Upgrade options on Intel P965 Express Chipset
Smashed Ixnay
My girlfriend's grandmother has a Dell XPS 410 that has a Pentium D 2.8ghz processor in it. The specs for the motherboard are here. It says it supports " Intel® Core™ 2 Duo" processors, but it has a Pentium D computer in it now. She says it's slow, so I was trying to help her upgrade it rather than buy a whole new pc. If she wanted to put an e7400 in there, would that work? What about quads cores like the q6600? Will all core2duos work in it?
Since it is a Dell and not an actual mobo product from a motherboard manufacturer, more than likely the E7400 will not work. There are many p965 mobos that do support the Wolfdale core E7400 CPUs but those tend to be the higher-end models, not the basic stuff found in an OEM system like the Dell.
The Q6600 should work. Try to stick with Intel Core 2 Duo CPUs that came out around 2006 or were based exactly on the 2006 CPUs (Allendale and Conroe cores) like the E6XXX series, E2XXX series, and E4XXX series.
So would an e6300 at stock speeds be an upgrade over her Pentium 4 2.8ghz cpu now? What about if I OC'ed it to 2.3ghz (don't want to go crazy since it's just used for internet mainly). I don't even know if I could OC with the dell mobo, which is why I need to know at stock speeds if it's faster. If not, then I could probably find like an e6600 for cheap somewhere. It has like 1gb pc5300 ram now. I prob would put 4gb pc6400 in there since it's so cheap.
Think that would make a difference of night and day?
At stock speeds a E6300 will absolutely RAPE a Pentium 4 2.8Ghz or Pentium D 2.8Ghz. Also, you cannot OC with most consumer class Dell PCs. So there is a difference.
Alright, sounds good. I think I'll probably find her an e6300 or e6600 for her. I'm pretty sure even with the e6300 with 2-4gbs of ram would definatily be faster than the Pentium D 2.8ghz with 1gb ram.
While that's true, what exactly does your GF's grandmother do with her PC? If it's just basic web browsing and word documents, even a Pentium D is fast enough for that. Maybe the slowness your GF's grandmother is talking about is due to a slow drive? Or bloated OS install?
It comes with a 250gb HDD. Think it's 7200RPM and a Sata 3.0 HDD. I'll have to check on that tomorrow. I plan on going over and trying to clean it out for her. It basically is internet, excell, word, and some flash type games that she gets off AOL.
Thanks for the quick responses Danny.
No prob.
Hmmm for all the tasks that you've described, a Pentium D should be more than enough. So it's probably related to the actual OS install or slow hard drive. Though adding extra RAM will help.
I would save yourself the hassle and just increase her RAM to the max that board will support, 2GB would be a good improvement. 4GB might be overkill, but definite "future proofing" that will accommodate any future needs.
STOP - Before continuing and throwing away money - consider this.
What is she doing on the machine such that she thinks it is slow ?
Is it overrun with mal/ad ware ?
How much memory is installed ? If less than 2 GB I would recommend going there first along with a run of ADaware and Spybot Search and Destroy. Antivirus run recently ? Clamwin is free and only runs when you tell it to.
When was the last time the HD was defraged ? Thought so.
Check for dust buildup causing the cpu to throttle, all fans running etc. etc.
A 6300 and 2GB of ram would likely do wonders but a 2.8GHz P4 or Pentium D (which is a dual core P4) with a decent amount of ram and a clean HD should be a kick ass general use computer. Now if she is playing the performance pig they call Warhammer Online, thats a different story.
Point is, unless you tell us more, running in and slapping in a new CPU will only mask the issues she is having and likely not for long.
There is no way that that machine should be "slow" on the Internet if the existing hardware and software is tuned up and functioning properly and it is equipped with 1GB of ram or more. (Well, unless she is on dial up in which case there is no hope, only un-ending agony and despair).
It is likely also filled with Dell supplied "crapware" delete as much as you can from Remove Programs .
Any tech can slap in new parts, do some engineering and find the root cause. :)
I agree that by just increasing the memory to the max, it will really speed up her PC, thus a faster or new board is not needed. For basic stuffs, the speed of the CPU doesn't matter as much as memory and clean HD. Most (if not all) Dell PCs come with Pre-installed OS, which sucks as they are full of garbage programs and ad. Pretty sure if you know what you are doing, doing a clean OS installation usually speeds up the overall performance of the PC as well...unless you don't have a separate license to install on hers. Nevertheless, re-imaging her HD with an original image off the CD or recovery partition and get rid of the garbage programs will still help.
