I got P9316 with a 2600k @ 4.5 and 2 6950s with shaders unlocked and core clocks at 840 memory at 1300.
http://3dmark.com/3dm11/418676
That's considerably higher than I got with two 6970s and an i5 @4.1. Are those 6950s unlocked/overclocked?
P5,553 Single 6950 unlocked @900/1400
http://3dmark.com/3dm11/377963
P10,222 2x 6950's unlocked @950/1450
http://3dmark.com/3dm11/419585
Pardon my newbness and a bit of off topicness. Can you please point me in the direction of how you are overclocking the 6950s past 840? Or are you using a 6970 bios?
P4929
Q6600 @ 3.3GHz
MSI 6950 unlocked to 6970 @ 950 x 1401
I'm using Afterburner to OC the card and 950MHz is the max on that slider. The latest version still isn't out, so I don't know if they will allow for higher OC on the core and will provide voltage adjustments, but I've made it this far with nothing more than the BIOS flash.
I'm pretty sure my numbers are being held back by my CPU.
To the guys getting low scores, make sure that you shut down any unnecessary processes/services prior to starting your run.
With latest driver 266.58. GTX 570@915/200 and i5 760@3.5
Extreme 2018- http://3dmark.com/3dm11/451852
Performance 5784- http://3dmark.com/3dm11/451927
See this thread: http://hardforum.com/showthread.php?t=1577774
Oh hell yes! Much appreciated!
Gahhhhhh! I just downloaded and tried and it says the program is the wrong version for my Windows. I'm running Vista 64-bit, so I'm thinking this is only compatible with 32-bit versions?
OK, downloaded from a different source, and the file now installs. I do get voltage control, but do you have any idea if they are going to make it so the core clock slider goes past 950MHz? I've already reached that (the max supported) and may only need the voltage support if I can get more OC headroom. Oh well, this is still better, and I'll just have to wait and see what happens.
Have you enabled unofficial overclocking in Afterburner?
I haven't, but I also don't see anything that offers that. Any idea where I could find that item?
Here's a small guide on how to enable unofficial OCing in Afterburner.
http://www.overclock.net/ati/641299-guide-enabling-unofficial-overclocking-msi-afterburner.html
My score seems extremely low. I get 3860 on the computer in my signature.
What should a 470 GTX score on average?
Back to the land of totally abuse 3dmark scores for geforce owners I see
Someone should make a bias free synthetic one of these days!
