Yeah there is some fresh air coming over the card but is kind of blocked by my hard drive. And there isn't really anywhere I can put it in my case that wouldn't block the air. The load temp is still better than what I was getting. I might try re-applying as5 and see if I can get the temps down a little. As far as overclocks go I am still messing around with those. I had the card @ stock with the stock cooler but I plan to take the card to 6800U levels now.Mister E said:Nice line-up there Viper. That load temp seems a little high though. You got fresh air coming into the case over the card? If not that may help. And did it improve your o/c's any?
K, I will make sure to dump the whole bottle on the card I will post new temps when I re-seat.Mister E said:Hard drives do not need direct ventilation. But you always need some sort of airflow so that temps wont soar. So yeah move that baby so your card can breathe. Also that 70% ISO will work fine to clean your core. Just dont splash it all over.
v1p3r-386- said:K, I will make sure to dump the whole bottle on the card I will post new temps when I re-seat.
cambrian said:don't take this the wrong way amadeus but your wife is very pretty. Bears striking resemblance to Scarlett Johansson.
....and a long and awkward pause later....
Ahhemm....and yeah also very nice job on the zalman.
To test I useamadeus00 said:LOL, thank for the compliment. She gets that A LOT!
One of them is my wife
.....ummmm what were we talking about?
Oh yeah.....Zalmans VF-700Cu. Here is an update. After the mirror finish lapping, the temps did drop 1 degree. Still getting about 78 load / 51idle. What are you guys running to get the test the rig? I am using 3d05 setting it on 10x repeat on Game Test 1 at 1280x1024x32 4AA 8AF. If I run HF2 or Doom3, I don't nearly get as hot. Maybe 73-74 load.
v1p3r-386- said:To test I use
RTHDRIBL
Run it in a window and you can look at your temps while running it. amadeus00 did you apply as5 by putting a drop in the middle and putting the fan on and twisting. Because that dropped my temps from 76c load to like 59c @ stock speeds.
The second pic is Scarlett Johansson. Hot cute.Mister E said:wow amadeus00! she is gorgeous in that pict. treasure her!! lucky dog you.
Talk about a nice thread to wake up to on a Monda morning.amadeus00 said:LOL, thank for the compliment. She gets that A LOT!
I would like to know this too.[H]ard On said:Has anyone tried one of these on a 7800GT yet? Have they been reported to fit?
Hmm, I just go into the nvidia control panel thing to look at temps.amadeus00 said:Ok, I asked this question in another thread and got zero replies. I'll tryi it in here.
I was bit concerned why my overclocked 6800GT (425/1100) was getting temps like 78C/51C load and 61C/40C idle. I have a Zalman VF-700Cu mirror polished and applied with AS5. I know these aren't bad temps but they are not great either. I usually monitor my temps with RivaTuner and SpeedFan at the same time but yesterday, I forgot to load RivaTuner and SpeedFan picked up two additional temperature reading. Doing a little research, I found out these were MAX6648 readings. It means these are temperatures from the Nvidia board. It has been reported that these reading are 10C lower on the core temperature because Nvidia puts an additional 10C as a safety factor. It made me wonder what program are you guys reporting temps under? SpeedFan or RivaTuner?
