5800X performance for $50 less?! Intel Rocket lake i7 11700K Review
StormNobleheart
I have the Asus Z590 Maximus Hero XIII in my computer currently. I doubt I could sell it for enough to purchase another 570X Strix-E much less a Dark Hero. I have a 10700K already. Unfortunately, I only have about $450 set aside. I really wanted to install the second Samsung 980 Pro I have and run them in RAID 0. I would lose two more SATA ports if I installed it in the third m.2 slot. This would take out my storage drive of three 4TB hard drives in RAID 5. I also really wanted to run the drives at full speed. I had planned on running a medium level overclock with a 280mm AIO cooler. I do not game much anymore. About the only modern game I play is World of Warcraft. I wanted a really badass computer and was looking forward to the release of this CPU. Instead, I got less than mediocre.
chameleoneel
Well then I would suggest selling the 10700k and replacing it with an 11700k or even an 11900f
P.S. its generally not recommend to RAID 0 solid state drives unless you really need the extra throughput. As it lowers the access times, which is what makes an SSD feel so quick for general usage.
seanmcd
I thought you meant you had already pre ordered an 11 series CPU. I'd say buy the 11700k and sell the 10700k, if you are seeking the pcie 4.0 drive benchmarking scores. Otherwise put the money in the sock drawer and wait a little longer and see if prices change a lot or they sneak another CPU into the mix, although you're probably seeing the end of LGA1200 with these.
StormNobleheart
Thanks. I probably will sell the 10700K. That is disappointing to read about SSD's in RAID 0. I have worked on PC's for about 25-years and I still feel like I know next to nothing.
chameleoneel
P.S. I haven't actually tried it myself. It could simply be people whimpering about nanoseconds which don't actually matter. But I usually see discouraging remarks about putting SSD into RAID 0.
*I recently saw a video on Linus Tech Tips for a product which runs a couple of SSD together with a big cache and they couldn't get it to throttle from cache overthrow. Seemed pretty cool.
pendragon1
i ran a couple 60gb ocz v3 ssds in raid 0 for years, no issues and they still test 95%+.
Nasgul
Chapter 1: Nasgul finds out about multi-quote
Chapter 2: The disappointment of Nasgul
Chapter 3: ?
Honestly, I miss a higher quality troll. Idiotincharge might have been an actual idiot, but he did it with style.
no-no-no!
Chapter 1: TuboGLH waste times
Chapter 2: TuboGLH needs a life
Chapter 3: TuboGLH looks in the mirror and sees failure.
Nothing like an old man who has wasted his time.......so, talk about idiocy, takes one to know another. Wasting time in style. My superfan......
Nasgul
Actually when everyone else was bashing Intel, GN still gave the 9900k best overall CPU award so hardly a biased channel but when something is bad is just bad. People need to accept that and not try to blame on bias.
Not really, you have to read between the lines of the comments in the video. But it's obvious, it's all for views and likes as it was before.........before the 14-16 year blackout.
Nasgul
You screwed it up - make sure you quote me accurately!
I got rid of the useless part of the comment, because it was over by 34 characters, that's why I had to edit the comment. It would've been nice if all characters were allowed but it doesn't.
I tried to see that GN video, but it's the same old same old, this guy complaints as if he'd know more than the Intel motherboard manufacturers and their engineers.
Whisky Tango Foxtrot!
I am really, really regretting my purchase now. I am regretting giving that Asus 570X Strix-E to my nephew when I could not get a 5000 series Ryzen more so. I was just going to get the 11700K anyway because I have a nice Z590 board in hopes that it was close enough to the 5800X to warrant the $400 price. Now, I am contemplating stripping the GPU, PSU, sound card and just dropping the rest of the system into the dumpster. I am that disappointed with the product and THAT disgusted with myself.
I wouldn't pay attention to any of those videos. When GN makes case reviews? The guy is really ignorant, Hardware Canucks is good for that, and whenever GN makes reviews for PSU? They hook them to these machines as if a home user will ever want to know the exact hairline detail of how a PSU handles wattage. Johnny Guru probably laughs at those reviews.
The motherboards can, CAN be adjusted manually in the BIOS OR software if you want to adjust the voltages, yes, by default, as per a manufacturer, the performance will vary, and funny that he has an ASUS box in the front when ASUS is the and my #1 choice for Intel motherboards. But also Intel systems are the most reliable and stable. I wouldn't want to get a system with a plethora of issues. Got my STRIX-E and the 10700KF and I'm actually bored now, no issues to report, not even the i225-V LAN controller which it took about a min to download and update the firmware and drivers but it was made out to be a major issue.
