Runningflame570
- Jan 28, 2008
There's a big difference between the proprietary DirectX that's owned and operated by Microsoft that ANYBODY can use versus the proprietary PhysX that is controlled by one of the major video card manufacturers and can ONLY be used on their cards.
There really isn't. Like PhysX, DirectX is a single-vendor standard. The fact that the vendor in question is ubiquitous (on the desktop at least) may change the end result a fair bit, but it doesn't change the facts behind things.
The person you're quoting is correct. DirectX does hurt gamers as it limits PC gamers for practical reasons to using Windows and it's one of the few remaining major hurdles to broad cross-platform compatibility.
You should hope that Khronos gets their collective heads out of their ***es and improves things sufficiently to eventually replace DirectX as all else being equal OpenGL would be better for people as consumers.
Anyways: AMD/ATI **** yeah!
