VladDracule
- Feb 5, 2007
yeah i just noticed that lol. is there any solution for sli? for extra cooling or are you gona be stuck with liquid cooling at that point?
Mine runs at 23 C and peaks to 26C
What can I use with vista to check temps on a 8800 series card?
nTune doesnt work with vista correct? Riva tuner?
IDLE it stays 50C
With rthdrible stresstesting its stays constant 66C for half an hour![]()
640 core...still testing !!
Hans.
Ummm, shens. No it does not, unless you are running sub-ambient cooling or live in like, Alaska.
Proof or shens.
you have to do low level system settings, not driver settings. the top half of the rivatuner window. set it to fixed, 80% (or 100%)Guys, I have rivatuner installed, but when I tried setting the fan speeds it made no difference at all. I will give it another try as I never unistalled it.
Hans, how exaclty are you going about testing a stable GPU OC? I know how to test a CPU OC, but how do I make sure my GPU is stable?
sumofaguy - Thank you very much!!!! you have saved me the headache of dealing with Ntune, I did not know about the low level settings, but I did as you instructed now my cards both idle at 41 to 48c depending on my room temps and never go above 68c under load. Now I can uninstall Ntune as it is a big pile of wasted code and garbage.![]()
Here is a link of the picture of my rig that I just finished building with a LianLi V2000 server case.
Thought I would add my bit.
I have an EVGA 8800 GTS. Clocks are 513/1600. Idles at 44 degrees. Load is at 59 degrees. I added a slot fan and the temp did not move. Did I mention it sounds like a jet engine? I've got quite a few fans so there is plenty of air flow. All you need is good air flow. At 535 the core does 47 idle, 61 load. Could probably keep it under 70 if I went up to 600 mhz.
For reference, my old card, a 7900 GT @ 520/1500 ran at 44 idle, 63 load which is actually in RMA for overheating memory. It was one of those bad 7900 GTs from last spring that many of us had to deal with.
Room temp is around 19 degrees. Cpu runs at 35 idle on both cores, 58 load @ 2.6 ghz. I've got one fan blowing in front, one in side, two out back, one slot fan below the video card. The power supply has 2 fans. I also have a couple adjustable fans attacked to the motherboard. One is blowing from the intake in front to the video card.
Well, I decided to take a picture anyways. You can tell I have not been to a LAN party in a long time.
this is lame, I cannot for the life of me get rivatuner to adjust the fan speeds according to core temps, the settings stick but nothing happens!
