m1 grant said:I believe I've fixed the problem with the Blue tint
However I still thing that the monitor is a lil dark, but turning up brightness or gamma turns the screen very white
SJetski71 said:Dude make sure that the last time you use windex on that screen. Most crt screens have a coating that gets streaked/ruined if you use the wrong cleaning solutions. My old 17" crt was ruined by windex![]()
gr33dy said:mathesar,
I know this thread is about the FW900, but I had another question about your G520P. I know it takes about 10 min. from power-on for the black levels on the 520 to get really black. I was wondering if you noticed this occurence when you first purchased it brand new.
Thanks.
Yes, I did when I went to pick mine up. He said they buy them from businesses that are closing. I guess they got lots of them from one particular large company that went under.seniorpaul said:Well, i'm thinking about getting one of these CRTs now. Just out of curiosity, did anyone ask the ebayer where he got 100's of these monitors from?
[CaM]Spoon said:I never knew sony makes crts anymore!? espically a widescreen! WOW im so in there!
How deep is this thing? just wondering if it will fit on my desk. I used to have a 21" HP CRT and loved it but died on me. Now im using a 21" Lcd and its not the same! Im really dieing to get a widescreen and whats better then CRT widescreen! AOAHAAHA
So glad i found this furom.
Anyone know where else i can buy it.. I really want the grey casing but the one on ebay is KILLED! plus if you looks closely the windows bar is burned in on the screen.
m1 grant said:my monitor still looks a lil dim im @ default vid card settings, my color temp is on easy 8700K and my Bright is ~30 and my contrast is around 85. Do u think I should talk to lou about a replacement?
m1 grant said:as I said the tint wasnt a problem anyomre, I think the tint is very close, but the brightness of the monitor @ 7200K (sry got the wrong color temp earlier) was way too dim and im wonderin if its the age of the monitor or my calibration, or if maybe im not used to the dimmer characteristics of a monitor, being that I just came from an lcd
The monitors are essentially identical in specs and capabilities and both are made by Sony. The one with the HP badge is white. The Sony badged one is silver and black. He has seperate auctions for each (and the Sony is $75 more).[CaM]Spoon said:so which color version we get? Silver or white?
Wonder if i should take a risk on this. Dont trust buying big things like this over ebay. I really want the silverone and willing to pay more for good condition... Cant really trust what condition im getting of ebay. ah man
synergyo1 said:^^^ I think its equivalent to a 19in 4:3 monitor.
northrop said:The only thing that scares me is 20 depth dimension. Where can I find a good desk for it, because my current desk sure as hell wont work. (L-shape desks preferably.)
northrop said:This monitor is so hot. I may get it next month if I decide to upgrade my rig.
zandor said:That's why you've got the blue thing going on. Those high color temp settings aren't really much good. The main reason so many monitors (and TVs) come set that way is that they look comparatively brighter when they're sitting on a shelf in a store.
I might have these backwards, but if I remember right 6500K approximates indoor lighting and 5500K is more like sunlight. 6500K is usually the recommended setting. It'll look red at first, but you'll get used to it quite quickly.
The first thing I'd try is the sRGB setting. It's basically a best guess at correct color. To really get it right it'd have to be calibrated, and you'd need software & test equipment for that. Graphics shops calibrate thier screens of course, but I've been quite happy with sRGB so far. If you don't like the sRGB setting after a day or two, put it on 6500K and start playing with it. It'll be quite a noticeable change from 8700K, so give yourself a while to get used to it. I'd also recommend looking at some photos, as it's easier to judge color settings with pictures than something like the Windows desktop. You get used to the desktop being a certain color, and any change looks wierd. Pictures, particularly quality ones prepared by someone who really know what they're doing, will usually look better immediately.
Lazlo said:Im considering ordering one of these. I'm still using an ADI Microscan 5P (Since 1998) and was considering a 2504fpw. After seeing pictures of this monitor though... well, consider me sold. I am however a bit worried about it's lifespan.Has anyone asked about how much the extra warranty is?
synergyo1 said:The guy ships to Canada.
synergyo1 said:I only see two ebay listings of Lou's.. his sony and HP one... both say shipping to US and Canada only.
But yea.. call and make sure before purchasing.
*** SHIPPING IS ONLY TO A US ADDRESS ***
NO INTERNATIONAL SHIPPING
