- Apr 25, 2001
Looks like the AMD parody account is back.
RPM wouldn't show up in any config as it doesn't require explicit coding. The dev would just need to use the half types, which is highly likely on console, and use a recent shader compiler for the compute.
Unless heavily ALU bound, the RPM wouldn't necessarily make a huge difference. It would increase performance by using less power and letting the card clock higher. Usage of just FP16 would be a relatively constant boost effecting nearly all cards benchmarked.
It's DX12 which spreads the load well. From some videos, CPU usage was hovering 30-50% somewhat evenly with one core pegged. A Forza community manager said that was just the result of frequent input polling to reduce latency. So just the result of one thread not sleeping as opposed to serious load. Using jag cores, CPU load from consoles should be rather lite.
Nvidia's issue is likely choking on async based on frame times. Game likely using decoupled rendering as Vega's times were too consistent. That 12ms +/- a few percent shouldn't be possible as geometry varies around the track. Tuned sure, but Nvidia's performance should show similar results.
I'd also hazard a guess this is a Microsoft VR title in the making. That's a really solid 90FPS with details or MSAA dialed down just a bit. Of course XBVR doesn't really exist currently, but a racing game is a prime candidate for it.
Those deltas may not be tied to FLOPs though. It does line up well to clockspeeds. As I said above, RPM would have the result of lowering temps, and in turn increasing clocks, when not the bottleneck. Vega seemed to manage stock clocks at 4k, which is at odds with most recent testing I've seen without some modifications.
Vega may not have a power issue, it just wasn't designed with maxing all the hardware simultaneously. RPM being part of that equation. In compute; ROPs, TMUs, etc obviously aren't using much power.
Some users may notice that the game utilizes nearly 100% of one of their processor cores. This is expected behavior; we intentionally run in this manner so we can react as fast as possible in order to minimize input latency. Users on power-constrained devices, such as laptops and tablets, might want to use a Performance Target of “30 FPS (V-SYNC),” which will reduce processor usage and minimize power consumption.
Great! Hope other titles perform well. So far I am having a very good experience with the Vega 64 at 4K and VR.Here are the newest Forza Motorsport 7 benchmarks. noko This might make you happy. Personally I hope that Nvidia releases a new driver or works with the developer to get more performance out of Pascal. The 1080Ti shouldn't be that far behind in performance running on "Game Ready" drivers released specifically for the game.
Forza 7 Benchmark: Vega has more gasoline in the blood than Pascal.
https://www.computerbase.de/2017-09/forza-7-benchmark/2/#diagramm-forza-7-1920-1080
View attachment 37945 View attachment 37946 View attachment 37947
The "parody" account that suggested Vega would end up 20-30% faster than 1080ti? Just because the math and facts make sense. Because the graph above, with Game Ready drivers from Nvidia, doesn't show exactly that? Frankly I feel sorry for you. Getting even the simplest of things wrong in life.Looks like the AMD parody account is back.
Why would any sort of vectorization require specific code? Compilers can do that work trivially. It can of course be done manually, but simply replacing float with half on any sort of vector would be exceedingly easy to vectorize for a compiler.RPM requires specific code, and on that note it will show up in a cgf, they will have fall backs for 32 bit for older AMD cards and Polaris. They have to have different paths and that will be there.
Writing engines in high school and college, then engineering at one of the top ten schools in the US, and some grad work with clusters and tools from national labs.DX12 doesn't spread the load, where did you learn programming from? Its how the shaders are coded then the engine takes that and with DX12 splits the load. So if you have bad or incorrect code to begin with it will screw up.
Inefficient scheduling won't cause bad frame times? Along with increased CPU load? Perhaps you would care to explain why the AMD cards are doing so well then. The frame times for GCN are nearly perfect here and Nvidia included a game ready driver.Still talking about async, async compute doesn't cause this with frame times man, first off you still seem to neglect the fact there is no problem with Async compute with Pascal. And if you want to look at this all you have to do is look at frame times of various games with async on and off. That problem was still there frames times going all over the place with async compute off with earlier DX12 games, had nothing to do with async compute.
