The AX58U is good if you can stretch the budget abit more the AX86U is even better.
I love this router! Latency is so much lower!
What's the budget and how much time do you want to put into it? I stopped buying off the shelf routers. OPNsense on Protectli hardware FTW.I need a new router. I currently have a netgear nighthawk r8000p. It is about 3000 Couric's. It constantly cuts out and always has. The latest firmware update from last month is horrible...have to reload website two or three times to get them to load (I am not alone). The $29 Walmart special is more reliable. I can't take it anymore!
I am after reliable, ddns and be able to vpn.
few hundred bucks...and I want it to be fairly simple. I don't need an app; i can log into the IP and what not, but building a complete linux router is out.What's the budget and how much time do you want to put into it? I stopped buying off the shelf routers. OPNsense on Protectli hardware FTW.
opnsense is simplefew hundred bucks...and I want it to be fairly simple. I don't need an app; i can log into the IP and what not, but building a complete linux router is out.
Only 1gb for the lan though on those I think.There are several on the market. Off the top of my head the Asus 86U models get good reviews and the top model of that line has one. Just make sure your modem has a 2.5g port and isn't requiring two 1gb ports.
Hello I need a router that has 2.5 lan ports to get my full 1200 down xfinty speeds
Are there any wireless routers with 2.5 lan ports
Thanks
pfsense or opnsense very good options but also more complicated to setup and not wife friendly so will depend on environment.For the dual 2.5 price you may as well go pfsense and an access point…
But for a consumer router that’s plug and play with that speed, I guess it’s what you gotta pay
Totally agree with you. This is the consumer router thread so I really shouldn’t be mentioning pfsense or opnsense but man, that’s a lotta coin just to use a 1.2gb connection.pfsense or opnsense very good options but also more complicated to setup and not wife friendly so will depend on environment.
I agree with you.Totally agree with you. This is the consumer router thread so I really shouldn’t be mentioning pfsense or opnsense but man, that’s a lotta coin just to use a 1.2gb connection.
Wife friendly is a big concern for me and the guys I know. Happily married for many years now.Totally agree with you. This is the consumer router thread so I really shouldn’t be mentioning pfsense or opnsense but man, that’s a lotta coin just to use a 1.2gb connection.
Wife doesn't want to have anything to do with the network, other than to remind me it's not workingWife friendly is a big concern for me and the guys I know. Happily married for many years now.
It means that I take care of it 100% and she never has any issues with wifi or network access or big ugly boxes all over the place (if a mesh). Also price and no need to hack into the walls, etc., etc.Yeah im interested to know what defines a router as wife friendly?
Sure i guess.If the connection goes out are you able to do a factory reboot on the device and walk her through the setup over the phone.
That would be very painful on pfsense box with someone that is non technical.
Yes but power outages happen sometimes. External factors that are outside of one's control are always there.Sure i guess.
Thing is with a opnsense router is that you no longer have to play the reboot game.![]()
I'm not sure what that has to do with a factory reset. My OPNsense box has never needed to be factory reset. It only reboots during software upgrades that I kick off and if power goes out I simply click the power button and it's all well and good.Yes but power outages happen sometimes. External factors that are outside of one's control are always there.
Honestly at this point you couldn't pay me to use a "consumer" router or even recommend one. Pfsense or OPNsense always and forever at this point.
Even friends and family who are non-technical now I recommend it. They just work. For family i fire up wireguard on the router and remote in to do upgrades. They don't even know. They just know their router problems are gone.
I guess the both of you can convince him to go untangle or PFsense.
i'm not changing my stance on it.
not going to disagree there do whatever fits your needs and environment the best.I'd say the definition of WAF varies based upon the specific W in WAF, so I'm not going to even try. I was merely expressing that I've moved to the point of being anti consumer router no matter what. My WAF is for a different class of router entirely that I will also live with.
So I've upgraded from 1Gbps to 5Gbps fiber and got a new modem with a 5Gb LAN port. I'm currently using an Asus AC2900 with 1Gbps LAN. I'd like to get a router with at least a 5Gbps WAN port but most of what I see is 2.5Gbps. Is there a wireless router with a 5Gbps LAN port?
ofcourse there are here is one stand alone if you don't want mesh. https://www.bestbuy.com/site/netgea...sh-wi-fi-router-white/6520472.p?skuId=6520472Hmm I don't think i've seen any consumer level routers with a 5 Gbps wan port only 2.5Gbps. So you will have to look at something expensive.
https://www.bestbuy.com/site/netgea...sh-wi-fi-router-white/6520472.p?skuId=6520472So I've upgraded from 1Gbps to 5Gbps fiber and got a new modem with a 5Gb LAN port. I'm currently using an Asus AC2900 with 1Gbps LAN. I'd like to get a router with at least a 5Gbps WAN port but most of what I see is 2.5Gbps. Is there a wireless router with a 5Gbps LAN port?
Only thing that sucks about that unit is unless you already have your own switching you can connect via sfp+, all the LAN ports look like they're 1gbps.I generally avoid netgear products due to them being very slow to do firmware updates.
And now that I think about it Asus does offer some models with 10 Gbps port.
Asus RT-AX89X
I am OK with 1 Gbps LAN. My only wired units are a printer and a desktop PC with a gigabit ethernet port. I just want the connection from the router to the modem to support 5Gbps. In looking at that router I could use the 10baseT port to connect to the modem correct?Only thing that sucks about that unit is unless you already have your own switching you can connect via sfp+, all the LAN ports look like they're 1gbps.
Then you don't need to waste money on a 5GB Internet connection as you will only see 1gb to all your devices. I suggest getting the right hardware to support at least 2.5gb to your network and wifi. You maybe 1gb on ethernet, but wifi will go faster and utilize whatever your port speed is on the router being 2.5gb, 5gb, or 10gb till you upgrade to a faster switch and devices that support it that aren't wifi.I am OK with 1 Gbps LAN. My only wired units are a printer and a desktop PC with a gigabit ethernet port. I just want the connection from the router to the modem to support 5Gbps. In looking at that router I could use the 10baseT port to connect to the modem correct?
The cost is the same for me since I work for the company providing the service. We were getting close to our limit every month so I thought why not. I also needed a wi-fi upgrade anyway.Then you don't need to waste money on a 5GB Internet connection as you will only see 1gb to all your devices. I suggest getting the right hardware to support at least 2.5gb to your network and wifi. You maybe 1gb on ethernet, but wifi will go faster and utilize whatever your port speed is on the router being 2.5gb, 5gb, or 10gb till you upgrade to a faster switch and devices that support it that aren't wifi.
Honestly If you up for a challenge look at this new MikroTik GearThe cost is the same for me since I work for the company providing the service. We were getting close to our limit every month so I thought why not. I also needed a wi-fi upgrade anyway.
Wireless, no.So I've upgraded from 1Gbps to 5Gbps fiber and got a new modem with a 5Gb LAN port. I'm currently using an Asus AC2900 with 1Gbps LAN. I'd like to get a router with at least a 5Gbps WAN port but most of what I see is 2.5Gbps. Is there a wireless router with a 5Gbps LAN port?
There are routers that have 5gb or higher WAN/LAN ports.Wireless, no.
Wired, yes. Ubiquiti Edgerouter Infinity is all 10Gbe
The least expensive one I could find was this one, lightly used.
https://www.ebay.com/itm/3254889710...5BFsVDlRJeMBOsyuitHYIeSY_nO6ZiC5H3_mxe98wpPiU
