Wol-va-rine I have a similar setup, 2x 120mm fans blowing at my 5770. I should upload a pic lol
No, they don't show that. The Week 18-20 and 20-22 increases are the only jumps over 40% this year.
Please look at the data.
Average increase means nothing. I'll let you figure out whyThe average increase is what's important.
No you have it backwards. The pace at which difficulty changes (up or down) is a measure of hashing power, nothing more.Look at the last 3 months, or the last 6 months, or the last 9 months, or the last year, and you'll see that the difficulty is doubling about every 4 weeks.
The only thing difficulty is supposed to do is change. There is a difference between changing and decreasing/increasing.I think what you're missing is that the difficulty level is only "supposed" to go up every 2 weeks,
So? That only means the network's hashing power increased so rapidly that it was able to solve 4032 blocks. I'll let you figure out where that number came from....and yet frequently in your list of data, it goes up twice in 2 weeks.
Again you have it completely backwards.So a bunch of what appear to be small increases are actually much larger if you look at how much the difficulty went up over a 2 week period.
P.S: As homework let me give you this little morsel. When the network solves the 210000th block people will no longer receive 50 coins as a reward, only 25. Try to work that into your math.![]()
It doesn't appear that you have, since you keep changing your stance. Keep moving that goalpost I'm sure you'll eventually get one right. The average increase is irrelevant for predicting future performance here. There aren't going to be another 450,000 Radeon 5850s brought online in a two week period. Your example was wrong. Deal with it.I have. The number of weeks over 40% this year is an irrelevant statistic. The average increase is what's important. Look at the last 3 months, or the last 6 months, or the last 9 months, or the last year, and you'll see that the difficulty is doubling about every 4 weeks.
Earlier you dismiss outliers in performance but here you are hung up on them? It's hard to follow this incongruence in your logic.I think what you're missing is that the difficulty level is only "supposed" to go up every 2 weeks, and yet frequently in your list of data, it goes up twice in 2 weeks. So a bunch of what appear to be small increases are actually much larger if you look at how much the difficulty went up over a 2 week period.
I think he's saying it's stupid to think that one million 5850s are going to materialize.I'm saying that a trend which has been going on for the past year and a half is likely to continue. What are you saying?
Figured I would share my data with you guys.. These were the best trimmed settings I could get without any changes in voltage..
VIDEO CARD 2
REFERENCE - Sapphire 6950
Non-Xfire (Dummy Plug)
(Currently in x4 PCIE)
6970 Shader Unlock Only
855MHz - GPU Clock
1375MHz - Memory Clock
0% - Power Control
56% - Fan (Any higher than this and I being to go deaf.. Refs are LOUD!)
173F - Average Temp
351-354 - MHash/s (371.6 Max)
Note that it is kinda finnicky to get the settings correct as I have to control the Reference card with CCC while turning the Non-Ref card with TRIXX to get the GPU clock up to 888.. If you open CCC while TRIXX is running it sets the NON-REF card back to default so I have to reapply the settings... So set your CCC settings first, then to TRIXX.. Also note.. At 191F these cards will lock up..
Is there a way to make TRIXX see both cards?
No point in pushing clocks past 800mhz if you're going to leave Power Control at 0%, they just get throttled down anyways. 855mhz core should be more in the 370Mhash/s area, 888mhz ~380Mhash/s.
yep, you and veeborg, lol, gotta do what ya gotta do in situations like these...
...6 blocks per day.
Awesome link for getting estimates on hardware
https://en.bitcoin.it/wiki/Mining_hardware_comparison
I've been hearing that getting in on the bitcoin mining business is now a waste of time and money. Is this true? i don't have a rig at the moment but would like to try to start it up.
I pay about $0.10/kwh, with a rig doing about 300W, I would need to mine enough to break even on electricity costs of $22 extra a month.
If you are pulling just 300w, what are you using? At $13 (medium-worst case scenario) a bitcoin, you'll breakeven at +/- 1.7 bitcoins a month for electricity.
All depends on your hardware... even at $0.10/kwh (relatively high) if you can pull .5 a bitcoin per day. you're still making a good profit for the time being.
Too costly for me, but thanks anyway
So what would happen once the difficulty increases to some 4M, more coins are released? It's at 877k right now but it's going up constantly.
I'd not recommend buying a system to do this. if you could use a recent graphics card for games then get an amd and use it for mining on the off hours.
I have a 5850 (secondary card) mining 24/7 in my rig now and mine most of the time with my 6850 (primary card), the only time I stop mining with the 6850 is when I game, once I'm finished gaming I start the mining again and can easily surf the web, watch videos, etc., while mining at the same time with the 6850...
I've seen you state this a couple of times. Let's get it straight. Intended block rate is 6 blocks per hour (one every 10 minutes), not day.
Good thing it sold out pretty quickly. I was about to pull the trigger on it and pay with my profits, but I just couldn't justify the expense.
Zepher you need to get an actual mining program. What you are running is just the wallet. Look into getting a program to mine with (I use phoenix)
Find a good pool to mine from, and make the miner mine in the pool.
How do you know if it is working?
All I see on the bottom of the window is | 8 Connections | 59610 blocks | 0 transactions
The Blocks started at 1000 and counted up to that number and just stopped when I started to post this.
I don't seem to be using any more power either, wattage is still at 265-273, which is my idle wattage.
EDIT: Blocks are now counting up again but wattage is still only 273.
Oh, ok. thanks.
Oh, ok. thanks.
But it has followed this trend almost perfectly for over a year now. You may not think it makes sense to use this extrapolation of future hashing power, but it's a trend that is not showing any signs of not continuing for the near future.
There is no reason to expect the processing power to continue to grow exponentially.
In Jun 2010 the total network rate was the equivalent of one or two Radeon 5850s.
Hardly a point to make inferences from.
How many hashes do you get with that 6850?
And why is the 5850 the golden boy for this? The card is about 2 years old, shouldn't the high-end 6xxx series completely crush it in terms of hash rate?
If I were to get a HD6950, would it matter which one it was? There are some that go for $280+ on newegg and others are $230-250, both having 2GB of RAM. Clock speed not withstanding, can't I just oc ether cards to a faster clock rate and save the money or am I missing something?
Hey wol-va-rine, can you make any more comments on this? I'm very curious. Many thanks.![]()
Hashing power is mostly about the number of shaders your card has. The 58xx series cards have more shaders respectively then th 68xx cards.
5850 has 1440
5870 has 1600
6850 has 960
6970 has 1536
Right now for new 6xxx cards, a 6950 reference cards that can have its shaders unlocked to 6970 shaders is about the best mining card/$ you can get right now.
That's pretty spiffy, how do we know if the card be unlocked or not? Or how do we know it's a reference card?