You're setting up some really easy rebuttals here. RPM specifically can influence power. Same ALUs yes, but what happens when you finish the work in half the time and they go idle? Barring an insane amount of packed math, the bottleneck easily falls elsewhere. Less energy spent on ALUs means higher boost clocks affecting other parts of the chip. Not to mention an idle ALU isn't contending for cache and memory bandwidth. It's really as simple as idle vs loaded processor power usage with some throttling thrown in.What are you talking about, you think using FP16 vs FP32 will drop power usage? Doesn't work that way, RPM uses the same ALU's, all the ALU's still need to be powered.
ROP's and TMU's are still being used the same was before, Forza's engine isn't that compute heavy lol.......
You just stated it yourself, the deltas line up with clockspeed,
Oh btw
Forza 7 runs mostly one 1 CPU core lol.
What did I say about CPU usage and frame times.
Nvidia already released a game ready driver according to Computerbase and performance is as expected. As your quote stated, and I was referencing that quote earlier, the CPU load isn't an issue. Put a sleep or wait in that input polling thread and I doubt any core is more than 50%. I've seen people parroting a poorly implemented game, but they have no idea what they are talking about. As the dev said, they are just polling input as frequently as possible to reduce any perceived latency. React to keyboard input as fast as possible. That would have little bearing on GPU dispatch. As I said, it's designed for console and relatively weak Jag cores. Testing demonstrated well balanced loads across all cores. Save the one polling input repeatedly.So it looks like a dev choice that is screwing around with nV hardware, lets see if they can fix it via drivers shell we. As I stated before in this post, DX12 doesn't spread the load automagically, in this case the dev's are using shaders that will not spread across all the cores for drawcalls, because it looks like they did it to reduce input lag.
RPM and FP16 are distinctly different here. Only FP16 is required to be coded for and it would be one of the first console optimizations the dev would have used. It works for AMD and Nvidia as well saving registers, cache, and bandwidth.
DX12 was designed to have multiple threads submitting work. Multiple threads by it's very definition spreads the load on the CPU. Shader coding has very little to nothing to do with CPU load unless all shaders need fully compiled. Which shouldn't be happing very often or at the very least cached as it should be in some intermediate state. Requiring only changes to addresses and minor tweaks.
In the case of FP16, simply code FP16 and the compiler will promote to FP32 if the compiler target requires it. That configuration could be in a file, but the engine could also just preselect paths based on detected hardware. That's assuming Vega doesn't have hardware to handle the packing either. Leaving the compiler to reorder FP16 instructions and hardware detect similar registers for packing. I can't think of any situations where coding FP16 and adjusting the target to promote to FP32 would break something.
I pointed this out to you years ago at this point. Current async implementations have been very limited on PC. Sticking to just overlap of graphics and compute. Barely touching on the "async shading" aspect of async that is used for multi-engine, decoupled rendering, and the ideal async techniques for VR. This is the very stuff I've been suggesting is required for modern games and especially VR. Forza 7 would seem a perfect candidate for VR, which Microsoft hasn't really pushed yet. Going by the extremely tight frame times measured for Forza, AMD should be doing rather well in comparison.
This title was developed for consoles with comparitively weak CPUs. All sorts of tasks then farmed off to the GPU for acceleration and even leading towards GPU driven rendering. That leans heavily on the multi-engine side of things. Monday Computerbase should have CPU tests, and I doubt much changes. The game just isn't designed for powerful GPUs, but I suppose an eight core might help a bit. Regardless AMD already has near perfect performance based on those consistent frame times.
The deltas line up with clockspeed, but how often has an air cooled Vega been maintaining those clocks? Power numbers on Forza would be interesting to see here. With RPM I fully expect performance to track ROP and TMU usage, barring obvious CPU and memory bottlenecks. It would almost always remove ALUs from the equation. At least until someone goes crazy with HDR.
This looks to be an extremely well optimized title in comparison to past releases, so I doubt much changes. This game would be representative of the DX12/async landscape of the future. It's what devs have been wanting and precisely what I've been saying all this time.
CPU load is limited, memory bandwidth less a concern(going off Fury and Vega), and performance scaling nicely by GPU throughput. It's just getting started.
Months before Vega launched, using Fury X's teraflops vs. the leaked (which were true) Vega 64 teraflops I predicted it right around the 1080. I figured it was based in reality considering AMD's history and it was pretty close.
What assumptions did you make to get 20-30% faster than a 1080ti? That's substantially faster than where it's actually at. You predicted it to be 49% faster than it is....
