Well, it's probably safe to run it at about 1.85..v_lestat said:i HAD a thermaltake or thermalrite whatever its called 948u with thermaltake 80mm fan and my temps never went above 45 loaded.
i now have a water setup using a swiftech MCW5000 and also a mcw50 in the same loop on the video card.
1 heatercore with 1 120mm fan on it. the fan is pretty slow and im not happy with that only 2500rpms so ill have to get a faster fan.
but temps at idle are roughly 28-30 and load max so far that ive noticed is 35 deg. with one day it was pretty warm in here and it got to 38deg.
and no resevois but i ordered one so hopefully ill be able to add that into the loop and get a little more water flowing.. although the heater core is more than enough of a reservios.
And that's exactly why 4000+/fx-55 win at every benchmark except one content creation one(out of several)?v_lestat said:ahh someone else who agrees with my that the pent 4s are faster.
the A64's one and only use is for gaming, everything else,, the intel's kick ass by a large margin. especially in multitasking. and what seems to be memory management.
I've had the same issue in the BIOS with my old Neo Platinum... bios flash fixed it though.Slacky said:I just joined the AMD crowd again. Just bought an Athlon 64 and I am happy with it. I went cheep since this won't be my primary PC, but I am very supprise at how it runs for the money. Right now here is the current setup.
CPU: AMD Athlon 64 3200+ (OEM - 90nm - 939)
Heatsink:Thermaltake A1838
Motherboard: MSI K8N Neo2 Platinum (Running 1.41 Bios)
RAM: 1x512MB PNY PC3200 (Yes, I know I am missing out on the dual banks)
PSU: -off brand- 350W
Overclock:
AMD Athlon 64 - 10*256 with a HT of 4X. - Stock Voltage +3%
Heatsink - Temp stays around low 40C
Ram - Set max speed to 166 - With overclock this runs memory at ~212mhz
Problems found:
Motherboard - Neo2 Plat motherboard has issues setting the HT multiplier. If you hit enter at this prompt you will lock the system. You can bypass this issue by just using the page up/down to change values instead. This was only tested with BIOS versions 1.3, 1.33, and 1.41. (Bios 1.41 seemed a bit better at overclocking than 1.3x versions)
Overall:
I haven't run an AMD since the old 486 systems. I must say that this is a decent chip especially for the money. It is not as fast as my primary system which uses an overclocked P4 3.2ghz chip but I am very happy with it and it stays much cooler than the Prescotts by a wide margin.
Slacky
hehe, i'd suggest you stop talking about things you don't know about.iddqd said:And that's besides the point that most programs can't be effectively split into two threads.
Yes, master. 2.6GHz @ 1.95vcore...Impulse said:I'd rather not have a space heater inside my case but this isn't the thread for the discussion, keep it about A64 OC Data!![]()
Are you running it at 3.5vcore?!centvalny said:Again, bench from this old 3700 http://images.dr3vil.com/uploads/sandracbi.jpg
I ran it with phase changer, no way I can reached it with watercoolingiddqd said:Ohh, 1.8 is more like it!
I should really get myself a 3700+ instead of this 3200+...
dfx said:with good cooling it doesnt matter
according to those experience high vcore guys over @ xtreme.org
A64 OC Datacentvalny said:xp 2800 Tbred B stock at 2.25Ghz-166fsbx13.5 multi. Very rare and overclock very well.
This is on air with NF7S ver2.00 and 2x512 Gskill mem.
http://images.dr3vil.com/uploads/sandracpuid2800.jpg
Oops, sorry guys. I just put up my old athlon. Neo2 is dead.(cf)Eclipse said:*notes that this is the a64 oc'ing thread*
not bad.. just wrong cpu.. hehe, this thread is meant to help people out who can't really figure out how to oc their a64's, not just any athlon.
though on that note, i got some crucial ballistix, and it refuses to run between 212mhz and around 225mhz.
i define an upper limit cause after that it works again. i think my memory controller is messed up![]()
Dephcon said:I think somethings off with my HTT setting.. cpu-z says its 250 and i set it at 800 in my bios? I dunno, i'm new to A64
1000mhz = 5xImpulse said:HTT != HT. The HT you tweaked down to 800 on the BIOS (thru a multiplier, probably using 3 so it's really 750) is the path between the processor and the NB. It's speed doesn't really matter a whole lot as it's very rarely saturated. The FSB is often reffered to as HTT with the A64s, that's what you've got at 250.