Get a 10700K for $319, better than a 5 series 6 core for $349. And the 10700K easily does 5.0GHz. If you're close to a Microcenter, the 10700K is only $249.99.
seanmcd
You completely change the context by changing what you changed, not sure you actually get it.
chameleoneel
I am a professional! Even I don't care about an extra 12 seconds of time though.
GN put a good context on such a thing, though. When you are doing actual professional type work, it can take a really long time to finish a final render on a video. And those 12 seconds can add up a lot, over time. I think the example he gave is their GN animation, which takes roughly 60 seconds per frame, to render.
Makaveli@BETA
That video is misleading.
Yes the 5800X runs abit hotter than the rest in the stack enough to avoid it no.
Is the next video going to be well you shouldn't run AVX 512 work loads on Rocket lake because you know it pulls close to 300 watts.
noko
Personally I would buy a 10850K for a new build vice 11700K, about same game performance, better productivity performance over the AMD 5800x and 11700k. Still wondering about the actual street price for the 11700K. Rocket lake has another limitation, max of 8 cores. If one bought AMD 6 core, you have options where you could get up to 16 cores later (as in when they are dirt cheap in 3 years or so) extending usefulness of a build. When one has multiple rigs, Daisey chaining upgrades is very cost effective, upgrade one, upgrade all. Intel has never worked out well for me in that regards, buy CPU and motherboard, stuck with same CPU in same motherboard as new CPUs are released. Is Z590 and Rocket Lake another dead end platform?
chameleoneel
Personally I would buy a 10850K.....better productivity performance over the AMD 5800x and 11700k..
Not exactly true. AMD's CPU's beat an Intel with two more cores, in most instances being tested in reviews. There are a couple where Intel has a small win. But it seems for most things, AMD's 8 cores beat Intel's 10 cores when actually using your PC for work.
LGabrielPhoto
LOL between the lines? I was a 9900k owner and when he did the awards and gave it best overall, I agreed with all he said about the processor. He picked it as BEST overall, nothing to read between the lines. Unfortunately, you seem to be determined to find a reason for Steve's evaluation of the 11700k other than the fact that the processor is simply a lackluster product.
There is for sure a lot of Anti Intel stuff around, a lot of it now well deserved, but GN is surely one of the few that gives it to you straight. Some people just don't like to hear the truth.
StormNobleheart
I already have a 10700K and a Z590 motherboard. I already have an 11700K on pre-order (begrudgingly) so I can actually use the features of said motherboard. I thought the particular board I wanted would sale-out for a very long time like the 570X Dark Hero and 570X Strix-E did. Instead, the Z570 Maximus Hero XIII remained readily available at MSRP. I wanted to add a second m.2 drive without losing the RAID 5 setup as well as run the SSD at full speed. I learned not to pre-order a motherboard and CPU ever again, even if it means waiting several months to a year for them to become readily available near MSRP. This entire experience has left me soured and very resentful. So resentful, that I am still considering selling off ALL of my computer hardware, save for the laptop and Teac dual floppy drive.
I must have missed something along the way. What are you so upset about? Youve got a solid rig as is. What do you do that it fails at?
Right now is the perfect time to sell your mb. MC has nothing z590 high end in stock. Cancel your pre order and go with the mb cpu combo you are pining for...wheres the problem?
chithanh
Case in point, here is Puget Systems' comparison of AMD and Intel CPUs in productivity:
https://www.pugetsystems.com/labs/articles/AMD-Ryzen-5000-Series-CPU-Review-Roundup-1962/
The 5800X beats the 10900K in the vast majority of benchmarks, and loses only in a few highly parallel rendering tests (and by only a small amount).
Factoring in the Z-series mobo and serious cooling that you need for the Intel CPU, it will have to be more than $100 cheaper than the 5800X to make up for the platform cost.
NightReaver
I think he's just very disappointed in early RKL reviews, but that's the only way he's gonna get to use the full feature set of his mobo. Tomorrow should be fun.
chameleoneel
Nah he's got a pretty valid thing in that with 500 series chipsets, one of the NVME slots is unusable for Comet Lake. Which wasn't made clear until about two weeks ago, when mobo vendors finally updated the wording in their features pages. Well after some 500 series boards had released. Its pretty annoying. Especially if you have a board with only 2 slots.
I also found that out the hard way. However, I don't really need both slots. and I was otherwise taking advantage of the RAM overclocking on H570 for non-K cpus. So I'm ok with it. But still a poor showing from Intel on getting clear messaging across on forward and backward compatibility.