You have to understand how off that prediction was and you keep coming back with equally crazy predictions. That's why some people react the way they do.
He is going to hob around everytime some lone game does better on Vega, while ignoring the scores of games where Vega is behind the regular GTX 1080, or even barely above GTX 1070.
The first RPM game coming appears to be Wolfenstein, this month. The video's look rather nice in the rendering, I am getting more excited about this title. This game maybe will show how useful is Rapid Pack Math with games. My Vega 64 is ready . . .
If it's using the same engine as Doom (I don't know personally), won't it already run great on pretty much everything?
I mean, I'd like to see what all the fuss about these new features AMD is putting in their GPUs are about too, but are they going to be demonstrable in such a game?
Really don't know, we will see. The visuals, at least to me look more complex, higher textures and more natural looking lighting. It will be using AMD Intrinsics and RPM, not sure how well it will be optimized for Nvidia. From the videos it really looks pretty awesome but those can be misleading. I have this game pre-ordered since it came with the Vega 64.If it's using the same engine as Doom (I don't know personally), won't it already run great on pretty much everything?
I didn't make any assumptions. I took the results presented by developers and IHVs in various papers for different features Vega added and combined them conservatively. Culling and binning gains largely equalizing performance. Then applying measured gains from RPM. I didn't even account for async hammering Nvidia's CPU performance in comparison and left out many features that we're hard to quantify.What assumptions did you make to get 20-30% faster than a 1080ti? That's substantially faster than where it's actually at. You predicted
How was it off? Forza7 shows EXACTLY what I predicted. Throw in a liquid cooled Vega64 and even that 30% is really close. Forza likely isn't making the most of all the features either. I really wouldn't be surprised to see Vega go well beyond 20-30% as time progresses. Pascal just doesn't have the hardware to efficiently run some paths. Not unlike a 780ti over time, where even midrange parts outperform it.You have to understand how off that prediction was and you keep coming back with equally crazy predictions. That's why some people react the way they do.
The first they are marketing anyways. That doesn't mean other games like Forza couldn't use it already. It really is just a matter of using FP16 in compute shaders, which should be common in recent games.The first RPM game coming appears to be Wolfenstein, this month. The video's look rather nice in the rendering, I am getting more excited about this title. This game maybe will show how useful is Rapid Pack Math with games. My Vega 64 is ready . . .
Most are transparent and of more use for devs. Maybe some if the Tier3 features for conservative raster, etc; however they are likely a few years off and I wouldn't expect huge visual differences there. As a said above, a Bethesda guy stated 80%+ async compute, so RPM could be hitting really hard.I mean, I'd like to see what all the fuss about these new features AMD is putting in their GPUs are about too, but are they going to be demonstrable in such a game?
A title shows up with those critical features running as expected and landed almost perfectly with my predictions. Still waiting on the RPM confirmation, but coming from console seems highly probable. Bottom line both cards are performing inline with theoretical numbers.
My "crazy" predictions were spot on and almost everyone around here missed it. Whether that's bias or lack of critical thinking ability by many I couldn't say. Every site I've seen has confirmed not all Vega features are enabled and that will change the picture. Keep in mind, I was predicting parity with Titan and eventually surpassing it as RPM, primitive shaders, and GPU driven approaches land. Already there are Bethesda devs quoting 80%+ async compute workloads on upcoming games, so it's starting.
FP 16 and 32 is not vectorization lol
If you say so. Included a less technical explanation for you. Yes FP16/32 alone isn't vectorization, but registers are generally standardized around 32 bits. So FP16 results in packing 2:1.Arguably AMD’s marquee feature from a compute standpoint for Vega is Rapid Packed Math. Which is AMD’s name for packing two FP16 operations inside of a single FP32 operation in a vec2 style.
https://www.anandtech.com/show/11717/the-amd-radeon-rx-vega-64-and-56-review/4
Gibberish is just about everything you post. You copy in technical material in an attempt to show you know wtf you are talking about, but with no understanding of what you're saying and hoping nobody else can or will bother to actually parse it. This shit isn't difficult to understand either. So how is it I'm the laughing stock, yet you're the one that f'd up? If I'm the laughing stock it reflects rather poorly on those laughing, as it means they're too dumb to actually understand. Essentially easily manipulated sheep lacking the ability to think critically. Franky I find this hilarious that you followed the same theory as everyone else and it fell flat. While I took a unique view and was spot on. Unless you don't think the Forza benchmark showing 22% faster when I predicted parity to 20-30% faster.The rest of your post is gibberish, as I stated you have no clue of what you are talking about, you are not a programmer and you keep making things up to fit your "theories". STOP DOING THAT! This is why you are the laughing stock of Vega supporters here, even the die hard fans know you are spouting BS.
