Prince Valiant
- May 3, 2023
Worth looking into if the LEDs can't be disabled outright or you want them on. That's some setup you've got .Nah. It only flashes when the computer is off. I think it is because of my weirdo setup that relies on a powered USB hub.
I can understand that my setup might result in the keyboard always staying lit, but flashing is kind of weird.
I might just set it up with one of those power strips that triggers a switch when one outlet powers on. I could hook it up to a monitor.
Picked up one of these recently - www.dygma.com Defy - after owning their original Raise split ergo keyboard which was fantastic.
View: https://imgur.com/a/vkA2EDx
This will be my first ortholinear/columnar split keyboard so it will be an adjustment, but hopefully worthwhile. My particular Defy is "full spec" which means all of the basic features are included (and there are a lot of "basic" ones like hotswap sockets; my previous Raise was Kailh Speed Silver, so this time I tried Gateron G Pro Yellow 2.0 which are apparently well regarded for linears. ) plus Wireless (both bluetooth and 2.4ghz dongle), Tenting up to 60degrees, and multi-zone Underglow (standard RGBW per key is default, the underglow is separate and more useful than you'd think both for layers and for stuff like having it monitor your system).
I backed it during the crowdfunding and ended up saving quite a bit vs the launch price. One thing that impresses me is both the desire to use open source firmware/software, and having watched them as a new company grow through fulfilling several major projects, they've always been forthcoming with exactly what's going on - even when stuff went wrong. They seem to be far more trustworthy than most and the open ethos is worth it too. I have been considering getting a columnar layout for awhile and looked into several others including various ErgoDox layouts/kits, the Moonlander, Kenesis Advantage360, Keyboardio Model100, and afew others and overall the Dygma looke like a better option. I'll have to see how it goes getting used to the layout but if anyone has questions just let me know/
It shouldn't take long for you to adjust to the columns. What do you think about the thumb cluster so far? I like the look of the Kinesis Adv. best, aside from it surely being a space hog and far from portable.
