TraptPatriot
- Jan 3, 2011
Recently I came into possession of an MSI 780ti. The PCB is the Nvidia reference layout, so any waterblock for a 780ti reference will fit.
Since I have a custom water loop, I spent a lot of time researching what block to use. I originally wanted the EK acetal with the backplate, but FCPU was all out of backplates. So I saw they also offered the XSPC Razor full cover and the backplate, both in stock.
I went on the XSPC website to verify that this waterblock would fit my card, and for the GTX TITAN/780/780ti waterblock, the MSI card is listed as compatible. Great, so I order both the card and the backplate from FCPU.
Both of them arrived 4/4/14, and tonight I finally received all the parts I needed to upgrade my PC. Got the fan and heatsink off the board, got the waterblock prepared, and go to test fit before putting thermal grease/pads. What, the waterblock will not fit? While studying the waterblock, there was one part that stood out right away, one of the silver and blue cylinders (no idea what they are really called) sticks out of the line of them, and the waterblock cover only has room for the single line. Also, the power connectors hit the edge of the acrylic cover, thus making another spot that won't allow it to fit.
I start doing research again, and turns out EK full cover blocks compensated for both of these issues on the 780ti boards, and which is why their 780 blocks do not have the changes. So XSPC is selling waterblocks listed that will fit 780ti reference boards but they in fact will not.
Talk about a hassle, I am out of money, out of a usable waterblock, and my PC will be down for a while. Sure, I could take my dremel and grind those sections out, but I do not feel I should have to, as I bought something that was listed as compatible.
/endrant
*UPDATE* Called FCPU this morning, and they asked me to take pictures and they will review them and get in contact with XSPC to see if they can get this resolved. Not really thrilled with having to wait for something that I should not have had to deal with anyway. But, at least FCPU is looking into it.
/endrant
