Watch, they'll start coming out of the woodwork. Prolly by the time I hit submit on this post, there will already be some DDR's(DICE-DICK-RIDERS) defending them. Just watch!BTW! Q-BZ....I'm not throwing you into that group, your posts are well thought out, and it's clear your not a mindless fanboy.
Thanks. I try.
I'm not a hater, I'm actually enjoying the game but I do have some issues with the game in it's current state.
Squads - There is still no easy way for you to create a squad with your friends. If you have a group of 4 people and you join a server with more than 75% capacity, you'll most likely wind up on opposite teams and very likely on different squads. Trying to change squads and get everyone on the same one is nearly impossible, especially once the server fills up.
Party Joining - Certain browsers don't display the popups properly, and others are hindered by anti-virus. Options are to disable anti-virus (no thanks) or use a browser that you don't want to. For me, I'm still unable to get it to work properly on any browser even when I disable my anti-virus.
Rubber banding - I know a lot of people recommend disabling Hyperthreading to achieve better results, but it doesn't work for everyone. Like man other people, I have some video/audio encoding that I do when I'm not gaming so disabling/enabling HT constantly is not really a good option. I still think there are issues with the netcode that are causing this.
Mouse issues - There are numerous documented cases (and videos) of the stuttering, input lag, negative acceleration and other mouse issues. The sensitivity adjustments and "Raw" mouse are not clearly defined so it's difficult to find a solution. I finally found decent settings after playing around with the in-game settings and my drivers but it still doesn't feel quite right.
I could go on, but I'll stop here. The bottom line is that there are plenty of valid issues that need to be addressed. You can't simply dismiss these as someone being a "hater" when they clearly need to be fixed. But I have some faith that DICE/EA will fix these things in due time.
I wouldn't classify you as a hater by any means. This is a great post with specific points that everyone can follow.
Frankly, I don't disagree with any of it although I've not had these mouse issues some other people have had. Some of that I've either just been lucky or it's been a timing issue because I haven't had some severity on some of those issues like other people have but I know those issues are out there and I have been effected by some of them to a degree myself at times.
I, too, could probably bring on some valid issues but you've covered the broad points good enough for me.
The rubber banding thing...I saw people complaining about it on a couple of our servers here a few nights ago and then...something got changed somewhere on the server end presumably and those complaints went away so I'm not sure the rubber banding situation isn't a problem from one or multiple "sources" clashing the wrong way.
I saw it, too. Since that first night I've never seen it again and I have HT and I haven't changed a thing on my system FWIW.
Overall, though, lumps and all...I'm having a hell of a good time and seeing a pretty damned good game that I know I couldn't get the same experience on any console. That's all I'm trying to say here.
