Nice tip (but only 1 shady "reseller" shows up for me).wowcro said:Try going to BenQ.com and looking for stores there I believe you can enter your zip and they will give you a list of stores. I tried with Ohio but I didn't have any luck. Also, most likely in the stores they will hook it up via VGA and splice the pic 1 million times thus making the pic miserable...
I plan on getting this but from that comparison the ghosting looks bad.
Sweet, someone tested input lagHi all,
There is ZERO input lag on this thing. I briefly ran an input lag test using DVI cloning with my Dell 2005FPW and the BenQ was actually about 6 to 10 milliseconds faster, and the 2005FPW is no slouch in this regard. Both at native resolution (1680x1050 for the Dell, 1920x1200/1080 on the BenQ). Not sure how much interpolation will add, but I'll try that tonight.
i just got this and dont know what to think at the moment. windows reinstall seemed to go ok, battlefild 2 seemed to work just as i remember on my older hyundai l90d+
i hooked up the ps3 via hdmi to it though and selected 1:1 and noticed allot of what i have to play is a small resolution so that stinks.
but i am noticing jaggy/tearing on all the games i have played thus far like this. i am not sure if that is the source game and normal or not?
as far as ghosting i have not actually been able to pickup on it. at the desktop the games i have tried seem responsive at the mouse and no trails with vsync on.
anything specific i can do to help others make a decision let me know and i will try it out. i do not have access to a camera.
24" LCD's coming in a massive box usually. Dramatically larger than 22" LCD's. That's probably why the heavy shipping fee.
To those worried about color reproduction and viewing angle? Why are you buying a TN then?? Oh wait, because it's $369. Well, quit complaining about it being TN then. You get what you pay for.
Bestbuy here over in Western Canada routinely have the 24" Westinghouse on sale for $399. Might wanna look into that if you are worried about TN. More inputs that also.
This LCD here is for those that need 24" for the absolute lowest price and a better looking TN than other TN's.
