i do, i've been crazy busy with other things and i'm about to go on vacation for a week and a half, no consistant computer accesslithium726 said:i've got a X2 3800 coming in from newegg! (cf) needs to update the charts![]()
what are you doing with the ram? where does the mobo top out?rayven01 said:Figured out what my problem was. The MSI CoreCenter program I was using for temps/voltage readings was unlocking the agp lock. Just using clockgen & mbm I got up to:
2520 @ 1.38, (280x9) stock cooling, prime stable for over 9 hours. Can't seem to get to 285, even upping voltage.
(cf)Eclipse said:what are you doing with the ram? where does the mobo top out?
dr_dirtnap said:Chip: A64 X2 4400
ADA4400DAA6CD
CCMWE0524RPMW
OC:2695 (11x 245) 1.55v
Cooling: Air - XP-90c, plus a bad ass delta
Prime Stable - 24 Hours
I thought I read somewhere about X2's having trouble running 2 instances of super pi since X2's have only one memory controller. As soon as I start the second instance it quits.
Hopefully once I get my Ultra-D back, it was DOA, I will be able to get that extra 5 mhz. This neo 4 platium crapped out on my 3800 venice at about the same HT.
bored-sarcasm said:3700+ san diego
ada3700daa5bn
cabge 0522xpbw
2781.43 @ 1.4v on air
264.9 * 10.5
see it here
just got this running too.![]()
ada3700daa5bn
cabge 0522xpbw
264.9 * 10.5
see it here
sorry i don't have time to really answer this, but now is where i urge people to read rule #1 againLionKinG88 said:I'm not such a good overclocker so I would like some help & advice.
i'm assuming air?honkee said:Venice 3200
ADA3200DAA4BP
LBBLE 0521BPIW
Z711186E51889
305x 8.5 at 2600 mhz(133 divider)
1.577 volts 16 hours prime stable before i stopped it
congrats on being the firstlithium726 said:3800+ Manchester
voltage and cooling?fuelvolts said:3000+ Venice
ADA3000DAA4BP
LBBLE0521BPFW
Boots at 2.434
Prime Stable 24 hours @ 2.4 (267x9)
this will be interesting, hurry it up!newls1 said:I just got an FX57 with these numbers:
ADAFX57DAA5BN
CABCE 0522XPMW
I'M waiting for my vapo to show up, so I havent installed it yet, but will post my OC when all done. Im hoping this chip will OC well.
you're missing the batch code there friendheadless said:Got my new 3200+ and evga board last night
Prime stable for 6 hours so far @ 255x10 = 2550mhz @ 1.48
LBBLE, 0522
(cf)Eclipse said:you're missing the batch code there friend![]()
