You're good too man. I love you <3
You two should get a room. So you can then compare your BC2 e-penis sizes.
So does anyone know how to use the grenade launcher properly? I can never really figure out what that crosshair means.. that's why I never really bothered with the grenade launchers in most games lol.
C4 and AT mines both can be detonated through other explosions, and if the secondary explosion kills/damages anything, it's attributed to you, at least the team damage portion is.![]()
I will say this...
The usefulness of the weapon is only properly demonstrated in 2 situations:
1.Taking on squads. You might get 1 or 2 guys before the last one finally gets you. A real bitch when the remaining survivor is a medic that revives all of them anyways and you get fucked.
2. Blasting away cover. If they are behind any building structure, you can kill them with it. Hell, half the time its better to aim at the wall near or behind the person instead of actually at them.
Using the grenade launcher against a single target out in the open is really an exercise in futility. You usually get killed before you can load a second round.
Well guys after a week of trying to get this game working its now working fine and its just dumb what the cause was.
The cause was (love this) displayfusion .. even though I did disable it a few times to try running the game without it running in the backround , after I restarted from installing 10.3 cats and disabled this program it runs just fine. How retarded considering this is the ONLY game that doesn't like it.
1. Aim the nade launcher at the guy with the funny little hat
http://denkirson.xanga.com/722757523/bad-company-2/
This is really interesting. it seems that some of the best weapons can be unlocked early and the last weapons to be unlocked aren't any better in some cases. i didn't think this was true, though i'm only level 10 right now.
This part is of note:
So that kind explains why I can't hit anything when I'm a sniper, and never seem to do damage while shooting at a helicopter. I see everyone else shooting at Heli's so I have been but according to this I'm not doing any damage.
Based off the above, it looks like I should stick with the T88 S for Sniper since it uses regular bullets and won't gravity drop like the others I was using.
bumping myself, heh. just wondering if anyone had a chance to look at that webpage I linked above with weapon stats. Just trying to figure out if I'm reading things correctly![]()
Bullet. The standard for all weapons from pistols to the weaker Recon Rifles. They are almost not affected by gravity at all.
Sniper_Bullet. A bullet affected by fake gravity. Used by the M24, SV-98, GOL, and Slug Shotguns
HMG_bullet. Used by stationary and vehicle mounted machineguns. That AND the M95 sniper rifle. It drops as much or slightly less than Sniper_bullet.
The feature of HMG_Bullet is that it can damage lightly armored vehicles such as Jeeps and Helicopters.
My game goes to 1-2 fps when I look at the score. It is crazy! Just pressing tab will literally make my game a slideshow.
The menus when I join some games are painfully slow to deal with. Not sure why that is. Usually when the game gets going its fine.
Did anyone see a huge frame drop after the steam patch? I took a 20-30 frame drop. A few people over at the steam forums have mentioned it. Curious if any of you took that hit?
lol
I made a perfect sneak around the enemy yesterday.
4 of them in a tight pack.
I grin.
Pull out grenade launcher
Shoot in the middle of them.
No kill.
Screamed NOOOOOOOOOO as they all turn around and decapitate me with bullets.
Sad![]()
lol
I grin.
No kill.
Sad![]()
Toss a nade and get ready to pick em off as they turn and scatter in panic.
For some reason, at level 16, I still haven't unlocked nades.
No idea why
Is there a way to throw your kit on the ground? Last night a team mate and I were jumped in one of the houses at White Pass. The guy managed to kill my medic before I dropped him, so I switched kits with the medic, and defibbed him. I was an engineer, so I dropped my XM8-C w/ 4x scope, tracer dart, and CG kit. The zombie medic woke up with a XM8 in his hands and was probably pissed that I took his M60...![]()
Nope no way to switch back with out real coordinated effort for you to go kill some one pick up their kit, medic picks up his kick then you grab your old kit.
Most of the time it is not worth it.
One thing to note, is you get xp towards the unlocks for the class you spawned in as regardless of what kit you are using.
So you can spawn in as a engi kill a medic and take his kit and rack up the points with heals and defibs while unlocking engi gear.
I am absolutely useless with grenades, I don't get how people can use the 40mm grenade with any effectiveness. I end up just using it for destroying cover or small vehicles.
Hit f? They shouldn't be locked.
Pretend the crosshair isn't there, I went from 48% accuracy to 59% when I figured out the crosshair doesn't help that much.
playing on hardcore servers helps you figure it out very quickly lol
Are you saying ignore the tick marks on the crosshair, or ignore it completely?
No doubt, I went from guessing by the crosshairs to HC squad DM, accuracy went up right awayFeels nice to tag someone in the face with the GL at 50 yards.
Ignore completely. Don't listen to folks who grief the noob tubers either, M60 and Gustav pretty much make you use 40mm to stay competetive.
wait.. so they're just ... there?
haha I expected to see them in my kit selection.
I fail so hard![]()
