A64 OC Database & Overclock Guide
DaLurker said:
Hey, I thought I might give you the max overclock I achieved with my last Venice CPU.
Stepping is
LBBLE 0519 CPFW
Max overclock was 304 x 9 = 2736 @ 1.67v on Custom Watercooling.
I'm on my second Venice core now (killed the other one removing the IHS :() I'll let you know how this one goes.
0523 CPAW.... hopefully it's good
i'll update soon, just posting this for future reference. i also want to commend you guys for the sudden drop of spam in this thread. makes my job a lot easier :D
Might as well wait until Sept 1 to update, as you've gone over your monthly quota on the hosting site for the images! :p
Semrpon 2600 @ 2.32 Ghz (290x8) with stock voltage, stock cooler, and even worse, stock paste. Motherboard was KV8 pro. At 291 system is unstable and has several memory errors, but at 290 it's rock solid and Prime's for over 72 hours.
Validation...
http://valid.x86-secret.com/show_oc.php?id=33597
EDIT*** Forgot, runs SuperPi 1M in 43 seconds.
really? according to my host, i'm only 1/2way through my bandwidth.
Eickst.. go back and read the first post. you didn't supply of the production data i'm looking for :p
also, if you're getting memory errors, drop the ram divider. i don't care what the ram speed is, just the cpu :D
Ah crap. Guess I'll pull the info on that when I get back to the shop. As far as dropping the RAM divider, it didn't help, so I set the memory to run as close to 200mhz as possible. It's like there is a brick wall between 290 and 291. I can't see how it's the motherboard, as the memory controller is on die, but anythings possible.
AGP/PCI lock. via chipsets are known to have issues with it... but i'm stunned that you made it to 290mhz. most via boards either top out around 240 or 260-270mhz
Yea, the PCI/AGP is locked at 66/33. If it wasn't locked, i would probably have never made it past 201.
no, what i mean is that the lock sorta fails when it gets to around 260-270mhz for most of the via boards.
and if it was unlocked, you'd be limited to 230-240mhz :D
i gave him that quote of 26-270, as thats where my via chipset shit the bed. some are better then others, and you sir, have one better then others.
not a final overclock - just results so far ;)
3800+ X2 CHBHE 0527 UPBW water cooled swiftec storm
HTT-280==2.8ghz @ 1.648v
DFI NF4 SLI-DR 704-2BT
BFG 6800GT PCI-E x2
2x512 OCZ-4200 Platinum TCC5 1:1
2x 200gig Seagate 7200.7 SATA
510w PCP&C SLI / Antec 480 for all pumps/fans
Win XP Pro SP2
VID= 1.55
VID SPECIAL= +110%
CHIPSET= 1.7
LDT= 1.5
VDDR=2.9
LDT= 3x
CPC = 1T
CAS Latency(CL) = 2.5
RAS to CAS(Trcd) = 4
Min RAS# Active time(Tras) = 7
Row Precharge Time(Trp) = 3
Row Cycle Time(Trc) = 7
Row Refresh Cycle Time(Trfc) = 14
Row to Row Delay(Trrd) = 2
Write Recovery Time(Twr) = 2
Write to Read Delay(Twtr) = 2
Read to Write Delay(Trwt) = 2
Refresh Period (Tref) = 200 MHz 3.9us (3072)
Write CAS Latency(Twcl) = 1clk
DRAM Bank Interleave = enabled
Skew = auto
Skew Value = 0
DRAM Drive Strength = 7
DRAM Data Drive Strength = 2
Max Async Latency = 9ns
DDRAM Response Time= normal
Read Preamble Time = 6.5ns
Idle Cycle Limit = 256clks
Dynamic Counter = disabled
R/W Queue Bypass = 16x
Bypass Max = 7x
32 byte Granularity = disabled (4 bursts)
attachment.php
X2 Manchester Data:
ADA3800DAA5CD
CCBWE 0528MPMW
2625mhz
1.575V
Air (XP-90)
625mhz OC
Seems after that Core 0 craps out on me. Core 1 keeps going and going even to 2.7Ghz. If I go WC, I might get a little more out of it. We'll see if I think it's worth it after I pay this off first ;).
Athlon 64 X2 3800+
ADA3800DAA5CD (crippled Toledo core)
CCBWE 0525XPMW
2 GB Corsair xms twinx 2048-3200c2 pt @ 1T 2,5-3-3-6
Abit AV8 3rd eye
Thermaltake Big Typhoon
2400 mhz (240x10) DDR400 1.375v bios
2600 mhz (260*10) DDR435 1.55v bios
After so much testing, here is my FINAL OVERCLOCK! Or at least until ASUS decides to fix the 1T command rate problem on the A8N-SLI Deluxe. First of all, I could not have made it this far without the invaluable help of (cf)Eclipse and CCA. You guys are great!
