Comixbooks
- Jun 7, 2008
anyone using gsync? I just got a gsync monitor. is this the correct way to enable it? vsync in nvidia control panel: use the 3d application setting, vsync in-game: off ?
There should be a set up Gsync settings in under the Nvidia right click on the desktop control panel. Some older games you need V-sync enabled if you have two monitors a 60hz and the Gsync just play around with both of them and you can tell the difference usually right away if Gsync is working.
Also if you just circle the mouse on the desktop and see lots of mouse pointers it's working at 144hz instead of 60hz.
Some older games don't support Gsync but usually all the newer one from the past 3-4 years work with it.
I know like Fallout New Vegas you need to have V-sync enabled to get rid of the stuttering. The additional FPS in the game might read out but don't smooth out the game because it's a older game.
The first game I played with a High Refresh monitor was Call of Duty AW and I couldn't believe how smooth the game was Gysync is just icing on the cake along with high refresh rates.
