full screen mode, i can see the difference when i turn high end mode on and it drops me to 30-45 depending on how fast i move the camera.
Guys, how is 4k performance?
I'm not in the beta, but I have downloaded the free character creator, and I'm having about 30-40 fps in it. Feels bad as I want this game but I'm not going to play it on anything less but 45 fps with everything maxed out at 4k.
With full screen mode its possible. You wont be able to use high pc mode or whatever. They just gotta fix the bug.
Check sig for my pc specs.
Isn't full screen mode bugged where it lowers your screen refresh rate? How is borderless performance? This is what I mostly play.
What do you mean "high pc mode"?
How is your fps with everything maxed?
Hope you don't mind all these questions![]()
Borderless window mode is around a 100fps loss on my PC. On medium settings borderless I get around 45ish fps. Everything maxed out 12-20fps.
Fullscreen mode, is around 60-80 everything at high/very high except high-pc settings (It is a setting that adds extra stuff but really hurts fps)
Yes, it locks the refresh rate down as it is currently bugged.
Hmm I see. 60-80 fps is quite amazing at 4k and nearly maxed out! How much loss do you get if you turn even high-pc settings?
Mid 30's.
Again, I get those FPS, but the game locks the refresh rate to 24hz, which also screws up the color pallet of my display making it look like complete shit. If they can fix that, It has great performance in SLI, which requires fullscreen mode.
I read somewherer that if you turn V-Sync off it doesn't lock the refresh rate?
Thanks for answering my questions, really appreaciate it!
Create a resolution like 3840x2158 @60 Hz and then set GPU display scaling to aspect ratio and it should work. You'll get black 1 pixel borders above and below the image but at least it should run at 60 Hz.
Hasn't worked oddly. I tried CRU and everything. Some people are thinking its related to HDMI but I dunno. My screen only has HDMI so I cant try DP. I dunno if DP to HDMi would work, and I am not gonna spend money on a games bug lol
I should mention maybe i am using display port, which is obvious since i use freesync but might not be if your not too familiure with the tech.
So i can get it to work full screen mode 60hz using display port.
I use HDMI and if I use DSR the game will run at 4K@60Hz. I use CRU and only available 1080p resolutions are 60 Hz and 75 Hz.I should mention maybe i am using display port, which is obvious since i use freesync but might not be if your not too familiure with the tech.
$8 - $17 a month for dye.Wonder what our launch price will be?
2x 980SLI @4k. I'm not reaching 60fps with everything maxed, but my cards and CPU aren't maxed either. FPS is normally in the 45-57 range. I might need to tweak some of the settings in the Nvidia control panel.
Sli only kicks in in fullscreen if you arent running it. Also force vsync off to see cards at max.2x 980SLI @4k. I'm not reaching 60fps with everything maxed, but my cards and CPU aren't maxed either. FPS is normally in the 45-57 range. I might need to tweak some of the settings in the Nvidia control panel.
They've said no Prmeium Subs for US/EU.
Also, do characters change looks with gear? Because I equipped some (low lvl) chest armor and boots on my character and her clothes didn't change a bit.
I see. Think I'll stick to sorceress, the class looks fun
BTW, I guess there are no region limitations? If I preorder US version, I can still play on EU servers?
Because US version is cheaper than EU and I can just use VPN to get the US version![]()
