Battlefield 3 General Discussion Thread
I see now. I do have a RAM-related question.
My mobo is a GIGABYTE GA-MA790XT-UD4P. I currently have G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) in. I did get some more RAM as a gift. It is a G.SKILL DDR3-1333 4GB 2GBx2 would it work to just put the other 2 sticks in
Yes, it'll work.
It's your ram. This I tested myself. After a couple of minutes of gameplay, my game suddenly keeps stuttering (w/ 4gb ram). When I added an extra 2 GB ram (good thing I have extra ones), the stuttering was gone.
I went back to 4 gb again to test if it really was the ram. The stuttering came back. So after testing personally, I believe that you need more than 4 GB ram.
this. i had the exact same issues with stuttering etc.
upgraded from 4 to 8 gigs. smooth as butter. also shortened my loading times.
With the price of ram, many people are just upgrading to 16GB. I think we'll be good for awhile ;)
EDIT: Also, when exiting BF3, it takes my computer a good 1-1.5 minutes before it is "operational" again. RAM usage % goes back to normal but its very unresponsive after exiting this game for a while.
You were likely dipping into swap which would cause stuttering and this post-exit behavior. You could confirm using the resource manager or performance monitor with a counter, but it sounds like you already figured out you need more ram ;)
thats what I did.
I checked my usage and with 8gb of ram I was dipping down to 1100MB free
I need to check again now that I am at 16gb.
Man, no matter how much I play this game I can't get used to the decimated ground vehicles turned into wet paper. One RPG can disable a tank and a 2-second strafe run from an aircraft can destroy a tank. Just craziness. Some noob's at DICE must have been getting their butts kicked hardcore by some people in armored vehicles to obliterate them in a nurf.
I need to set a repair macro so that when I back up my nearly destroyed tank from one hit, I click the repair macro and then I can go the store and do some shopping, come back to a repaired tank and be read to go again.
"Connection to game server has timed out" Been getting this lately. Do you guys know what causes it?
Yeah, I agree. Anyone have any idea about how many RPG hits it would take in real life to disable/destroy a tank?
Depends where it hits. In reality it only ever takes one, as an RPG that hits a non-critical area doesn't count because they don't do incremental damage. You can bounce 50 of them off the front armor and the tank doesn't care. But I think most modern tanks are well protected against RPGs - it takes something more powerful to really damage one now. Insurgents in Iraq didn't have much success using RPGs against tanks.
OPSEC.
And keep in mind that in real life tanks do not operate alone. Regardless of whether you even hit the tank, you're going to have to deal with some VERY highly trained, VERY well-equipped, and VERY PISSED-OFF infantry. ;)
It's really just a big grenade right that's why its an RPG rocket propelled Grenade. Mostly used against light armor/UN-armored vehicles and as Anti-Personal munition.
The HE (high explosive) warhead is a general-purpose explosive warhead for use against soft targets such as infantry, unarmored vehicles and fixed positions.
yes RPG-7's are spitwads to tanks IRL.the RPG 32 is the more current version and is comprable to the SMAW
Exactly this. In "real life", generally speaking an anti-tank munition is either completely effective or completely ineffective. That being said I read a report about a British Challenger II that took several RPG hits and yet was repaired and back in the fight later that day. The main damage to that tank was to the optics, damaged by small-arms fire if I recall correctly, and the tracks, damaged by driving into a ditch after the optics were taken out. Really just think about it; If you hit a tank with some kind of weapon, the type is irrelevant to this discussion, on its left side, and then hit it again on the right side, would those two hits "add up" their "damage" to the tank? Or would you just be left with no penetration on both sides and a fully-functional tank?
I mean hell if you want to talk realism, what kind of body armor are these guys wearing that they can take several hits from the GAU-12 mounted on the LAV-AD and survive? Those are 25mm rounds carrying over 70,000 ft-lb's of energy. I don't want to know what it looks like when someone gets hit with something like that in real life.
You get shot by the mobile AA gun in real life they would be lucky to find your boots. I hit a guy like 6 times and he managed to get off an RPG to blow me up....wth.
That's what I'm saying. Keep in mind that I'm not saying I think the mobile AA *should* kill in one hit(although I think it should do more damage than it currently does), I'm just saying that any time someone wants to say that the game is a certain way "because realism", they're missing the fact that almost nothing about any of the vehicles or "heavy" weaponry is even close to being realistic.
Plus, keep in mind that in any vehicle in this game you have unlimited ammo. Realism be damned! :D
Of course, yet another caveat in the name of fun. All I'm really saying is that if you can't finish your "because it's realistic" argument with "and also fun", then the fact that it's realistic doesn't matter. Limited ammo would be realistic but would it be fun? Maybe if the vehicles were as tough and powerful as they really are, but I don't know, it would require a rebalance of the whole game. Technically I'd say infantry get infinite ammo as well, because the support class carries around a magic ammo crate that he can make as many of as he wants and that anyone can get as much of any type of ammo as they need out of ;)
Well, I've said it before and I'll say it again...if you want realism in a large-scale military FPS, go play ArmA 2 OA. :cool:
Bastards, I'd feared it was this but hoped it wasn't. Got no cash for 8GB (the 4GB set I have already seems to have been discontinued or is super hard to find) and this hitching has been driving me up the wall lately. Even went so far as to record it myself with the intention of making a video just like this. Locking up for 1-7 seconds at a time every 30-90 seconds. Very irritating.