Worth mentioning is the fact that my system will do 255MHz x 11 = 2.805GHz with the same memory timings and voltages but it will not pass Super Pi, even though I can play games and use the computer without a problem. But since I want to be able to use the system without worries of potential instabilities when least expected and the fact that in order to post my details on this thread it has to be fully stable, I will have to settle with 250MHz x 11 = 2.75GHz.
Here are my details:
AMD Athlon 64 3700+
ADA3700DAA5BN
CABGE 0515SPMW
1237218D50990
Final "stable" overclock:
Air cooled with ThermalTake Big Typhoon
250MHz x 11 = 2.75 GHz @ 1.5v vcore
2.5-2-2-8-2T mem timings @ 3.0v vdimm (running at DDR500-PC4000 with DDR400-PC3200 rated memory!)
Just picked up a new venice 3000, seems to not be on the chart, but I could just be dumb(been out of the pc game for a while) I got this in akihabara in japan so it makes sense to me that its a bit newer:
ADA3000DAA4BW
LBBWE 0530CPFW
will post o/c results after i finish installing gentoo, compiling kernel/os + segmentation faults = not fun.
edit: did a search, seems its a toledo w/a defective core haha
edit #2:
now running at 277x9 for 2493Mhz stable.
The board boots when i set the bios to 300mhz, but when i check in cpuid it's only actually running at 276~277.
http://valid.x86-secret.com/show_oc?id=35717
Toput all that in one neat spot:
AMD Athlon 64+ 3000
ADA3000DAA4BW
LBBWE 0530CPFW
2493Mhz, 1.45vcore, air cooling
# 1st line of OPN ADA3800DAA5CD
# 2nd line of OPN CCBWE 00528MPMW
# Maximum 2710
# VCORE: 1.55 --- buggy board wont let me go no higher
# cooling type: Air
X2 3800 275x10 1.52v
DFI nF4 Ultra-D 702-3 bios.
Gskill PC4400 (TCCD) 2.5-4-4-8
SuperPI 32mb Run:
All bench tests done at 275x10: : Next 2.8....
Here is my X2 3800+ to replace my A64 3000+
ADA3800DAASCD
CCBWE 0529RPMW
It is cooled by my Koolance AL and is Dual Prime Stable @ 2608Mhz with 1.52 volts
and my OCZ Plat. Rev 2 PC3200
I know i am being held back by my 27C ambient temp that my computer room is at
what custom settings should I use when running a Prime 95 torture test? or should I just do the blend test instead?
Venice 3200+
0518 APEW
Max FSB was about 330ish, max OC was 250x10 @ 1.55v (may be a little higher volt than neccessary.) I could probably go higher, but my board (A8N-SLi Premium) limits volts to 1.55 so I'll never know.
2 sticks Corsair, 1GB each. 3-3-3-8 1T, DDR333 divider (about 208MHz)
ADA3800DEP4AW
CBAZC 04385PBW
2720Mhz
1.65v
Chilled water (+/- 23c)
100% stable Prime ran thru entire one week vacation, memtest ran, about 2 hours, then I got board and wanted to game.
Im getting a 3700+ SD next week. :p
Yo Eclipse. After all this time of reading an referring others to this thread, I've never given you props for making it.
Great job bud!
great thread eclipse didnt have a clue about overclocking a64's, had been on a-xp's for ages :)
your guide has helped me up to:
ADA3000DAA4BP
LBBLE 0521BPFW
2710666F50991
thanks for your help, and i dunno if u remember the advice on the ram when i had my mobile xp (bout 4 months ago), but its transferred over a treat to this a64 @ 250 2,2,3,7 :)
:edit: cooling = xp90-c and 92mm panaflo
30000+ venice e6 core
2790 310*9 1.63v
don't know the week on it but I jumped 150mhz after flashing to the 6/23 bios for my dfi ultra-d
ram is at 279
3000+ Venice (E3) / Asus A8n-sli
ADA3000DAA4BP
LBBLE 0519GPMW
281mhz*9 -- 2528mhz - 1,44V
1gb ram @ 230mhz
ada3800 daa5cd
ccbwe 0529spmw (e6)
10x290 @ 1.57v
xp90/medium panaflo
ocz el gold pc3200 bh5 2-2-8-2 3.6v 5/6 divider
memtest stable
2xprime stable
2x 32m superpi stable
very truly yours,
politenessman
perp, that's crazy fast. care to provide a screen of it being prime stable since it's.. so far beyond what's typical for X2's so far?
