- Apr 10, 2005
larkin said:question for someone who knwos about gpu overclocking:
theoretical question
if my 650/2000 in unstable, how do I get it stable and why are some other people stable at that speed and higher with similar cooling?
Let me try to answer my own question and see if i'm right, other cards are stable at that oc and higher because they got lucky, whatever it means to have a lucky chip, they have it (for my benefit i'd like to know exactly what it means to be lucky technically speaking about the hardware difference). How do I make my card stable at 650/2000? Well, xtreme overclockers have shown that these cards have a lot of head room, the limiting factor is temps. So, if you want your card to be stable at a higher OC then figure out a way to keep the temps lower. This could mean mods to the gpu cooling, going water, or simply cooling down other components in the case warming things up.
Missing anything?
First off, check this out: http://www.xtremesystems.org/forums/showthread.php?t=124472
pretty cool, eh? I was wondering about that.. those stream processors have a frequency also.. and they're doing a ton of work.. so getting those OC'd would yield good performance I would imagine
Anyways, some cards are just better OCers than others, but getting your temps down almost always helps a good stable OC... the fav of extreme OCers seems to be cooling the gpu only with water/chilled water, or in some cases phase change or ln (whatever your extreme cooling poison of choice is) then leave the memory and mosfets to be air cooled..(with sinks or sometimes without). . . but full face blocks seem to be doing very well also now days.. EKwaterblocks.com makes a nice one.
personally I am going to put my card on a full face EK block and hope for the best OC without vmodding I can get... these cards are already powerful enough and risking it for 30 more mhz on the core doesn't seem worth it imo... I'll go SLI when I need more power.