Err, the developer said exactly what I did. They mentioned vsync for battery life. Anyways, they had to release a PR statement clarifying it because apparently people didn't understand it.The DEVELOPER STATED something, and you can't seem to get it through your head why it was done and that would affect Pascal. They were specifically talking about desktop paths, that is why they mentioned v-sync, laptops and others. You take that and put it towards consoles WTF. It was right there in the same sentence.
Forza Motorsport 7 is not limited to running on one core. There seems to have been a miscommunication along the way. “Forza Motorsport 7” uses as many cores as are available on whatever system it runs on, whether that is a 4- to 16-core PC or the 7 cores available on Xbox One.
http://wccftech.com/turn-10-forza-motorsport-7-one-core/
I'm unsure where he would have said it was hard. Any reasonably educated programmer would understand floating point math. Especially anyone writing shaders. Going off the papers devs keep presenting, they seem to understand well enough. The less educated leaning on the big engines and skilled devs.Lets see, Anarchist, will you still sit here and BS with me about everything? Vectorization my ass lol. Come on, you think Sebbi would have said it not easy to do if he didn't mean it? First off most junior programmers won't even know how the different pipelines work, as noted by you already, experienced programmers will know how the pipelines work on per architecture level, but they still need the experience of doing the same shaders over and over again to know where the problems can be when going from FP16 to FP32 in the same shader (all of this mapping will change based on different shaders, how many shaders do games employ? 100's maybe even thousands depending on the game on how the shaders are setup.)
"Leaked" may not be the right word when provided to the site, a driver released specifically for it from Nvidia, and performance looking rather solid. Low CPU usage and spread across all cores, good FPS and frametimes, and stable from everything I've seen. Those Vega frame times were nearly flawless. The only Nvidia issue I can see is choking on the async submission, but without the "performance critical" MPS hardware or ACEs of GCN, that will take a lot of work to even out. There is a reason devs always disable async on Nvidia.Forza isn't even out yet and the "leaked" benches show something really wrong with the nVidia side not something really great on the AMD side... it's not confirmation of what you've been saying. It's a typical Microsoft launch.
IT IS OUT FOR THE LOVE OF ALL THAT IS HOLY!!!Forza isn't even out yet and the "leaked" benches show something really wrong with the nVidia side not something really great on the AMD side... it's not confirmation of what you've been saying. It's a typical Microsoft launch.
It released last week for those that purchased the ULTIMATE EDITION. It releases this week for the base game purchasers.
Already linked you the vectorization, but "packing" rapid "packed" math into Vec2 is pretty simple. Not all that difficult for a compiler either. As vec3/4 is somewhat common in 3D space, that mapping is rather straightforward. That's already common for anyone familiar with compiling on PC. Junior programmers don't even need to understand the pipelines to convert to FP16, and casting isn't difficult to figure out if needed. Consoles obviously easier as everything suitable is FP16 already. Even without that step, limiting to Polaris and Maxwell2(I think) would be sufficient for FP16 support.
