D
Deleted member 184142
Guest
"MADE IN CHINA"? I thought WD REDs were only manufactured these in Thailand??
These from my understanding are more or less relabeled HGST He drives, and all HGST HDD manufacturing is done in China.
I would bet dollars to doughnuts these are totally standard drives.
The one I received was a bubble wrap envelope about four times larger than the drive box. I wish it would have been in another box. At least that was some protection.I just got mine, just want to comment on how crappy they were packed with almost no packing material, practically loose in the box.
Being a doughnut man myself, would those be Dunkin or non-Dunkin doughnuts?
So where was this HGST drive made?
Probably in Prachinburi.
More likely their factory in Bang Pa-In. The corporate office in Prachin Buri doesn't have any clean rooms except for the bathroom which doesn't come close to the required ISO standard needed.
I guess all of the HGST He8 drives that are manufactured in Thailand don't really exist? You should inform HGST as they are claiming they all come from Thailand.
The HGST drive is a WD relabel . This is the same drive:
https://www.pcper.com/reviews/Storage/HGST-Enterprise-He8-HDD-Found-Early-Retail-8TB-WD-My-Book
Yes, you have no idea....
So, do you still think "all HGST HDD manufacturing is done in China"?
No problem. We were talking past each otherConsidering all HGST He8's have been manufactured in Thailand and none from China; we now have WD RED's coming out of China is probably a good indication that these REDs are probably not a relabel. I think we should expect differences between the HGST He8's from Thailand and these "RED"s from China. I'm sure we'll find out soon enough what those differences are.
Yeah I have 5 of mine in an 8 bay unit now and one in my old Mac Pro. If I can get the performance where I want it, I'll relocate that data and pull that driver over.
Not going to sweat the China thing, and might order a few more if/when they go back on sale.
Are you seeing performance issues with the ones you have? They are still on sale and available right now for $179.
if there are specific test you want run...let me know.. I got my 6 today and can use my hot swap bay. If not i'll probably build my zfs pull in about a week.
If you can, capture the s.m.a.r.t data from each drive with smartctl and post it so we can see what HW and FW revs you have. I'll post mine when I get my drives.
sure i can do that. I got half of them pulled out tonight. Not sure how anyone does this with out breaking the clips.
If you use two credit cards turned long ways it will engage both clips at the same time on each side. Push down hard and you don't have to do any prying, it will bring the tray out.
nice. I'll give that a try.
user@debian:~$ sudo badblocks -wsv -b 4096 /dev/sdb
Checking for bad blocks in read-write mode
From block 0 to 1953506559
Testing with pattern 0xaa: done
Reading and comparing: done
Testing with pattern 0x55: done
Testing with pattern 0xff: done
Testing with pattern 0x00: done
Pass completed, 0 bad blocks found. (0/0/0 errors)
user@debian:~$ sudo smartctl -A -d sat /dev/sdb
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.7.0-1-amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 131 131 054 Pre-fail Offline - 116
3 Spin_Up_Time 0x0007 162 162 024 Pre-fail Always - 438 (Average 374)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 12
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 125
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 12
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 13
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 13
194 Temperature_Celsius 0x0002 222 222 000 Old_age Always - 27 (Min/Max 22/59)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
user@debian:~$ sudo badblocks -wsv -b 4096 /dev/sdc
user@debian:~$
user@debian:~$ sudo smartctl -A -d sat /dev/sdc
3 Spin_Up_Time 0x0007 169 169 024 Pre-fail Always - 411 (Average 365)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 13
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 13
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 14
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 14
194 Temperature_Celsius 0x0002 222 222 000 Old_age Always - 27 (Min/Max 23/59)
