Will gtx 580 work with my CPU?
I got intel Core i7-920 2.67, I dont overclock, and Im planning on getting the gtx 580, will the CPU be a bottleneck? I'm doing this for BFBC2 and Crysis 2.
Depends on the game and screen resolution. Given your sig lists a 1600x1050 panel, I'd say, even a HD6870 would be a bit CPU limited on that panel, in the only two games that come to my addled mind right now (Black Ops and Starcraft2).
in the near future, the resolution will be 1080p. The only games i play are BFBC2 and starcraft 2. But Crysis 2 seems like a game I would be interested in.
Move BCLK up slightly. I'd recommend moving to max stock volts (1.25, iric) and pushing the BCLK up until it reaches 3GHz. Then just leave it alone until you think you know more. If your RAM isn't 1600 or faster, lower the RAM divider/ratio down from the defaul 2:8/2:10 (or whatever it is) to something lower. To be honest, 1600x1050 and even 1920x1080 are heavily CPU limited by a GTX580. SC2 is almost all CPU, at least according to techspot's review of it. :p
I dont understand what is BCLK? And this sounds complicated, how would i know what i did was right and reliable? And temp wise, it will increase it right? I use the fan that came with the cpu and my case isnt overclock friendly. SC2 runs fine now with the gtx 260, but i didnt Fraps it and never played singleplayer to find out. Im worried though when i move to 1920x1080, that will probably slow down fps, im hoping a gtx 580 or 570 will fix that. BFBC2, i run it on high settings but no HBAO.
Baseclock, and yeah, it will increase temps. The GTX580 will make sure your graphics will never be GPU limited for a while :D
You overclocked the 920 to 3.0 before? What was the temp difference if you can remember? yeah the gtx 580 should be great, just dont want to waste money on it and not notice any fps difference in the end. I wonder what BF3 will require, it could get released this year.
There is no way a gtx 580 would get 'no fps difference' from a gtx 260 with a i7 920 at stock.
The temp difference is very small if you do a mild OC. The stock 1366 cooler is pretty good.
An i7 920 is fast enough not to cause much of a bottleneck for games. Yes, the GTX580 may be held back a bit, but only at resolutions where a GTX580 is total overkill. You'll never really find a stock i7 causing you performance issues in games. Yet.
http://www.techspot.com/review/305-starcraft2-performance/page13.html <-- i7 920 at stock has the avg FPS equivilent to the min FPS of an i7 920 @ 3.7GHz.
My i7 at 3.6GHz can drive my weensy HD4350 at 1080p in SC2 at 25FPS average through a 1v1 :D (min gfx settings, ultra textures. Max CPU settings [reflections, physics, etc]).
See the top quote? It disproves your opinion with facts.
Starcraft 2's an utter dog on my system on Ultra, and on anyone else's system I know for that matter. Since it looks almost no better than 'High' I wrote it off as a bug.
Probably because you have quadfire... turn it off and see how it runs. Ultra is fine on my system with xfire off. Xfire on has some bugs.
I overclocked my i7 920 to 3.2GHz on stock volts, stock cooler, in a normal midtower case where I forgot to plug a fan in the back vent. It was fine.
Im not planning to overclock anything but my bios says it can do it automatically, i wonder if thats wise?
A i7 920 will do 3.4 to 3.6+ with no adjustments other than the clock. It will remain cool even with stock cooling. After that all bets are off.
wow it can reach 3.4 with no adjustments? how reliable is that? last time i attempted to overclock with my old mobo things became unstable and refused to post.
Things are much easier now.
You should be to take just change your BLCK to 155 and that is it and check. temps and stability. If it is fine go to 160 and repeat. That should get you quite a bit more performance. Mine makes it to 171 BLCK before I have to begin to touch any other setting, those will be different with each setup. The point is you can speed up the BLCK to about 160 without any worries and it should work fine. Try it, you won't hurt anything. If it does fail make note of the error code on the blue screen. This help to understand why it failed.
seriously man, just read up a tad and ask for advice to help walk you through the process on here. It is so easy to overclock its absurd to not try really. Free processing power.
sounds risky. why would manufacturers leave it at stock when they could go higher? And every time i increase the BLCK I gotta increase the voltage right? The closet thing i done to this was lower the voltage for the graphics card because at stock it was unstable, do i do the same for cpu?
years ago i used to read that tweakguides.com thing and if i remember correctly, he wasnt a fan of overclocking so thats why i never really felt i should try it.
Because honestly there was no reason to push the clocks on a i7 920 when they came out. 2.67 ghz was so ridiculously easy for the chips to hit, and it was still faster than anything AMD had.
The whole "why would manufacturers leave it at stock when they could go higher?" is a loaded question.
Short Answer: They offer the same part at various clock speeds in order to hit various price points. It was also all they needed to eclipse the Core 2's performance and to out perform everything AMD had at the time.
Long Answer: One thing you need to understand is that a Core i7 965 Extreme Edition is physically the same processor as a Core i7 920. They have the same transistor count, the same die, same pin count, same amount of cache, processor cores, as well as the same number of QPI links. Making processors is a lot like baking cookies. You use the same ingredients, the same recipe and each time you make a batch of cookies they come out similarly, but slightly different. This is true from cookie to cookie and it's the same with batches. They'll be similar and even taste the same but they aren't 100% identical. Processors are the same way. However instead of a different number of chocolate chips or slightly different texturing, or size, CPUs have slightly variable thermal and clock speed characteristics.