I(illa Bee said:
ADA3800DEP4AW
CBAZC 04385PBW
that's newcastle! :p (and has a borked week anyway ;))
2790 310*9 1.63v
ram is at 279
you're missing some important stuff
ADA3000DAA4BP
LBBLE 0519GPMW
1gb ram @ 230mhz
cooling?
biovader and YourPaceOrMine... i need your final stable speeds :D
ADA3500DAA4BW
LBBWE05256PMW
2750mhz 250x11
1.525v
166/200 divider (trying to increase memory, cpu speed will not change.)
Air
ADA3500DAA4BP
LBBLE 0524GPOW
2.5ghz 230x11 1.425
Using an XP-90c with medium speed panaflo. I would take it higher but first I need to figure out whether or not this XP-90c was a big waste of cash or if my evga motherboard is reading temps off over 10c because I get 47c idle 61c load :confused:
sry.
cooling is done with a xp-120 with a 1200rpm papst fan.
idle temp is ~35C°
load its 49C° after ~5hours prime95
specs are now:
ADA3000DAA4BP
LBBLE 0519GPMW
280mhz*9 -- 2519mhz - 1,46V
1gb ram @ 229mhz
I am having trouble raising the HTT beyond 219-221MHZ. I have the following setup
EVGA SLI mobo
Venice 3000 + xp 90 HSF
512*2 Corsaid value select ram (Probably not the best ram for overclocking)
I have my HT multi at 2x, CPU multi at 5x and ram running at 100MHZ. Then with Prime 95 running the computer freezes when I increase the FSB from Clockgen to around 219-221MHZ. I have not tried increasing any voltages yet, all voltages are at default values. The cpu temp from Myguard is around 44 degrees (when I run the prime 95 torture test. Idle temp is 38). Oh, I also tried this with the HT multi at 3x, same thing happens. Any ideas why the FSB wont go higher? I'll post any additional info you need about my settings. Thanks.
I was able to get htt up and around 320 or so with my eVGA SLI mobo using Eclipses method. I'm having other issues though. I can't get my 3500 venice past 2530mhz. I'm not sure if it's the ram or CPU holding me back. The eVGA bios only goes up to 1.55v for CPU. 250x11 won't post half the time even at 1.5v and errors out in Prime95 after a couple of minutes. Same issue with 240x11. I'm not sure of the exact divider because of the evga mb bios layout but it's always one less than max, 250x11 was 200mhz 240x11 was 208mhz. I'm testing right now at my normal oc of 230x11 hoping that this Crucial Value ram isn't the cause of my problems after the recent upgrade. Ah well, I guess 100-200 mhz isn't anything to stress over. I guess when comparing your potential OC to outspoken [H] members OC's you should subtract a few mhz or a thousand for a realistic expectation :D
Here is an update OC for me to my previous X2 3800+
ADA3800DAASCD
CCBWE 0529RPMW
i also got 2 x 512mb BH-5 and it is still cooled by my Koolance AL
I popped her top and she is now nekked, running with an exposed core :D
my temps. now MAX out at 50C before i pooped the IHS it was running at 53C and only at 2.6Ghz
Nice thread! I am a XS native but read this site all the time. So I figured I would join. Anyway, here is my chip on air then on phase. I have a 3800 X2 CDBHE 0526UPBW. My day to day oc is at 3ghz 1.53v 1:1.
On air TT Big Typhoon without the IHS::::
24/7 settings::::
On Phase 3.1ghz stable::::
System:
X2 3800+ CDBHE 0526UPBW **Testing With Mach1**
DFI LANPARTY UT nF4 Ultra-D w/ 704-2BTA bios
Mach1
Ram-Patriot-PDC1G4800+XBLK
Enermax Noisetaker 485w PSU
EVGA6600GT
Highest OC @ 3330MHz
Looks like Eclipse isn't updating this anymore but I'm now able to OC higher than 2.5ghz with my 3500 venice. Turns out setting my hypertranspont frequency to 800mhz in bios allows me to oc much further now. It's sort of difficult to understand Eclipse's guide because the wording and everything in the eVGA bios is entirely different so can someone explain why this would fix it? I thought hypertransport was linked to memory speeds if they exceed 200mhz not the actually HTT of the CPU.
Anyways I'm at 2695mhz @ 1.47v 245x11 204mhz ram speed.
