nice. that makes the Galaxy Geforce 460 1GB GC model + Just Cause 2 PC to $203.51 after BCB.
So the question is if this is better than a $255 GTX 470 (I have two GTX 460 810MHz on order).
Got a EVGA GTX 470 for $214 after BCB/MIR/AC.
See if CompUSA is taxable in your state also. They are running 15.3% BCB
I think your math is off, I did it and it's $234.39......
i'm guessing you do Ebillme, how does that work?
Since you were kind enough to spend more than 200 dollars with us during our 20th anniversary celebration, we'd like to return the generosity: by taking 20 bucks off the total cost of your next order over $200! All you've got to do is choose 200.00 dollars worth of your favorite technology: anything on our site is fair game! Place any order worth 200 bucks or more, and we'll shave 20 dollars off your purchase price at checkout. It's as simple as that!
I cannot get the 15.2% searching for "tigerdirect cashback". What else did you try?
disable adblock if you are using it.
isn't the bing cashback going to end at the end of this month?
Does that mean we will never end up getting the money back if we buy something now?
Circuit City, Tiger Direct and Comp USA are the same company now. Which explains all having 15.2% and all having tax in the same states.
The EVGA GTX 470 link with the coupon in the other thread doesn't seem to have a rebate. Which card did you order?Got a EVGA GTX 470 for $214 after BCB/MIR/AC.
Got a EVGA GTX 470 for $214 after BCB/MIR/AC/SC (Store Credit)
I think the extra $20 off is from bill me later or something.Corrected
Corrected
So I know discounts disable BCB, Does anyone know if the EVGA GTX480's promos will disable BCB? Its 499.99 with a $20IR and a $30 MIR.
Wanted to get some 2TB drives, but got this message:
This product is excluded from the Cashback program. Adding this product to the cart will make this order ineligible for Cashback.
CRAP!
How did you acquire the TigerDirect cashback?
