HardOCP News
[H] News
- Dec 31, 1969
I don't know about this concept design, it seems kinda odd that you would combine a flash drive with something like a battery. Good idea? Bad idea?
Best smuggling device possible? Think about, you put it in some mundane device that no one cares to notice and use it to carry or steal data. Or again, use it to hide data.
Make this into a D cell battery then take your 80's style boombox into the secret CIA or other secret government facility. Eight or ten D Cell sized USB flash drives should be more than enough to gather a sufficient amount of secret data.
I have a couple of those and they are ok to have around at a pinch but their capacity isnt great.
I just never like the idea of having batterys loose in my pocket or bag. So I wouldnt want to use it for a USB stick.
Ever dropped a AA battery in some steel wool?
Well, the one I linked just charges on USB, it doesn't have storage at all.
I don't know why people keep thinking that the one from this article does either. As far as I can tell its just what you linked but with more "refined" but also more problematic design.
It's a 4 GB memory stick, and a battery, according to the linked article. I guess that's why there's confusion.
I personally think this is a horrible idea, though. In the article it says "So you have a USB drive that you use quite often, so often that you keep it hooked to your computer most of the time." If I have a drive hooked up to the computer most of the time (I do), how do I have time to put it into another device? For what amount of time? And if I need to access it, I need to remove it from the other device and change it around to put back into the computer? Someone thought this was a GOOD idea?
While a great Idea when you think about it, this design is about using the USB port to charge, it doesn't look like it is about holding data at all.
Li-Ion cell = ~3.6v, AA cell = ~1.5v
Otherwise it's perfect!![]()
In the picture it says right on it, "4 GB".
