In terms of exterior design I'd be happy to go with the red case (which wouldn't actually be red, to be clear). The side-mounted I/O and lack of optical will no doubt bother some people, but those are kind of intrinsic to the design, and it wouldn't be the same if those were changed. So it may be that we need to just forge ahead, even if those things turn some people off.Necere, what are thought about the direction of this discussion? Which internal and external design is your favorite at the moment?
I assume you're asking about the 30L concept, since the 20L ITX version only has room for a single 240. The 30L would have a 120mm fan mount at the rear, so 280+120 in total. I don't foresee any options besides those. If you look at other cases in this size class (e.g., TJ08-E), that's about as good as you'll find.I am wondering if a single 280 radiator is enough to cool a x99 and one or two GPUs?
Any options for
[1] some holes on the roof or the floor for another 240 radiator and fan; or
[2] a pedestal under the case for fan and radiator (similar to Caselabs)?
I agree with all these points. In a perfect world, you'd be making both cases at once, catering to most people interested in these. But that's not realistic.I think if the side-mounted I/O is made modular and can be placed on left or right and top or bottom, it will minimize the number of people that are bothered. I'm actually warming up to this design.
I'm heavily leaning towards the mATX/ATX version. IMO the ITX version with its SFX PSU limit should be a separate project.
Have you considered a solution that allows people to change the position of the I/O? For the I/O it doesn't matter if it is mounted on the left or the right. You "just" need to design side vents that can be turned around.The side-mounted I/O and lack of optical will no doubt bother some people, but those are kind of intrinsic to the design, and it wouldn't be the same if those were changed. So it may be that we need to just forge ahead, even if those things turn some people off.
You will. And rightly so I'm afraid. If it is really just about the small extra height for a fourth expansion slot that gets in the way of full mATX-mainboard and ATX-PSU compatibility (let's not forget that ATX-PSUs could almost fit into that case as well), you will get a lot of flak. I think we are only leaning more towards the mITX-/mATX-hybrid because it is small. From a design standpoint the mATX-/ATX-hybrid makes way more sense.This forum will lean towards the latter, I assume. I just wonder if I'll catch a bunch of flak for creating an "almost mATX" case by leaving off the 4th slot.
In a small ITX-tower I would not go with the variant 1c anyway. In my opinion an ITX-tower should be designed for a small footprint, maybe with the radiator as an exhaust in the roof and the intakes in the bottom side panels and no cooling option in the front panel to save as much room as possible. Since an enthusiast GPU overlaps the mainboard with one to two slots, you have extra room underneath the mainboard that you could probably use for interesting fan setups (like have the fan intakes underneath the mainboard on the right side of the case).I feel like precluding (for the most part) SLI/Crossfire by design conveys the idea that it's more of an "ITX-plus" case, rather than an mATX case.
It's easier said than done. The I/O is integrated into the vents, and if you just switched sides they'd be upside-down at the bottom. But there may be a way now that I think about it...Have you considered a solution that allows people to change the position of the I/O? For the I/O it doesn't matter if it is mounted on the left or the right. You "just" need to design side vents that can be turned around.
It would need to be 45mm taller to fit both an mATX motherboard and ATX PSU. At that point you might say, well why not 20mm more for a 5th slot and proper SLI/Crossfire cooling? And then you might say, well, we need a 120mm rear fan to exhaust all that heat. And then we're back to the 30L version.You will. And rightly so I'm afraid. If it is really just about the small extra height for a fourth expansion slot that gets in the way of full mATX-mainboard and ATX-PSU compatibility (let's not forget that ATX-PSUs could almost fit into that case as well), you will get a lot of flak.
A top rad is just wasted space if it's not used, though. At least with a front rad the space is useful for longer GPUs and/or drives.In a small ITX-tower I would not go with the variant 1c anyway. In my opinion an ITX-tower should be designed for a small footprint, maybe with the radiator as an exhaust in the roof and the intakes in the bottom side panels and no cooling option in the front panel to save as much room as possible.
An idea is to make the foot piece from steel, but then the entire outer shell would need to be painted or powder coated.I would buy the "red case" with the clean front panel and the variant 1c internals. However, I'm not convinced that it offers enough over the competiton. Personally I still find the two color "half Mac" design more appealing and unique; the initial design you have posted here as a starting point combined with the perforated front-panel you have posted here and the either the variant 1b internals with the front I/O you have posted here, or the variant 1c internals with the front I/O mounted out of the way of the cooling options. The only problem we might have to solve are the feet. Maybe make them shorter so that they are sturdy enough with just 2mm aluminium.
