v_lestat said:if its a 3200+ which is 2.0ghz 250mhz is the max your gunna get,,, that makes it 2.5ghz not many people go over 2.5ghz with the 3200+
2.5ghz seems to be a limit for alot of the socket 754 chips so dont feel bad. even the some of the 3400+ chips wont go over 2.5ghz.
the socket 939 chips on the other hand they go higher.
but if you dont want the lanparty let me know i might buy it from you hehehe...
My ClawHammer does 2.6GHz at 1.93vcore, so I wouldn't know about thatv_lestat said:if its a 3200+ which is 2.0ghz 250mhz is the max your gunna get,,, that makes it 2.5ghz not many people go over 2.5ghz with the 3200+
Just air for nowCircuitbreaker8 said:^^ Do you have watercooling or vapo? I thought you wernt supposed to go over 1.7v with A64s?
iddqd said:Just air for now. I run it at 1.83 all the time.
v_lestat said:that info is not possible.
if its a 3000+ then
#1 - the mulitplier is infact 9 not 10. or is it 8 ?
#2 - a FSB setting of 250mhz does NOT make 2.5ghz - my 3200+ CG runs 250mhz at 2.5ghz. there for your 3000+ is only running,, what ?? 2.3ghz ??
so recheck which chip you have cuz if its a 10x multiplier then you have a 3200+ not a 3000+
Athlon 64 3000+ @ 2.5ghz w/ an Abit KV8 Pro
1GB Corsair DDR400@DDR420
oh, stupid me, i didn't realize you guys were talking about the chipset voltage.. hehehe. i can't change the chipset voltage, so... i wouldn't knowiddqd said:Yeah, for the chipset!
stelleg151 said:With my chaintech board, I got my winnie running at 2.5, cause its a crappy week 35, and I got my geil ultra pc4000 running at 227 or so, resulting in a 34 second 1m.
winchester(?) week 35 at 2.5Ghz with pc4000mem at 227Mhz. 34 seconds on superpi 1m.stelleg151 said:With my chaintech board, I got my winnie running at 2.5, cause its a crappy week 35, and I got my geil ultra pc4000 running at 227 or so, resulting in a 34 second 1m.
You don't know what you're missing. There's all kinds of fun to be had adjusting VCC from 1.6V all the way to 1.9V.(cf)Eclipse said:oh, stupid me, i didn't realize you guys were talking about the chipset voltage.. hehehe. i can't change the chipset voltage, so... i wouldn't know![]()
Socrilles17 said:Heres an entry
ADA3000DIK4BI
CBBHD 0447UPCW
with epox 9NDA3J
at 2.7 ghz on stock cooling (300*9)
centvalny said:3.42Ghz....3.4 benched
I wont bother with prime95 and alike, since from 3.38 to 3.42Ghz (with 1.75V) range is just for benching and gaming. It also depends on ambient room temp. When its freezin vapo can reached -63C idle with heaters on 30%.Arseface said:Sweet
What clocks do you get Prime95 stable?
I've got a Vapo XEII, and I was thinking about going for an FX55 with it... I was hoping to hit 3.2Ghz stable at a 'sensible' voltage - what do you recon the chances are?
Gskill LEv_lestat said:son of a biscuit!!
not thats a sweet OC!!
what brand and type of ram is holding strong at 298mhz ??
Where were you in the past month or so?v_lestat said:ok in engrish please
centvalny said:I wont bother with prime95 and alike, since from 3.38 to 3.42Ghz (with 1.75V) range is just for benching and gaming. It also depends on ambient room temp. When its freezin vapo can reached -63C idle with heaters on 30%.
3.3Ghz 24/7 and 3.35 to 3.38 depend on what game. Heres the comparison chart....http://www.asetek.com/filarkiv/products/XE2/Performance-Graph.jpgArseface said:What clocks do you usually put it at for gaming etc?
Also, how much difference do you think the Vapochill XEII vs. LS is likely to make?
HybridHB said:Well i just got my new winchester 3200 from newegg today. Its a
CBBHD 0448SPBW
Anyone know what these letters mean?
