Arcygenical
- Jun 10, 2005
Sorry, but no pom-poms either.When all my friends were doing that kind of stuff I was doing mad scientist work in the science lab.
Lab coats can be sexy too
Arcygenical
Lab coats can be sexy too![]()
*rolls his eyes to the lab coat comment* you guys a nuts.. but thats cool.
Anyway, I am probably building a case around the cooling system, Or I am going to mod a Lian Li PC343 to hell and back to make everything I want to put in there fit. Im planning on three loops, eventually, a CPU loop, a GPU loop, and a Chipset/memory/hdd loop.
Im planning for three loops, because im planning on cooling a Quad FX system, and hopefully still being able to use all of my PCI slots(hence, the looking at the Alphacool). I am certainly not against mounting things on the outside, or modding the case itself to make it a bit bigger to fit my needs. I'll give you all a description of my idea so that you have more information to give advice on. Keep in mind, I would love to be able to control all of this from ONE device (if the aquero can do it, ill use that, if the mcubed can do it, ill use that.)
Here goes:
Loop01=pump-cpu01-cpu10-rad-res
loop10 =pump-GPU01-GPU10-rad-res
loop11=pump-chipset01-chipset10-rad01-memory01-memory10-hdd-rad10-tline
I plan on using a 120.3 for loops 01,10, and a pair of 120.2s for loop 11 (yes, i do mean thermochills) I would like to use a single pump in each set though i think loop 11 might need two, not really sure at the moment, will definatly have to test that.
I want each block to have a thermal sensor on the block itself, or the water right above the block's transfer surface, will have to test that on a couple of the blocks. I want flow meters on every loop, at the end of the loop (so right after the res).
I will be running 100+cfm fans that i want to be able to undervolt to run nearly silently, then crank up when im gaming (I use AKG 240s, they block out outside noise pretty well. And they make most games sound beautiful.). I want to run 7 total on the rads, in pull configuration, all on shrouds. (if i end up mounting a bunch of the stuff outside the case ill end up using two shrouds, one to use as a mount, the other for the fans, with the rubber seals between each point (fans-shroud-rad-shroud-case) to make sure there is as sealed an air channel as possible.
I probably wont do the chipset/mem/hdd loop right away, will probably wait till i get everything else squared away first, then add that by the time i go to Boston University in Janurary.
The hardware specs, at this point, are unknown, but will be either a Quad FX, or Skulltrail system (hopefully skull trail is out by the time im ready to buy the hardware), and whatever the better graphics solution is at the time i am ready to buy. 8gb ddr2 at 800mhz (or 4, depending on which version of Vista i decide to go with), and a pair of raptors to run it.
The system is being designed as my gaming/work rig, with the majority of my information stored on another system (a server that i will bring with me, just a small one, about 8 drives total, and headless). When im working I want to set it to be just about silent, and when im sleeping/watching a movie, then, when im gaming, i dont care what it sounds like, i just want it to be smooth, cool, and fast.
Thanks for all the help thus far, try to stray from the arguing, just post opinions as opinions, and if you have facts, link them, thats the best help for me.. Thank you again guys.
I imagine you're going to be an engineering student simply by looking at how you refer to your components through bits.![]()
I haven't seen any mention of monetary constraints so I'd suggest you head over to Mountainmods.com and have them build a custom case to hold all three radiators. It'll make life easier as most cases out there, including the Lian Li cube will not have the correct fan hole cutouts to mount PA rads. I currently have a U2 with a three loop system and I seriously can barely fit everything in there. I wish I purchased a custom case instead so that my wiring wouldn't be so tight. [/quote}
I may do that, though i was planning on drilling holes in the top or right-hand side of the lain li to fit everything, and make 5.25" bay mounts for the pumps, unless i go with the Aquastreams, then i dont need to, they can attach to the back of the aquabay.