After they are "completed" processors will be function checked and they'll be tested for errors. Assuming there are no errors and everything functions the way it was designed to they'll be validated for the next phase. Thermal, power and clock speed tests. (Actually the precise order of testing is unknown as Intel's manufacturing techniques are a closely guarded secret. I'm speaking in general terms here.) Anyway at some point they'll run the chip and determine it's maximum safe clock speed, TDP, etc. It varies slightly from CPU to CPU but so long as it falls within a certain range, it will pass validation to be sold. Now, some CPUs will clock to 4.4GHz or whatever while others may only validate at 3.2GHz or 3.8GHz. Depending on the combination of clocks, voltages, and thermal envelope, it will be sorted or binned according to quality. The best chips are binned as potential Core i7 965 Extreme Editions or at this point, Core i7 960's. Others will be binned as Core i7 930's or 950's. Intel is really good at making these things. They are generally second to none in terms of manufacturing quality. Therefore they rarely screw up and most of the Core i7's can do upwards of 3.6GHz or more under the right circumstances.
One other aspect of binning becomes "binning to fill orders." Say Intel makes 300 CPUs. 200 of them qualify to be sold as Core i7 960's, 80 of them qualify as Core i7 950's and the remainder as Core i7 930's. Well despite the fact that Intel may have 200 CPUs that can be sold as Core i7 960's, doesn't mean they will do so. If they've got 300 orders for Core i7 930's then they'll take all of those CPUs and turn them into Core i7 930's to fill order requirements. Intel is also conservative. They do not sell Core i7 920's or 930's that barely run at their stock clock speeds at stock voltages. They always have some extra headroom. The reason for that is because Intel can't predict how they'll be used. They know many of them will be run under extremely hot conditions and that some boards clock them slightly differently, or there will be power supply variances, motherboard power variances, etc. So all CPUs, regardless of type are capable of more than what their published specifications say they are. That's not a guarantee but it's a fact proven time and time again by enthusiasts. The exact amount of headroom varies, but given that Intel's manufacturing gives them CPUs which generally can be sold as higher end parts, it's very likely that you can take your CPU to the stock clock levels of CPUs a couple models above or more.
Then you get into other factors such as heat, voltages etc. Some processors can be run at higher speeds without increasing stock voltage at all or increasing it very little. Other times processors will need huge voltage bumps to clock very much. How hot a CPU will run overclocked varies as well. It varies by cooling, ambient temperatures, motherboard temperatures etc. In many cases CPUs simply run a little hotter than Intel would have liked when clocked a bit higher. Well Intel is conservative with their cooling. You don't have to be. You can overcome high thermals with better than stock cooling. Air cooling usually suffices to a large degree, at least to some clock speeds, and water, chilled water, TECs, phase change, and LN2 can take you even further.
Also while not indestructible as far as voltages and heat goes, Intel processors have all kinds of built in protection circuitry to prevent them from being damaged. I've had water cooling failures which caused my CPU to throttle back and eventually shut down. It was left on for hours like this. I came back in and though the motherboard took damage from the overheat, the CPU was fine and still overclocks just as well as before with perfect stability. Intel conservatively clocked Core i7 CPUs. Reasons for doing so are their own but they may have simply been cautious in case AMD came out with a competitive part and they were forced to ramp up clock speeds on their CPUs in order to beat out their competition and stay on top. You see if your CPUs on average can already clock to 3.4GHz, but you aren't selling them that way, it's no problem to release a newer higher end model later in the year or immediately in response to your competition in response. Business like this is like a chess game. Move, countermove, and many moves are planned as "just in case" or as a means to executing a move planned well in advance.
In other words, overclock that CPU. It can take it and the results may surprise you. We can help you get started.There is extra performance to be had in there. Why not make use of it?
Dan_D, thanks for the good read and informative response.
I also want to agree with most here that it's really easy to OC the i7 920 and almost risk free. Worth a try and if it doesn't work out then you can easily switch back to stock speed.
Just to be clear. Increase the BLCK only. You do not need to touch the voltages unless you want a much higher overclock.
Not true anymore. In our [H]ard opinion, you are letting a great processor go to waste by not giving it at least a small bump like to 3.2 at least. :)
Thanks for all the info, I think I understand know why overclocking is popular. I guess I might do it once i get the new card, I will start with the BLCK thing but i dont know how to test its stability. I know for GPU its Futuremark, is that also the case with CPU? Are there any other programs? If Im gonna overclock it wont be anything drastic until I feel comfortable with the idea. like max 3.00 Ghz or something. A quick look at wiki's i7 page shows that even though the extreme edition is similar to 920 in specs save for the clock speed, its also $700 more expensive at the time of release! how can I attempt to get the same clock speeds with something so much cheaper? I dont plan to keep the CPU for 5 more years or anything so longevity is not big problem for me, the thing that worries me is a damaged CPU/mobo or even a blue screen which i never had with this hardware yet. The mobo im using has all kinds of overclocking options though, and it says it can do it automatically for me instead of manually, what does that mean? Should I use such a feature? As far as temps go, the case sucks, has only one intake fan.
...Not true anymore. In our [H]ard opinion, you are letting a great processor go to waste by not giving it at least a small bump like to 3.2 at least. :)
okay I will keep that in mind. 3.2? My CPU is not gonna like me. what do you use to test your new overclock settings?