here is an example code just for you, with parts missing, so you can start off
// float32
// Martin Kallman
// Fast half-precision to single-precision floating point conversion
// - Supports signed zero and denormals-as-zero (DAZ)
// - Does not support infinities or NaN
// - Few, partially pipelinable, non-branching instructions,
// - Core opreations ~6 clock cycles on modern x86-64
void float32(float* __restrict out, const uint16_t in) {
uint32_t t1;
uint32_t t2;
uint32_t t3;
t1 = in & 0x7fff; // Non-sign bits
t2 = in & 0x8000; // Sign bit
t3 = in & 0x7c00; // Exponent
t1 <<= 13; // Align mantissa on MSB
t2 <<= 16; // Shift sign bit into position
t1 += 0x38000000; // Adjust bias
t1 = (t3 == 0 ? 0 : t1); // Denormals-as-zero
t1 |= t2; // Re-insert sign bit
*((uint32_t*)out) = t1;
// float16
// Martin Kallman
// Fast single-precision to half-precision floating point conversion
// - Supports signed zero, denormals-as-zero (DAZ), flush-to-zero (FTZ),
// clamp-to-max
// - Core opreations ~10 clock cycles on modern x86-64
void float16(uint16_t* __restrict out, const float in) {
uint32_t inu = *((uint32_t*)&in);
uint32_t t1;
uint32_t t2;
uint32_t t3;
t1 = inu & 0x7fffffff; // Non-sign bits
t2 = inu & 0x80000000; // Sign bit
t3 = inu & 0x7f800000; // Exponent
t1 >>= 13; // Align mantissa on MSB
t2 >>= 16; // Shift sign bit into position
t1 -= 0x1c000; // Adjust bias
t1 = (t3 > 0x38800000) ? 0 : t1; // Flush-to-zero
t1 = (t3 < 0x8e000000) ? 0x7bff : t1; // Clamp-to-max
*((uint16_t*)out) = t1;
This is laughable man. THIS HAS NOTHING TO DO WITH VEGA, even RX 580 is giving better fps than 1080Ti, this is an anomaly, something is massively holding NVIDIA back in this game. the 1080Ti is only 7% faster than 1080, there is an obvious issue here. Rest assured it will be fixed, just like Hitman and Ashes of the singularity.How was it off? Forza7 shows EXACTLY what I predicted. Throw in a liquid cooled Vega64 and even that 30% is really close. Forza likely isn't making the most of all the features either. I really wouldn't be surprised to see Vega go well beyond 20-30% as time progresses. Pascal just doesn't have the hardware to efficiently run some paths. Not unlike a 780ti over time, where even midrange parts outperform it.
Nvidia released a game ready driver for it already and said it performed as expected in the benchmark. The lead developer straight up said work was distributed and steady frame times show it's well optimized for DX12. So why is Nvidia having so much difficulty with a relatively simple game? It's using the DX11 feature set, following DX12 submission rules, and far from CPU limited.Oh, my bad. When I checked the store it said "preorder."
Still doesn't change the point that it's shit optimization for nVidia and not a magical what can be for AMD.
As for AMD's "magic", the game has been released, benchmarked and played. The results are readily apparent for anyone that bothers and verified by IHVs as accurate. I don't see how you can call it magic when the evidence is right there. Or is the argument now that Vegas drivers are ahead of Pascal's? Forza isn't even partnered with AMD it using any exclusive features as far as I'm aware. For the Bethesda titles maybe there's an argument, but Forza isn't advertising intriniscs, deals, or heavy optimization specific to AMD.
Oh and stop grasping at straws to prove your failed predictions, if this is really the best example you can come up with then you are truly desperate!
Stuff isn't difficult once you understand it. That's not really arrogance, and if you can't explain something in simple terms, you probably don't understand it.Nothing is difficult for you, you are the pinnacle of arrogance and everyone that does this for a living sucks at it because you say so......
The context of the original statement was that a single core being loaded wasn't the same problem from prior games. Everyone assumed one core being the reason for Nvidia's performance and the guy refuted that notion. Stating it was just a thread polling input. Which was further taken as Nvidia only using one thread, at which point the lead developer further clarified it wasn't the case. That problem could have very easily been fixed a while ago. Hell, Nvidia's game ready driver could have picked a different core even if it was. Both devs said loading of a single core wasn't the issue, it's that simple.That was the ENGINE Developer, the game developer said what I quoted. THIS WAS THE exact same problem with Forza 3 and 6 on nV cards! I play the Forza series and have noticed it in those two games too when released, shortly after a game update solved the problem. Go look up those games and you will see the problem existed for nV cards! Tons of info on them forums, shuttering, frame times all over the place etc.
Sure, however I'm not sure those are the best areas for packed math. FP16 is largely in compute, which isn't pixel and vertex shaders. If using vertex normals sure, but the better use would be a wholesale conversion to FP16 of the vertices for an early culling pass. That's been the recent async compute approach anyways.Tell me, if I give you a fp 32 shader, pixel and vertex example we can take one from the web, like for normal maps or better yet AO, you want to show me how to port it over to vertex shader FP 16, I can guarantee you will not know how to do it, from the math all the way through. Cause you didn't know the steps till I pointed it out. Give ya 3 hours to do this.