Exactly this. In "real life", generally speaking an anti-tank munition is either completely effective or completely ineffective. That being said I read a report about a British Challenger II that took several RPG hits and yet was repaired and back in the fight later that day. .
I think that's pretty common of any armoured vehicles with the composite/reactive stuff. You might be thinking of the reports of a Warrior IFV I think, which took seven RPG-7 and two RPG-29 strikes whilst remaining operational. Something that would be phenomenally overpowered if they implemented it, which is why the realism argument is silly.
Though on the flip-side, I find it annoying when a developer makes an effort to make a game semi-realistic as with BF3, by making all the ARs firing the same cartridge from the same length barrel do the same damage over the same ranges, but then goes and does something out of the blue and totally inconsistent, something BF3 also does a lot.
Is it easier for jets to out maneuver missles from the heli's now? Seems like every time I lock and launch my missles jets just turn in circles and the missle will impact behind them for 0 dmg, and no the jet isn't using flares in these cases.
Interesting related point: "RPG is an initialism from the Russian language РПГ or ручной противотанковый гранатомёт (transliterated as "ruchnoy protivotankovy granatomyot"), meaning "hand-held anti-tank grenade launcher". Thus, "rocket-propelled grenade" is a backronym."
http://en.wikipedia.org/wiki/Rocket-propelled_grenade
Can't you get an 8 GB set for like $30 now?
Little more expensive in the UK: ~£40 ($60-70) for 8GB with comparable timings and voltage ratings, before delivery. Unfortunately still more than I have disposable right now.
I always wondered why its was called a "rocket propelled grenade" and yet was meant for armored vehicles.
Well, I cant, because my mobo only supports 4 gb ddr2 and, I dont know why but ddr2 memories are 2x more expensive than ddr3 :eek:
Because it's obsolete technology. PC-3200 1 GB sticks still go for like $20-30 apiece brand new. It's crazy.
I watch my gauges religiously while I play. BF3 is regularly using 5GB+ while I play. Meaning if you don't have 8GB you're GOING to take a performance hit. It's that simple.
BF3 doesn't use 5+ GB. Your system might, but BF3 by itself doesn't.
Thats not my case cause BF3 is regularly using 3 to 3.51 GB on caspia border and kharg island on my pc .
....Im wondering how much would cost a nvidia 8400 gs?.... it must cost about 300 dollars :eek:
Probably will when they stop making them, as is almost the case with older memory tech. I worked at a CompUSA for a couple years, and I remember when DDR2 was out, and there was still PC133 out, and it cost as much for a 128MB stick as a 1GB stick of DDR2, or something ridiculous along those lines.
Same for EDO-RAM after SDRAM hit the streets.
Supply and demand.
There is little demand for 8400gs, and there is still enough supply for what little demand is left.
DDR2 still has high demand despite lower supply. Manufacturers can only produce so much memory, and right now DDR3 is in even higher demand than DDR2 so the majority of production is dedicated to DDR3. The time to buy DDR2 was back in 2008 when you could get 8gigs for $100. Right now you can get $16gigs of DDR3 for $100. Its time to max out your machines with RAM if you plan on keeping a DDR3 machine for another 3 years.
Any advice on how to win 5 SQDM rounds? I've been playing quite a lot lately yet I always seem to get on the worst team - no kidding. Out of all the rounds I've played I have only been in one where our squad won.
Get lucky. That's really all it comes down to. Try to find a lower ticket count server so it doesn't take so long - you could find 1 ticket ones, but I think that is too random, something like a 10 ticket is better.
Every since the last patch I have been having huge rubber banding. The pings on the servers are always <70 so I don't get it. I put everything on medium just in case on a 16x10 monitor.
Funny you mentioned that, same here. I thought it was lag but I have excellent ping.
I've had it once or twice. Both times while I was in a tank (though I spend most the time in vehicles) and only for about 30 seconds. I just thought it was network issues, or steam/windows/whatever was downloading something. It stopped both times after 10 seconds or so and then a few mumors a few seconds further along before stopping entirely. Both times i've exited steam, checked there was no updating things and nothing. Networks were a virtual flatline other than BF3.
Theres 12GB of ram (+ fast 24gb swapdisk from video editing) and plenty of vram/GPU/CPU, especially for the settings I play at on multiplayer. So it's kind of mysterious. It's only happened about twice in hours so it's not terrible, but both have been since the last patch and it's never happened before.
'cuz it sounds better than "rocket propelled shaped-charge warhead" :D
just imagine screaming AR PEE ESS DUBYA instead of AR PEE GEE...that would suck
