Nice, uhmm wat's the temp on ur cpu and that x850xt gpu?Riptide_NVN said:
BigDaddy85 said:Nice, uhmm wat's the temp on ur cpu and that x850xt gpu?
As someone mentioned the AV8 has problems with temp reporting. Not every board does this for some reason but I've had two and they were/are both screwed up. GPU load temp is 60-62c and idle temps are 37-38c. Room temperature of 78 fahrenheit.BigDaddy85 said:Nice, uhmm wat's the temp on ur cpu and that x850xt gpu?
I agree. Thats one big plus to the two slot cards as far as I'm concerned.DarkBahamut said:After setting it to 100% fan speed it matched the Zalman temps AND it had the added extra of exhausting hot air out the case, and i dont care how good your case cooling is, a direct exhaust is better than none, no matter what .
Riptide_NVN said:Get some copper OCZ ramsinks. Those things rock.
The arctic silver adhesive is good, but you should mix it with some regular AS5, because if you use 100% adhesive (as I did on my 8500 back in the day) you will NEVER, and I mean NEVER get the sucker off. My TT Crystal Orb is basically dying on the 8500 (sounds like a saw), and if I try anything else to get it off, I'm gonna pull the GPU right off the PCB.dekard said:I'm having a problem with mine, the ram cooling chips keep falling off. Obviously I didn't clean them well enough, but Shesh!
Any ideas to get them to stick? I'm about to buy some more thermal tape or that glue stuff. Which do you guys think is better?
jebo_4jc said:The arctic silver adhesive is good, but you should mix it with some regular AS5, because if you use 100% adhesive (as I did on my 8500 back in the day) you will NEVER, and I mean NEVER get the sucker off. My TT Crystal Orb is basically dying on the 8500 (sounds like a saw), and if I try anything else to get it off, I'm gonna pull the GPU right off the PCB.
Less than 50% AS. 60/40 or 70/30 should be good, depending on how heavy the ramsinks are.dekard said:what ratio should i mix the two products? 50% \ 50%
its the little zakman aluminum ram sinks you see in all the pictures in this thread. they weigh almost nothing, maybe as much as a dime.. i'll probably go 70\30..jebo_4jc said:Less than 50% AS. 60/40 or 70/30 should be good, depending on how heavy the ramsinks are.
well i have seen another reviewer or owner had 8 ocz copper bga on their ram and zalman VF700-cu on the core. cools great uhmm man i don't want to look for it. try google it and u will kno wat i am talkin bout.LstOfTheBrunnenG said:GTX compatibility for this thing? Anyone?
YOHAN14344 said:
Mr. K6 said:If you want to get the thermal adhesive off, you can if you soak it in 91%+ isoprophyl alcohol and use a razor blade, but it takes alot of soaking to eat through the bond. On your memory chips dont us AS5 at all, its not made for them and does shit for them; you'll use a ton just for those 8 chips. Thermal tape works well and so do thermal pads with adhesives in the corner. If you must use AS5, then use a bit of adhesive in two opposite corners and use the AS5 in the middle, Don't mix the two, it just gives a poor result.