The mCubed line will be able to control your pumps and fans based upon whatever digital AND analogue sensors read your temps at. You'll be able to undervolt and overvolt your system through either preconfigured settings or through power/temperature curves (automation). You can hook up to 8 digital thermometers (more accurate than trashy analogue thermometers that come with most other bay devices that need to be calibrated) as well as 4 analogue thermometers and flow meters.
the Mcubed line sounds like what i want to use, I would love to see how yours is set up, i didnt really get much out of the madshrimps review pictures
Shrouds themselves will offer little benefit if you do decide to go push/pull. Shrouds only demonstrate a performance gain for low CFM designed radiators like the thermochills. And even then, the performance gain is only seen with a pull configuration.
I was planning on a pull configuration, not push pull (i dont know if i said that or not..) the second shroud i would be using as a mount.
Have fun in BU. I spent two years there before transferring. I just hope you're prepared for the winters. For a California raised student, I was in for quite the shock.![]()
Haha, I have lived in Maine my entire life. And i just spent a school year in New York. Ill think ill be fine.:-P (oh, New york sucks for compsci schools.)
Hmm to go back to the car analogies that Top Nurse so often favors.
All those options for the aquaero software are a bit depressing. It is like a formula one car with all the extra sensors and gauges to measure every little bit of the car....the depressing part is it is like those gauges were installed in some old 70s car. Probably beautiful to look at...but why would you want to know 18 different oil temperatures in a car that isn't designed for performance?
The only area where I feel AC has done anything good is with the aquaero and the aquasuite. Their blocks are mediocre at best. The double impact seems needlessly restrictive, it took the longest time for them to come to their senses and offer a stronger pump to go with their restrictive tubing. All in all, its a shame really. Also their reliance upon aluminum is annoying as well.
The only reason to get a system that uses all aqua computer parts is if you absolutely can't live without them. Some people fawn over their looks as if it were the next coming of jesus. Personally, I don't care for their blocks...look similar to most other things on the market. From a price / performance standpoint there is zero, repeat ZERO, reason for operating any aqua computer components in your loop. Everything they can do can be done for cheaper, and better by other solutions. If it can't, then it is something frivilous and useless like changing the color of some lights for reason X.
well, i really like the Aquasuite now, so looks like i will definatly be using AC for control, but, im thinking im going to go with either the D-tek FuZion cpu block, or the Appogee GTX swiftech block. Chipset blocks will be swiftech, and im still up in the air on the GPU block. probably going to end up with an alphacool, to test it out, if i dont like it, back it goes, and ill pick up an EK and possibly undertake a little motherboard modding to fix my PCI issue.... *starts thinking* though that could be tricky, i think i have a small enough soldering iron.
Why not have the best of both worlds? I achieve a nice over clock with my e6600 (3.5ghz) and get everything in the world as far as control. If you don't want to spend 600 bucks on an Aquaduct (well worth the money), go with an alphacool pump with new head and the Fuzion. I read somewhere you can overclock the pump via Aquasuite with the right module.
Nice to see you back here.
One of the things I love about AC bashers is their tendency to twist and distort the truth (FUD) to what ever suits their purpose. First it was Ranker decrying that AC wasn't a good investment because they didn't make new mountings for their coolers even though all AC coolers have mountings made for all processors. In fact they pioneered the concept of replaceable mounting screens for water cooling blocks. Before AC, if you wanted a new mount you were expected to buy a new cooler.![]()
Now we get Erasmus354 claiming that the AC stuff is crap. BTW, they were offering DDC pumps for sale some three years ago. They made a hardware/software controller for the Laing pumps that interfaces with the AquaSuite some 6 months ago. Do you see any other domestic company making this kind of product? Probably not because they don't have the infrastructure to support a total water cooling concept like AC, Innovatek, and Koolance. What they can't make in a machine shop they farm out or out buy.
So how do you know anything about the Double Impact cooler other than seeing two pics of it? Is this objective? From the way I see it it is more FUD.
Interestingly, they appear to have sold many thousands of these Aquaero devices (my serial number is 4453) so somebody must think they have merit. I can't say that most of those sold have ended up in AC systems or not, but I suppose it is a good bet.
One of the things I get a kick out of the big is better crowd is that they only want to believe in sterile laboratory testing. Now that I have a state-of-the-art water cooling system that will report on whatever minuscule changes in the water cooling system I make can be easily tracked and data compared I get more FUD.
