My $0.02:
Ordered Shimian QH270-Lite from seller dhsummer early morning 8/3. Total cost $275.90
Package arrives at my door in Georgia the afternoon of 8/7, I figured it would take twice as long to get here.
Screen is basically perfect. There's one stuck pixel. My old SOYO had several stuck pixels so this is pretty good. I can't notice it unless I look for it.
Came with a 110-240v power brick which works fine. Plugged it into the power chord from my old monitor.
Back of the monitor is spartan with just the power input and dual dvi port. Fine with me.
I thought it would look and feel bigger. The higher resolution is definitely noticable, but so is the aspect ratio difference. I wish they still made 16:10 monitors. A 30" version of this would have been pretty sweet.
Glossy screen is more reflective than the matte SOYO but it's not as terrible as some people say.
The stand is just fine in my opinion. It's would take a strong earthquake to possibly knock the monitor over and it doesn't feel any worse than the cheap stand on the SOYO.
Gives off a LOT less heat than my old SOYO (power brick gets slightly warm). I assume this is because of the LED backlighting.
My 6850 seems to have no trouble adapting to the higher resolution for the games I play.
TLDR: It's cheap and it works fine. Would recommend.
they do make 2560 x 1600 16:10 30 inch monitors Dreamseller has a bunch of them for $799
http://www.ebay.com/itm/FIRST-FSM-3...4794?pt=Computer_Monitors&hash=item4d032f2b9a