If you had to convert them. Even then it's a single hardware instruction. The compiler should handle the conversion automatically if you try to pass FP16 into FP32.I don't give a shit about the packed portion of the problem, cause that is easily done through drivers, no programmer intervention. When you have different FP's in the same block and shader its creates headaches.
What exactly do you think makes a tensor so complex? It's a giant SIMD... I've never said GCN is the be all of architectures, just that what's occurring isn't anything new. It's just vectorizing one operation instead of x parallel operations from different threads.That is why when you say something like a swizzle for tensor functionality or MPS is aka async, is laughable. You are trying to make GCN the be all of architectures, which by NO MEANS is it.
Kind of odd to be going the way of the dodo when the major consoles are based on GCN, upcoming SM6 uses GCN2 as a foundation, and GCN was designed for async compute, which is the foundation of DX12/Vulkan and derived from Mantle. Which again was designed around GCN. Seems more on the way in than out.It doesn't have all the capabilities of Pascal, nor Pascal have all the capabilities of GCN, both have their strengths and weakness, but when it comes to what is being used today and end metrics of the architectures, GCN is pretty much going the way of the Dodo.
Can't just use the f16tof32() instruction in HLSL? Shave what, 80% of the instructions in the process? That conversion can be pipelined in, so best left to the compiler. FP32 to FP16 could be tricky, but the conversion isn't really the concern there as you hack off so much precision. Regardless, I think all conversions should have hardware instructions as copies are really easy.This is not my code but low and behold everything I talked about is mentioned or is in the actual code. This needs to be done for ever single FP 32 pixel shader that would need to use the FP16 vertex shaders, pretty much all in game shaders. (this is in reverse too)
So waiting on magic drivers to fix Nvidia's performance then?I actually prefer Harmeeeedo's response:
Looks well distributed, but not really using SMT. Considering the load on the cores that's probably sufficient.you see the work being disturbed across the CPU cores evenly here?
I don't, I see one core at 100% and the others much less.........
So which one was right the engine dev or the game dev? The game dev stated they use one core predominately, that is what this is showing right here.
No. Not sure I'm running the correct Linux kernel for DX12.So were able to do the profile of Forza 7 yet?
MPS manages input and balancing from multiple processes. Hence multi process service. Asynchronous tasks, as they are considered unrelated. In the case of ACEs, AMD uses them under a different name to distribute asynchronous work from one or more processes. As Nvidia defined them, they are "performance critical" when dealing with these asynchronous tasks.
Both devs were right. One core is 100%, but as has been explained multiple times now, isn't doing anything critical. It's just an optimization to make the game more responsive. Using the spare CPU cycles. The main thread is probably the second one that occasionally hits 100%. The spikes could just be data transfers, but hard to tell.
Nvidia confirms the backlog
The ranking in Forza 7 is very unusual. Nvidia has confirmed ComputerBase, however, that the results are so correct, so there is no problem with the system in the editorial regarding GeForce.
Got a question for ya PhaseNoise,
Can drivers or hardware automatically convert from FP 16 to FP 32 without errors?
I don't think its possible unless the hardware is smart enough to know where the errors might come from.
CPUs certainly can, I don't know how GPUs deal with FP16 though. In x86/x64 half precision functionality and converstion instructions are a part of SSE.
You still want to avoid conversions though, as it consumes time. "Automatic" things to take advantage of FP16 will probably not be stellar because of this. You're saving a little time on the math, but you have to convert and pack data types first. It may be faster, may be only slightly faster, or may actually be worse. It would be hard for a driver to know. A developer would know, so I agree with your points it is realistically going to require developer support.
Oh, and anyone who thinks compilers do an even remotely okay job of automatic vectorization - no, they really do not.
I work in math libraries all day long, and the automatic vectorization is minimal, at best. Partially because it's insanely hard to detect when you can effectively use it from a static code inspection standpoint except in absolutely trivial cases where lengths are known at compile time.
Ah yeah that makes sense, hence why my co workers do it by handthx!
So fp16 if driver implemented would be a game by game bases? Compute shader replacement for items that it would give benefit? Anyways I thought RPM was for AI, compute learning stuff than for games while it could be useful for some game compute shader stuff. I have no idea the performance advantage overall on a game using RPM? 5%-10%? Less? Well two games advertised with RPM is coming, Wolfenstein and FarCry 5, maybe we get to see what it can do then.