NightReaver
Oh wow, didn't know that. What a mess.
StormNobleheart
I did not know about the first m.2 slot not functioning with Comet Lake until I received the board and read the manual. If I use m.2 slots two or three, it disables things I need, such as SATA ports for the hard drive raid and the optical drive. I am stuck with only m.2 slot four at the moment. I was not expecting Rocket Lake to blow everything away. I was expecting about a 1% to 5% increase in speed compared to the Ryzen 5800X with early leaks and estimated IPC uplift. I certainly was not expecting the 10700K to beat the 11700K. The power consumption and Apple's first CPU beating it really rubbed salt into the wound. I had thought about selling the board and just buying an X570 Dark Hero/Strix-E (good luck finding either at a reasonable price) and a Ryzen 5800X until I realized the cost. After fees and shipping, I may bring in $300 for the Z590 motherboard. I said screw it, it cannot be that bad of a CPU. Then all of this news started trickling out in the past week. Yes, I am very salty. A couple shakes worth with Intel and a dump truck's worth with myself.
OrangeKhrush
so ummm the 11900k was barely faster than the 5800X when cl9cked to the moon. it's a disaster let's call it that. hot and slow is the common theme
Nasgul
And too bad amd can't overclock. Needless to say, it throttles when reaching steady high temps.
LGabrielPhoto
LOL You do know about PBO+CO, right?
With that style of OCIng it still beats anything Intel so not sure what your point is other than "brand loyalty".
Quick run of CB 20 just for a reference. Can Intel do that without burning the house down? 😁
johnrea77
My good old i7-7700K is 14nm process just like the new i7-11700K. With the i7-7700K running stable at 4.8 Ghz for almost four years I see no justification to invest in a new CPU at this time. I did have the i7-11700K in my NE cart, but pulled it out once I realized what I wouldn't be gaining.
seanmcd
this 11900k must suck as bad as the 5900x because I can't find one in stock anywhere
kalston
Is that a US thing? There's virtually unlimited stock in Europe since launch, it's like Rocket Lake isn't selling at all (and nor should it - I say that while running a 11900k myself). It's also a ridiculous 200€ higher than the 10900k. But I have not seen the lower end SKUs going out of stock either so far.
Totally unlike AMD 5900/5950 that is practically impossible to buy "normally" since launch (or the last gen of GPUs by nvidia/AMD - same madness). 5600/5800 also had a rough start but they have been readily available for some months now.
seanmcd
I see it at mindfactory for the equivalent of $770 which is ridiculous (wtf). Otherwise it doesn't seem like it's "virtually unlimited"...
NightReaver
My local MC still has 5 in stock at $700 each. I have a feeling those are going to stick around unless someone reeeeally needs to show off the latest Intel 'flagship'.
kirbyrj
I mean there were still people who bought the FX 9590 for outrageous amounts of money, outrageous power draw, and mediocre performance compared to the competition, so I'm sure someone with more money than brains will pick it up. A fool and his money are soon parted...
seanmcd
I didn't know MC joined in on the price gouging. Not going to pay over retail for a cpu, in any situation :)
NightReaver
I agree on that. The 9590 was a meme, but at least it can be used to dismiss the "but muh 5ghz" that some cling to.
Freq only matters if there is IPC to back it up.
On that note, at least the 11900k is pretty fast for all that wattage it gorges on. It's mainly the price that defeats it.
noko
Wow! Your right. Seeing a more comprehensive suite of tests definitely shows AMD strengths here. It is not as if Intel is in left field like Bulldozer was in the past compared to Intel. Unless one can get the Intel system at a significant lower cost, AMD just seems like a better performing buy.
Nasgul
Why not just get an i3 then? 4.8 is the stock, mine runs at 5.0GHz with a Dark Rock Pro 4 and soon will replace the thermal paste and I'm gonna try 5.1-5.2GHz. But praising a CPU for running stock? Non-sense.
Gabriel, CB20 is not an "overclocking" benchmark. It's for core efficiency, frequency, and counts.
LOL, you didn't know that, right?
And hopefully, you know this: Gaming vs server CPU are not the same. 3.7GHz is not the same as 4.9GHz. 2014-2017 is not the same as 2020. (y)
Just making sure you don't compare Xeon vs 5950.
Loyalty? You're so short on that, it's also "preference", "trust", "confidence" and much more. Not a fan of figuring out why my newly build PC is having "issues", just that.
LGabrielPhoto
WHAT are you even talking about?????
Again WHAT ARE YOU TAKING ABOUT????
Whatever you say...I can see your kind. Ignored.