That's why I don't like having the radiator in the front because usually I don't use abnormally large graphics card. It's an exception that I'm currently planning with an R9 Fury Strix (because of performance, power consumption, noise, cooling aaaand ... FreeSync). Anyway, I agree that a top-mounted radiator should part of a concept, like very thin case (which is not whithin the scope of this project of course).A top rad is just wasted space if it's not used, though. At least with a front rad the space is useful for longer GPUs and/or drives.
I prefer power coating anyway, and I think that this particular design would look better with it. But Lian Li doesn't do that, right? And I assume that we have no other options.An idea is to make the foot piece from steel, but then the entire outer shell would need to be painted or powder coated.
Not in-house, no. We'd have to outsource it, which would increase cost, though I couldn't say by how much.I prefer power coating anyway, and I think that this particular design would look better with it. But Lian Li doesn't do that, right? And I assume that we have no other options.
Same here. I imagine the vents to be a separate component that you can just rotate around the y-axis. Voilà! All you need now is a clever mounting system that doesn't care about the orientation of the side vents.The way I imagined it when I made the suggestion was to have the vents and the I/O be separates pieces.
If possible, this should be pursued, that way almost everyone can be happy. And if possible, have a front panel with removable cables with headers, so people can mod these easily (sleeve, extend, shorten, replace cables, etc.).I don't know if we had the same idea, but if that vent-piece was screwed to the case with four screws, one on each corner, couldn't it be made symmetric around the Z-axis?
That way you could have four possible positions for the I/O: left top, left bottom, right top, right bottom.
Shame more people aren't interested in top mounted PSU layouts. Not sure why that is.![]()
It's more complicated if you want to maintain a clean appearance and add some vertical rigidity to the panel.The way I imagined it when I made the suggestion was to have the vents and the I/O be separates pieces.
I think that would be rather ugly.Would it make sense to keep the foot piece as is (2mm aluminum) but support it from the inside with a loop made of steel?
We haven't found a suitable alternative at this point.As for Lian-Li and powder coating: Do we have other manufacturers to chose from?
Volume doesn't necessarily correlate to weight. The weight of the components is far greater than the weight of an aluminum case anyway, so if making it smaller means making it lighter, then you're talking about cutting features.And are we sure that the feet won't be stury enough, even if you make them smaller and reduce the volume of the case?
It wouldn't really be the same then, would it? I think much of the appeal of the "hoops" is that they are hoops, and visually separated from the case proper.Do we have other design options for the feet? Could the front an rear panel be tall enough to fill the feet as well?
Making the lower section from steel while keeping the rest aluminum would not be a good look.or you can have polished stainless steel. No powder coating required.
Keep in mind the audio jacks will have decals that are orientation-dependent. Also I don't want to use visible screws if it can be helped.I don't know if we had the same idea, but if that vent-piece was screwed to the case with four screws, one on each corner, couldn't it be made symmetric around the Z-axis?
A bottom-mounted PSU lets it have a dedicated air intake, lowers the center of gravity of the case, makes cable management a bit easier (they'll sit in the bottom instead of hanging down).Shame more people aren't interested in top mounted PSU layouts. Not sure why that is.![]()
One of the benefits for a compact case, specifically, is that it allows you to have a 5.25" optical drive in the "normal" top location without it running into the motherboard. The TJ08-E is a good example of that, where if you were to flip it so the PSU is on the bottom, the drives would have to go with it, or else the case would need to be longer to avoid fouling the motherboard.What are the benefits of such a layout? What does it offer that a bottom mounted PSU can't?
I hope and believe you could make it work. If the I/O block is seperately removable, the orientation isn't going to be an issue as you could keep it the same orientation for all four corners. The screws for the I/O block could be done from behind to hide them, the ones for the grill could be possibly placed horizontally to hide the top one below the panel and the bottom one inside the case. Ofcourse this is all considered in a vacuum as we don't know the internal design yet.Keep in mind the audio jacks will have decals that are orientation-dependent. Also I don't want to use visible screws if it can be helped.
To keep a cleaner top appearance, flipping the PSU so the intake fan is at the bottom would work wonderfully to maintain the nCase solid top panel aesthetic and give some extra exhaust oomph under load (with those PSUs that have the fan that only starts when needed for cooling).
I don't think you necessarily have to stick to the 312mm afforded for PCI-E cards, I think you can shave off a few millimeters in the name of compact dimensions and go down to 295-300mm to save space. Very few video cards exceed 300mm in length, even dual GPU versions. This would allow a set of 25mm front intake fans and potentially a 30-35mm radiator to be attached to the front.
As for the concepts and ideas: I don't think that you can make something really interesting unless you go for the psu over cpu setting or vertically in front.
Putting psu in normal config, in my opinion, just makes it a generally bad idea since there's tons of cases to pick from and unless you're making a nice SFF that stands on the desk, the size doesn't matter.
