Alright, im building a new computer setup for school. Watercooling is on the top of my list of things to do, Im actually going to be buying the case and cooling stuff before the hardware. Now, my problem is, what to go with. I have setup two different systems, pretty much, and cant decide which one to use. Either Aqua Computer (all AC components) or a Dtek CPU+GPU and a chipset cooler of some kind.
Lets get right down to it, here are the common peices
Aquero LT
Multiswitch
a pair of Thermochill 120.3 (two loops, one of each block on each loop)
Im using AC to control things, becuase of the Aquasuite, which, from what i have seen will allow me to control two loops. Ill be using an add-on for my G15 to put the information normally on the Aquero screen on the LCD on the G15
Here is the AC list of components
Cuplex XT or XT DI (need to see performance specs) (probably 2, if Phenom FX is as good as rumor)
twinplex x2 w/swiftechs 8800kit or aquagrafx 8800gtx
twinplex XT for chipsets
2x Aquastreams w/controller
The Dtek List
Dual FuZion cpu
Dual FuZion gpu
Swiftech chipset cooler
2 Laing DDC 2/petra's top
If i go AC, i will probably end up getting 2 aquabays as well, with the mounts for the aqua streams
If Dtek, not sure what im doing for Res yet.
I will be overclocking, mildly, so im not too concerned about top performance
computer specs will be whatever is top in the fall (so probably dual phenom FX with a pair of 8800gtx or 8900gtx if a refresh is released by then. Quad FX also means dual chipsets to cool)
Thanks for the help in advance, feel free to make suggestions on loops, and definatly comment on which you would go with, and why (besides the tubing size difference)
Aquero LT
Multiswitch
The Dtek List
Dual FuZion cpu
Dual FuZion gpu
