[H] own review shows FE barely maintain anything over 1700 .. nevermind 1800/2Ghz
https://www.hardocp.com/article/2016/05/17/nvidia_geforce_gtx_1080_founders_edition_review/5
"The clock speed seems to average out to around 1770MHz (1.77GHz) according to the table. If you look at the graph the frequency likes to hover between 1760MHz-1785MHz most of the time. The good news is that this is mostly all above the quoted GPU Boost clock of 1734MHz. It is at least 30MHz higher, and sometimes more. However, you will note that there are many times the clock speed does dip below 1734MHz."
Gamer Nexus states that
Maybe the FE reviews were a factor, but we'll have to see if PCPer and Tom's Hardware also didn't get sampled with RX Vega either.
Quite the contrary. Intel has enormous bearing on NV since most of the those "green" PCIe slots are on Intel boards. Intel also chased NV out of the chipset market years ago so there may be a grudge there too
Radeon RX Vega 56
Unboxing embargo: August 12, 11AM EDT,
Performance embargo: August 14, 9AM EDT
Launch: August 28th.
Radeon RX Vega 64
Unboxing embargo: August 12, 11AM EDT.
Performance embargo: August 14, 9AM EDT.
Launch: August 14th.
Radeon RX Vega 56
Radeon RX Vega 64
"As we are not being sampled for RX Vega and aren’t in official communications regarding the product, we’re able to provide up-to-date news without concern of embargo breach."
- Gamers Nexus
Anyone remembers what I said?
July 1, 2017
the oc'ed 1080 can easily reach that score.That chart seems to perhaps have the Vega 64 a bit low in light of this mornings discovery of a Firestrike score of ~24,000 which should be a fair bit ahead of what an OC on a 1080 FE can achieve, as far as I know.
An OC'ed 1080 Founders Edition can reach that score? I'd been under the impression that 1080 FE's weren't that good at overclocking.the oc'ed 1080 can easily reach that score.
Right, but the only reason I mentioned it is because the chart has a 1080 FE listed, not an AIB version. Also, probably the tastier morsel in that chart is that they have an OC'ed Vega 56 above a stock Vega 64, which would make Vega 56 a pretty good value, if true.You would be correct. Most good overclocked 1080 cards are not a FE as most of them struggle to maintain 1900 clocks. However my Zotac 1080 AMP can reach 2100 and is likely what Hameeedo is trying to say. But to be honest comparing overclocked cards is kind of silly as you never know if you can hit that overclock or not, just gives you an idea of what is maybe possible.
Their complain was AMD favored some outlets to release more coverage earlier then others. That is a foul play on AMD and defeats the point of embargoes.I mean, not to re-hash what r/AMD was talking about in a few comments, but they knowingly violated their NDA (with low level info like thermal paste, whatever) because they saw someone else's content out there... without contacting AMD?
That's just dumb?
This is also after they included video of their conversation with an AMD rep directly on their review of Ryzen (I believe it was) which is a cringey non-professional way of doing things.
I really like their in-depth stuff they do, and I think they were fair with the Vega FE review.... but this was them just having a small tantrum.
I can hit 2050 on my FE and usually keep a solid 2038 with no problems.You would be correct. Most good overclocked 1080 cards are not a FE as most of them struggle to maintain 1900 clocks. However my Zotac 1080 AMP can reach 2100 and is likely what Hameeedo is trying to say. But to be honest comparing overclocked cards is kind of silly as you never know if you can hit that overclock or not, just gives you an idea of what is maybe possible.
They did use their words they publishedYeah, but use your words and talk to them first? Probably could have gotten permission but they didn't even try by their own admission.
And violated their NDA?They did use their words they published
I don't think you understand the point of embargoes. They are meant to level the playing field for media outlets. The moment AMD started to show favoritism towards some media outlets they demonstrated they where not interested in professionalism. The best strategy for any media outlet not wanting their coverage overlooked would be to break the NDA at that point.And violated their NDA?
That's smart.
There were a couple of good nforce chipsets, if I recall they had one of the better socket a chipsets, been a long time though, my memory my be off. 100 percent sure they made a couple good chipsets though. The sound was really good if I am not mistaken.nVidia chased itself out of the chipset market. I avoided nForce boards like the plague they were...
Yeah, nForce2 was pretty solid for Socket A.There were a couple of good nforce chipsets, if I recall they had one of the better socket a chipsets, been a long time though, my memory my be off. 100 percent sure they made a couple good chipsets though. The sound was really good if I am not mistaken.
Fudzilla has an abysmal track record with predictions. I am amazed they still operate.
This must be why AMD is suddenly pushing the 56 instead. At that price there is no reason to pick up a Vega 64 over a GTX 1080.
Tom's Hardware is definitely getting it because it's a big site.
PCPer is probably getting screwed over through.
Looks like PCPer received an RX Vega (you can see the box behind him) and there's currently benchmarking going on using an Nvidia card (on the far left you can see a Founders Edition in the motherboard).
Source:
all 1080 FE can hold over 1900 by just using a more aggressive fan curve.. adding extra core offset and power target to 120% those tend to go easily over 2.000mhz at about 65C stable.. in fact the [H] 1080 FE Sample did an average of 2060mhz and average 56C temp with vRAM at 11.1ghz BUT and the big but with the fan speed at 100%. so with a more moderate fan curve that top at 70% to keep noise down, 2ghz are still easily doable at acceptable temps on the 1080 FE.
Really was a good card just the +$100 was bullshit.
For 1080ti wattage and above I like AIOs, custom or a hefty air cooler. I still want my 3-4 slot blower heheh... someone make that. That would be my ideal... quiet, simple, hot air out of the case.
God damn it's gorgeous, at least they got that part right.
I would like to see these after playing for a couple hours in a normal closed case and see if they can sustain that 2000 overclock. Running a benchmark mine can do 2200 but wont stay stable for playing a game but will do a benchmark fine. It sort of like taking a 7900X and taking it to 4.8, sure it can do it but it cant sustain it for long. Not saying it's impossible Araxie but I dont think it's as sustainable as some benchmarks make it look. Plus many people dont realize it's throttling and dropping the clocks and they state it's running 2000 but in reality its running slower and why they are puzzled that their benchmark numbers dropped. AIB do far better as they have much better cooling and sometimes a few tweaks to the bios that help. But even at 1900 the 1080 is a nice fast card and Vega will have it's hand full trying to stay with it.