The main issue with this is that the PSU and GPU, if SLI/CF, would be competing for air. The typical scenarios where they are under load and require extra cooling are in most cases identical, which means that they would most likely reduce each others cooling capacity when they need it the most. Since you say you are a steadfast watercooler this of course would be less of an issue for you, but it's still very much an issue imo.
I don't think people will buy this because it offers functionality and/or innovation previously unavailable, but rather because it is really really nice.
This is of course just throwing opinions around, but I don't think it is necessary to do something differently just for the sake of different. I think the limitations introduced by your suggestions would put too many people off it compared to who get won over.
Maybe we should start to think in directions that have haven't been explored yet.
It's not a bad take on the SG09 layout. The front ports are a little problematic on the red case design, since the PSU exhausts right where they would be, and it's a wide layout. But at least with that width tall CPU coolers/GPUs and cable management wouldn't be a concern. The possibility of tri-SLI is interesting, though the PSU length is a limiting factor there. I'll have to explore the idea further.I'm a total noob at this so go easy on me. I like the idea of mATX/ATX and played around with combining the idea with 2.d so give me your thoughts on this.
1) We are referring to ATX PSUs, most of which do not employ the use of a fan unless a certain temperature threshold is met. It is likely that even with an axial fan sitting right below it spewing hot air towards it, the intakes providing fresh air to move that warmer air negates it sufficiently that said threshold will not be a concern, which means there will be no fighting occurring.
2) The post you are quoting does mention the addition of a diverter plate for the PSU if necessary, which would thermally isolate the two sections.
I disagree. People will not buy this over a design that already exists and is cheaper, simply because it is nicer. It does need to provide something beyond that. Or, perhaps I should say, it will not be bought in that volume that Necere/Wahaha360 need to consider to meet MOQ.
I don't feel the idea of making something look really really nice but internally just slightly different than mainstream cases. I'm not sure but I think there's going to be a ton of cases to choose from and argument of being slightly looking better since it won't use plastic doesn't get to me. I might be biased and that's just my opinion though.
But what is the selling point then if people could get a similar case from manufacturers like Silverstone for probably less than what an mATX Ncase would cost? A clean front panel without any functionality? Is that the reason why people should pay 200+ Dollars for a fairly common internal layout (that it less capable than every $80 case)?
If I were to build such thing, I'd definitely want to make it unique in functionality and size. Making a SFF case supporting amd octa cores would be cool for a start since there's always this question if there's anything mATX/mITX that supports them properly. And since AMD is preparing their next arch to hit soon-ish there might be another of such power hungry but over 9000 in terms of cores to think of.
I am not sure we'll ever agree on this. It's not like I can say that you are wrong and I am right. Out of those that are active in this discussion I seem to be outnumbered though
If the scope of this project was to make a true SFF mATX case (which from what I understand, its not) then you could, for the sake of size, make all sorts of compromises which could lead to an innovative and/or unique case. But if size is not the main goal (Necere has already stated its not) then you're left with making a case which offer as wide an application as possible, with a design that hits home with as many people as possible. I guess its a matter of deciding whether we want this discussion to get the best result for the scope as it is today, or if we think the scope itself should change.
There is a reason why traditional internal layouts has become the norm. No matter how boring, it really works. Either way. The possibility to cram an ATX board in there is kind of unique, so there's always that.
There is probably something here I am missing, but do you mean mATX with more extensive cooling options due to the high TDP of these chips? wouldn't a 240 rad suffice for this? So shifting the focus to sub 20L and 240 rad support?
The TJ08-E design aside for above reasons, I still think your statement hold weight. The question is only adding ATX support going to be radical/untried enough to produce? Per my other post, I'm interested in seeing where the SG09 can be improved.I think the key here is either going with something that is radical/untried, or really going after either the SG09 or TJ08-E design and refining it.
I think that good idea might be a combo of two ideas:
1) ATX with psu over last 3 slots proposed here http://hardforum.com/showthread.php?t=1878878
2) ATX with psu over the cpu.
Make the PSU mountable in both positions. Add mounts for water cooling rads in front of the case.
This way you either have "lower end" build that won't obstruct the cpu cooler but have one or two cards max or you use cpu water cooling and put the PSU over it to have all slots available for gpu's.
Making the dual mount for either card or PSU over the motherboard card area might be tricky though.
With the PSU over the CPU design, do you intend to have all of the expansion slots available? Or still limiting to 4/5?
Actually making 17L ATX case with ATX psu over the cpu is quite possible even with water cooling. I did the draft assembly and it looks so obvious to do. Why noone is making this?
Case dimensions would be 330 x 305 x 168 mm
Coolers/blocks up to 55m tall. 280 rad mount in front of the case that would fit with fans when gpu's have water blocks.
