Monkey God
Mangina Full of Sand
- May 7, 2007
Yeah 5830's get you good numbers for the price. I run about 250mh/s with them, and I dont even overclock them much.
Hashing power is mostly about the number of shaders your card has. The 58xx series cards have more shaders respectively then th 68xx cards.
When/if bitcoin mining crashes, 5830's are going to be worth nothing. The 6950's seem like a sweet spot for a modern, usable card that will still hold it's value to people besides miners. I don't think you could go wrong picking up reference 2GB cards that unlock.
That's fine. I dont plan on selling my 5830 after this craze is over. It's a nice backup card.
XFX brand cards will probably get sold first over any other brands because of the double lifetime warranty...
I'm surprised at the resilience.
My thinking is similar to those posts above. I am suspicious that mining won't be profitable long term, so I kept my investment relatively low at around $169 and went with a 6870 for my HTPC. I would have liked to get a 6950 but they're considerably more expensive than that
I see lots of mention of SDK 2.1. I am not sure how to check what version I have installed and how do I installed 2.1 if I have something else? I have the newest drivers 11.6 I believe. I am sure I am probably running higher than 2.1?
If you did an Express install of any of the recent CAT's your running SDK 2.4. If you wanted to try SDK 2.1 you'd have to uninstall 2.4 first and then you need to keep in mind that 2.1 is only going to work on 5XXX series cards. If you have a 6950 or something you can't install 2.1.
Full git changelog:
Dean Lee (1):
Updated Chinese Simp translation
Doug Huff (3):
Fix rfc1918 and rfc3927 compliance for ignoring non-internet-routable host
Add common temp files to .gitignore.
Demystify a few magic numbers.
Han Lin Yap (2):
Added Swedish translation
Remove unused variable
Jeff Garzik (4):
Bump version to 0.3.23.
Reduce minimum TX fee for new transactions, to 0.0005.
Lower minimum relay TX fee to 0.0001 (from 0.0005) BTC.
Add minimal release process docs.
Matt Corallo (1):
Fix CPU Usage bug when using -nolisten and have no connections.
Nils Schneider (1):
create keypool in LoadWallet()
Pieter Wuille (3):
Update transactions already in the wallet when rescanning.
Fix for small change outputs
Faster timeout when connecting
Fixing a database issue that caused a block award to be given 24 times.
Pure insanity. Notice the row of 6970s has one laying on its side, roughly around the CPU area.
I'm half surprised the fans on those GPUs (which surely are working at or near 100% due to the heat) don't vibrate those cards right off the brackets.
Ouch - I'm glad I got out of BTCGuild. And here I was complaining about my little pool's bad luck.
Or maybe that's a box fan package in the background.
So about how long does it take to recieve awards from slush's pool? I requested them last night and my wallet is still empty....
As for BTC Guild, I suppose it's a good thing I havn't withdrawn yet today, lol.
They're trying to give me a negative balance so I'm ditching that account and I switched over to my backup miners set up for slush's pool. I got out my bonus btc an hour before they started putting negatives.
I think it's 8 GPUs, hence the 4 6990's. And as far as stealing from the pool, do they really want me to work off a negative balance? No wayI'm curious how he's getting 6 6970s or 4 6990s to work on one motherboard. I thought getting more than 4 GPUs to work on a single board was next to impossible.
Don't I just download the bitcoin app, and then copy the code that it enerates and paste that into the site as my wallet ID? Or did I just make a total noob mistake?You sure your wallet is up and running correctly, and has downloaded all blocks?
