ok, so the ones that look like this are the one to ask for?
http://xs49.xs.to/pics/05406/NewRam1.JPG
LawGiver said:ok, so the ones that look like this are the one to ask for?
What chipset / motherboard you running?bAcKpAiN said:I just received my "uglies" and all seems well so far at 200Mhz 3-3-3-8 Tiimings 2.6 volts. That's where the gig of corsair value ram was set. All seems well and I will post a screenie once I get it hosted. So as of now I am successfully running 2 Gigs!
Pete84 said:What chipset / motherboard you running?
bAcKpAiN said:I run a DFI LanParty UT NF3 250 GB with a 3200+ DTR. Right now I am running memtest @ 230 x 10 3-4-4-8 timings. *fingers crossed*
yeesh said:Has anyone else had my poblem? It sounds like they're either working or not working for everyone, but each of my uglies works fine by itself, only failing to work as a pair. I'm pretty sure my motherboard doesn't even support dual channel (unless gigabyte is keeping it hush hush), so I don't think that's the problem.
I bought myself a pair of these sticks, hungry for 2GB of RAM. I recieved a pair of the shorter sticks, with chips that say:
ADVANCE
MODULES
AMB0B1E (maybe, very hard to make out)
128M x 4 DDR
DBBU (maybe)
Anywho, just like Rev I have a Gigabyte K8NS NForce3 250 (A2). I'm running a humble Athlon64 3000+. While either one of the new sticks by itself is happily recognized as 1GB and runs just fine @ 400Mhz, unfortunately if I put both sticks in my machine will not even POST. Beep beep beep, that's all it's good for. I've tried every possible combination of the three memory slots, and I've tried upping the voltage on the RAM. Neither of those bore fruit, and I'm too simple to figure out anything else to try. Does anyone have any ideas about what I am missing? Or am I just stuck at 1GB forever? TIA
Nice !!!Rev. said:
Pete84 said:Nice !!!
Via P4PB 400-FL P4 board
Gigabyte 7VAXP-Ultra sA
VNF3-250 s754
MSI Neo3-F s754 nF4
kt600 (not Asus) sA
Abit AN8 SLI nforce 4 s939
a8v-deluxe (bios 1014F) s939
ECS \
MSI |> NF 4s s939
DFI /
Asus
jetway nforce4
DFI lanparty ultra D (bios 618-03) s939
via kt800pro sA
ECS a754 nf4 s754
Gigabyte 7va sA (?)
DFI-ultra D
Nf4-Asus s939
ECS 754nf4 s754
A8V-deluxe KT800pro
Asus A8n-sli deluxe-nf4 s939
KT880 Socket A sA
Asus K8V SE Deluxe (VIA K8T800)
Gigabyte k8ns -- in dual channel s939
Asus A8V deluxe -- with 64 X2 s939
A7N8X (nforce2 chipset) sA
DFI UltraD SLI
MSI K8N Neo Platinum
Asus K8V SE Deluxe
cybpsych said:oakfan52, save ur money bro, these modules won't run on any Intel-chipset based boards.
NF4 for AMD should work fine, but NF4-Intel Edition won't work
I have a geforce 6100-m7 which is the little sister of the board you have (using the c51 410 mcp and can use the same BIOS). I just ordered two sticks so I'll let you know next week when they get here. This might encourage you as well, Biostar-usa was clueless about the ram support but Biostar Taiwain wrote me back and confirmed the new tforce geforce 6100/6150 will work with high density ram :gotkilled said:what about t-force motherboards with the nforce 430 mcp?
They also released a new bios specifically for additional memory support a couple days ago:2005/10/26 04:53 Customer Issue Form
Issue_list=Has the Tforce series been tested with high density ram 1GB (128x4)
Date: Thu, 27 Oct 2005 11:43:16 +0800
Yes, TForce6100 will support high density memory module.
with best regards
Steven
Biostar FAE
You probably should mention that is "ULi 1695 Chipset" right?[N]ex said:Just a fyi in regards to compatibility. These sticks (picture originally supplied by cyberdiety)
Work fine and are recognized as 2x1GB on my Asrock K7S8XE+. However, on my Asrock 939 Dual-Sata II they fail to work as anything else than 2x512MB. They do work fine at 2x512 MB 3-3-3-8 2T dual channel though.
Starfox said:Does anyone have a link to the current auction?
Exactly. Hence my four emails to him before the purchase to make sure the Advance were available and that he could specifically send me those. I fell for it. Now I get told "oh it's an automated system".bAcKpAiN said:Also if that is indeed the case where [N]ex got the non-uglies to work as a gig it is a first in 20+ pages to do so. Everyone has had problems with those regardless of the chipset.
gotkilled said:DOH! So it doesn't work with the Geforce 6100?
vibe said:There is only one type you want. It's the advance modules chips.
They work better possibly because they copy the Samsung SPD info onto them.
The PROBLEM is getting them to ship these kinds of dimms to you.
I wrote them four emails before I bought, got positive confirmation they had those kinds of dimms still and that they would ship them upon request. I followed their instructions and put the notice into my PayPal note. Then I followed up another email within 30 minutes after the purchase and got another positive confirmation.
One week later I got the package. They were NOT advance modules.
I wrote them to ask why and was told "the process is automated".
Then I wrote back and asked why they didn't tell me from the start they couldn't promise me any particular kind of dimms and they replied that "oh we thought you meant pc2700 vs pc3200".
Needless to say, I was like WTF.
Trust me, I could not have been more clear or more careful about my purchase.
If anyone is crazy enough to still attempt to order, I'd strongly suggest that you 1. not be in any kind of a hurry (like a month or more to get it right) 2. not be bothered if you have $117 or more tied up with nothing to show for it