When I doubled the output flow in my system what do YOU think happened?
CPU is a Core2Duo6600 and it runs with 3600 Mhz. i can also overclock it up to 4000 Mhz stable
The temperature is max 55° C
so who cares about flow rates. flow rates are overrated as hell.
gimme the same rig and worse temperature .. i overclock higher
Cheers
slame aka Stefan Krumme / aqua computer Berlin
Hell yes ...
i knew i registered once on this little forum.![]()
registered 2004 and this is my first post.
Just dropped in to quote myself from various other topics where i answered to our customers.
My personal oppinion on reviews is ...
as long as i didn´t do the review on my own i don´t trust them. There are some actual examples out there showing what i mean. Take a look who is sponsor of a site and think again about reviews. I don´t mean any special site with this oppinion, but i know that there are so many "mistakes" while testing.
We do our own testing but don´t show them public. If the cooler wouldn´t perform good there would be no release.
Some more about testing.
1. you need to have the same room temperature on all tests.
2. no whiffs allowed
3. the pressure on the processor needs to be the same on every cooler
4. thermal compound needs to be the same everytime
5. error ratio on temperatures
and on and on and on, i could do this for hours
See .. it´s nearly impossible for any amateur / semipro site to do serious testing. and if u only have one "mistake" the results will differ a lot.
and btw ... i don´t care about flow ratio
my rig ...
airplex evo 360
airplex evo 240
airplex evo 1800
2 aquadrives
cuplex XT
ABIT OTES voltage regulator cooler
2 ramplex
2 small ABIT voltage regulator coolers
1 NB twinplex
1 SB twinplex
2 aquatubes
1 aquapower
1 aquagratix1900 core pro
and the pump ? is an aquastream on standard flow
Cheers
No Top Nurse, there is no FUD here, simply facts and solid observations. If you take of your rose colored glasses and actually read what I say, and not what you think I said you would see that. Don't try to read into my words, take them at face value. There is no hidden agenda here.
Hell yes ...
registered 2004 and this is my first post. slame aka Stefan Krumme / aqua computer Berlin
Great statement and wish more people could think outside the box.
The power of marketing is incredible in the USA.
Now ain't that some FUD. The height of your overclock has nothing to do with watercooling at all. You're limited by other extraneous factors such as the quality of your CPU stepping, the voltages allowed by your motherboard, motherboard stability, etc. The whole point of watercooling is being able to SUSTAIN overclocks by keeping temperatures as low as possible to keep electromigration as low as possible.
It's funny how AC is taking a play from the Republican playbook. Since they can't find any legitimate sites to back up some wild claims here that AC products can beat current performance leaders, they now resort towards attacking the methodology of these reviewers as well as claiming that temperatures aren't important. Why watercool at all (besides the quietness factor)?
Simply put, a company who digs its head in the sand and ignores the natural evolution of watercooling is doing a disservice to the watercooling community.
And here we have the main difference between the German and the American market3. watercooling is for silence, thats what we think.
And here we have the main difference between the German and the American market![]()
I hate to say it but narrow minded thoughts like yours are the main reason we see so many "just bought a garden hose configuration and my temps still suck" on this forum. I hate to bust your bubble but the temp difference between 1/2" and 6mm is only 2-4c which will not make or brake an overclock. You could also note that this very forums website doens't use 1/2" based watercooling for reviews and testing....
I hate to sound repetitive but you need to get past the fact that size of tubing has the least affect on overall performance of a computer.
2. electromigration ?cool, you know some other words for "your cpu is living longer". Or did i misunderstand you ?
slame
You've been pwned Ranker.![]()
Since we have 3 AC diehards/engineers/employees in this thread, I'd like to ask a question out of complete curiosity. Why is aluminum still used in your blocks? I know you guys employ a good hard anodizing service (expensive too, from what I hear, upwards of 5e per piece) but what are the virtues of aluminum over copper, other than their machineability?
I've never been able to get a satisfactory response, as these types of threads deteriorate into complete madness and get locked, before any good information can be contributed.
