Mine is quite small and I have to be looking for it to find it. Newegg said I could exchange it and ASUS said I could advance RMA it. I'm not sure which route to take but I have to leave for business soon so I might just RMA it. Who knows. I want a calibration tool as well but I'm willing to put down a little bit of money if I can use it on my TVs as well.
I gotta say the glass helps make the colors "pop" but the colors looks imho look better and fuller. Maybe I need to calibrate more but I think it looks better than my ACD. I miss the glass but only a little. The height adjustment is CLUTCH.
I'm unfamiliar with backlight bleeding. Ran a simple test that I read here. Set background to black and turned off the lights. I have one pic at 80% brightness and the other at 30%. I can see a glow on each corner. How do you all feel about this? I'm not very nit picky but I did pay a hefty amount. What would you guys recommend? Thanks in advance.
80% Brightness
http://imgur.com/vnbCD,649Uc
30% Brightness
http://imgur.com/vnbCD,649Uc#1
80% Brightness
30% Brightness
Yes, i agree. Cameras normally tend to overxpose 1 on 2 steps of light
Keeper or return?
The Asus has a PLS panel and the same semi-glossy coating as the Samsung 850D
http://i.imgur.com/8mnhx.jpg (all you see is glow exacerbated by the camera)
http://i.imgur.com/TNo62.jpg <- white-point uniformity
Coming Soon - Asus PB278Q
isnt that pretty bad uniformity to the left side? its darker
Why would anyone in the US buy this for $300.00 more when this is available at Microcenter for $400.00???
http://www.microcenter.com/product/384780/EQ276W_27_IPS_LED_Monitor
^ Have you calibrated the screen? when I got it I thought it was a POS coz of the bleed but after calibration everything became much better.
If you are spending $500+ on a screen a basic hw calibrator is a must and there is definitely a warm up period for this display, after 15-30 mins both luminosity and color temp become quite stable across the screen, still some difference like on almost IPS panels but nothing too bad on a screen this size, now if it did not have the 1 cm bleed at the two spots on top I'd be dancing
