I got all excited when I started reading through this thread, but not so excited anymore. Judging from comments, even with the higher refresh rate these would still not be as good at gaming as TN monitors. Or am I misreading the thread entirely?
Not to split hairs or anything but in the interest of accuracy and preventing further confusion:Well...no...I would stick with a 120hz TN for SC2 and COMPETITIVE shooters.
The beauty with this 1440p monitor at 97hz, however, is that it's great for everything else. Also, it is cheap enough so that you can own both...eventually. That's my plan at least.
You've wandered into either personal preference (you might be looking for bleeding edge gaming characteristics) or personal perception territory (misreading comments maybe).I got all excited when I started reading through this thread, but not so excited anymore. Judging from comments, even with the higher refresh rate these would still not be as good at gaming as TN monitors. Or am I misreading the thread entirely?
The limitation wasn't written into it's firmware, in so many words. I'm guessing it was simply overlooked and not on purpose.What is it about those monitors that allows for the refresh rate increase "cheat" vs other monitors?
That's not bad. Certainly I think most of us here can easily determine if there's going to be a problem with any hardware in that kind of time frame.
Great! One final question then: how hard is it to "overclock" this monitor to 80-100Hz (assuming an Nvidia card, I know AMD seems to be limited to 85)? Is it just a matter of setting a value somewhere? Finally, is there consensus on whether monitor overclocking affects longevity/image stability?
Maybe the OP can include a FAQ of sorts for these types of questions if he has time.
Return shipping to Korea is about 100 bucks.....
BB
NVIDIA users can add a custom resolution to get 100 Hz:wabbitseason said:Great! One final question then: how hard is it to "overclock" this monitor to 80-100Hz (assuming an Nvidia card, I know AMD seems to be limited to 85)? Is it just a matter of setting a value somewhere?
necriss said:Here are the Nvidia Control Panel timings for 100hz Catleap. Automatic timings allow a maximum of 97hz, for 100 the following manual timings are required.
There isn't much data out there, but I've been running the NEC EA231WMi at 83 Hz for over two years without problems.wabbitseason said:Finally, is there consensus on whether monitor overclocking affects longevity/image stability?
The HDMI equipped Catleap seems to be what I'd need. So the general consensus on these is pretty good? Any common issues?
I don't like quoting my own post but, anyone down for a summary of events? Don't really want to read through a 23 page thread.
ATI/AMD users can use my program to get 85 Hz by adding a detailed resolution with these timing parameters:
Program: http://www.toastyx.net/cru-preview.zip
Release notes: http://hardforum.com/showpost.php?p=1038342324&postcount=6
You may see very faint horizontal lines at higher refresh rates, but those lines are also there at 60 Hz. Raising the refresh rate makes the lines slightly stronger, but I wouldn't worry about it. I've seen those lines on most H-IPS panels, but I didn't bother mentioning them since hardly anyone seems to notice them.
Yes, that's basically what you have to do. I don't have a way of testing the resolution through the program since the program basically just creates an EDID override, which requires a driver restart to take effect.Blazestorm said:Question about using your program... How do you know a refresh rate is valid?
If you pick some refresh rate for a monitor, restart, and then try to apply that resolution and it doesn't take will Windows just do the 30 second time-out and reset to the old one?
i need display port for eyefinity =)
The first resolution is considered the native or preferred resolution, so if you edited the first resolution instead of creating a new one, it will boot into that.Blazestorm said:Haha, I must have done something wrong because it auto-picked a bad setting once I restarted. I was just playing around with it on my 3007, I figured not much would happen.
The hardware is capable, but the driver ignores anything over 330 MHz when using dual-link DVI. We would have to convince AMD to remove the 330 MHz limit, or at least raise it to 400 MHz.Blazestorm said:Also Windows says my DAC is 400MHz, you think my 5870 could do 100hz like the Nvidia cards?
Would someone mind...
Thanks. Would like a bit more high quality photos. Lots of those are smallish and a bit muddy. Not much varied content. Not to be demanding but I'm considering not 1 display but 3.
Ok, I missed the acronym dictionary so what is OSD? Sorry I went through most of the threat (I want to say 95% of it) and I just gave up. That being said, Mine should be getting on a plane nowish Korea time, so it should get here tomorrow morning I think, then customs and whatever followthrough in Cali, I have a D90 and should be able to take the pictures requested, and I will also be taking detailed pictures of the Catleap WITHOUT the back (as I and several others have asked for already ) since I want to use the VESA Mount.
WOOHOO!
Is it confirmed that the Catleap Multi version has OSD?
