Truly annoying that MC crashes when I use the far distance. Was fine before one of the updates (may have been the beta update).
Did you try updating java?
then ops me!
im filling my inventory with all the tnt i can![]()
Hey there. Big minecraft fan here. Been a member of a small server, mainly building our own things in what I'd call the best world I've ever been on, but the admin has been having troubles keeping his server online. (I'm from the UK so there's the time difference for the US an all).
Anyway, I've been looking for another server I could get active on, and I came across this thread. You guys look cool and respectful, which is exactly what I'm looking for. I always have a fear of people messing with my stuff and with you guys I don't think I'd have this problem.
My rank is Limp Gawd, so I don't think there's any problem asking me to be whitelisted please?![]()
tell us your in game name
I'm confused I see a lot of people mentioning it coming back... once I added it I never took it out... I'm confused...
At which point Creeper Hill starts randomly exploding.depends, until someone travels to the nether by portal, the world doesn't load. once someone goes to the nether by portal, then it loads it.
The way our nether works, it's a second map on the server, the nether mod basically adds functionality to the portal by warping you to the other map... it's basically like running 2 servers in 1...
when I load the server, at the end of the log it says Loaded: Hardcraft1 but says nothing about netherworld
Update seems to be out, but it didn't prompt me whether to update so now I can't login. Yearrgh.
You needed the new launcher for that.
Yeah, just figured that out. Well frak.
youre out for a while... or not if someone compiled the minecraft installation right before the update.
Feed my fish while I'm gone.
ill try to zip the MC files before the update so you can play
I need the files as well. Can someone send them to me?![]()
I was never prompted for the update but when i go to login on multiplayer it says the server is outdated. Is there something i can do?![]()
Server wont update for a week, annoying huh? For those still playing have fun![]()
