D
Deleted member 202674
Guest
I use my X1C offline and just put files on a microsd card. You lose out on the ability to monitor it via internal camera and send it files though.
I wasn't a fan of the inland pla I got. Not sure if it was a bad batch, but my orange pla strings a ton. I dried it before as well as I always do. I typically order Amazon basics, sunlu, creality, or hatchbox. Honestly never had a bad experience with any filament other than that inland orange... Hopefully someone can chime in and confirm a different experienceWas able to finally snag an XMAS present for myself (and kids) in the P2S Combo from Best Buy. Arrives Saturday and purchased the 4 yr Geek Squad Warranty as well.
Now to get some Inland filament from MicroCenter. Figure Black, White, Gray, Red, Blue, Yellow is a good starting point. Is PLA+ worth it over the PLA Basic?
I like using COEX and Atomic Filament as they are local enough that I pass one for work and the other for family trips and can pick up and even got a factory tour at COEX.
https://coex3d.com/
https://atomicfilament.com/
In the middle of last year, I bought a Creality filament dryer (Creality SpacePi X4) that has dual two spool chambers so you can do different temps at the same time. I must have somehow missed this Sunlu device that fits on the AMS. It looks pretty good, especially for the price.Didn't read thread. Just came here to post I love my P1S. It lives in my garage with an AMS equipped with the Sunlu lid dryer. It's pretty much non stop printing *something* out there and once I learned to RTFM and started to understand what the settings all do it just spits out flawless print after print. I don't really care about custom firmware versions when this just works as is. I'm also a filthy Apple heathen and the Bambu Studio software works fantastic on MacOS, even better than on Windows from a lot of places that I read.
The only thing I would change is I wish it had a proper ethernet port. I've got a gigabit switch about 8 feet away on ip camera duty that would be easy to attach to. The built in wifi is very slow which I've read is a known issue. Other than that I would buy it all over again.
Bought a P2s about a month ago and since I bought it from best buy, i'm going to be returning it for an H2C so I can do multi-color prints without a ridiculous amount of waste.
You can say that i'm addicted at this point. Just looking to print things to make my life easier, or make some cool trinkets for the kids.
Not just wasted material, but wasted time. Changing colors every layer takes so long.Bought a P2s about a month ago and since I bought it from best buy, i'm going to be returning it for an H2C so I can do multi-color prints without a ridiculous amount of waste.
Yup, and it has dual nozzles, so 2 color prints should be fairly quick as well. Just gotta wait for the AMS HT to come back in stock so I can get one and then i'll be able to have 5 color prints pretty easily.Not just wasted material, but wasted time. Changing colors every layer takes so long.
Looking for a smoother plate than what came with my P2S...any recommendations on one?
Got my 3d printer station setup the way I like it finally.
H2c setup with an AMS HT for left nozzle and 2x AMS 2 pro's for the right nozzle and tool changer.
Changed up all of the filament storage bags to cereal containers with spool desiccant holders to keep them dry in storage.
Nice!
Did you see the filament track switcher thing for the H2D? Well, there are a bunch of notes about it for the H2C in the current release of Bambu Studio
I did, but i'm not quite sure what the point of it is for the H2C.
The left nozzle is just attached to my AMS HT and i'll swap the filament there when I need and for everything else on the right, i've got 8 slots to use on the 6 tools.
Sometimes that left nozzle goes unused for long periods of time even with the best of filament mapping.
It can speed things up, possibly, based on the print.
I mean maybe on single color prints, but for me, anytime I slice a multi-color print using the default slicing option, it'll call for something to be in the AMS-HT.
Now I suppose if I didn't have the AMS HT, I could just use 2x AMS 2 Pro's to feed everything and have 1 slot leftover. Or alternatively, if the left nozzle runs out, it can auto refill from another slot on the AMS. That could potentially be a couple uses cases there.
We are between the H2D and H2C for us at work. how are you liking it so far? Main use for us would be support material and reducing purge and contamination (currently using single nozzle system).
Have you printed near the bed edge with petg or abs? Good adhesion?
oh good. our current assortment is a k1 and raise3d, so time to get something a bit better. hoping to get one of them soon to play with!I'm loving the H2C for it being a hobbyist printer.
The H2D has a slightly larger bed if i'm not mistaken due to the vortex system now taking up some space.
I have not printed anything large enough to near the bed edge, but adhesion is good with PETG. I'm assuming the bed heating element and chamber heater is better than the old P2S I had as I have not had many bed adhesion issues with it.
No printing with ABS yet for me, only PLA/PETG currently.
Has anyone else had to disable the setting "long retraction when cut" in your filament settings? I keep getting extruder overload errors because when changing colors, it leaves the filament stretched out and not a flush cut which causes issue when it loads that filament again.
P2S Combo. Using SUNLU PLA+2.0 filaments.What printer are you using?
OK, thanks. I'm glad it's not just me then. I disabled that setting in my filament properties and am re-running a print that gave me fits yesterday with those constant errors. Hopefully it will make a difference.My P1S does the same thing, just makes a melted stretched mess. I haven't figured out how to solve this. My H2C has super clean cuts/retraction
alxlwson try disbling that "Long Retraction When Cut" setting under Advanced tab in each filamntn setting. Seems to have done the trick...hopefully it stays that way.
