Hows the results? Don't let 'em sit...make them run for their lifeVO_Nuclear said:It won't compete with a SLI setup. There is no structure difference between the X800XT-PE and X850XT-PE, only card clocks. Most of the X850 cards aren't OC'ing as well or as high either. PCI-E offers no advantage, so no performance there either.
Trust me on this one, I have 2 X850s sitting here in front of me...as well as a "good" board to run them.
centvalny said:My MSI wont boot with subzero temp.Ordered Gigabyte SLI and hope it will sport A3 chipset revision..
I have to choose beetween dual cascade with x850xtpe or single phase with dual 6800U![]()
VO_Nuclear said:I'd get the dual cascade, and keep the X800XT-PE you have now. Pick up a nice custom GPU cooler and have fun with it.
The only benches right now that SLI take advantage of are 2003 and 2005. 2001 and AM3 don't play well right now. I say go for 2001 spots, as they are still revered as being the "top dogs"
I will move the system to Gigabyte K8N sli....hope it will give me more Ghz and mem. bandwith than Neo2cornelious0_0 said:Aquamark3 does show gains also....not to QUITE the same extent....but I've seen SLI boosting AM3 scores by about 7k with a stock A64 or prescott setup....so it would gain you on a few fronts.
centvalny said:I will move the system to Gigabyte K8N sli....hope it will give me more Ghz and mem. bandwith than Neo2
Edit: Still havent decided beetween x850xtpe or 6800U![]()
X850xtpe vmod from oc-rookiehttp://www.xtremeresources.com/forums/showthread.php?p=435610#post435610cornelious0_0 said:I dunno bro, I still think it'd be fun to toy around with the 850 to see what kind of feats you can accomplish with a single card setup.....but then again...the SLI would be darn nice...and even if it only gains you on a few fronts right now...it'd still be fun to try out.
centvalny said:X850xtpe vmod from OC Rookiehttp://www.xtremeresources.com/forums/showthread.php?p=435610#post435610
VO_Nuclear said:Stay Tuned
BTW: It's been a bit dead around here lately, eh?
centvalny said:Most of first 5 here migrated to nforce 4. I guess we are all still tweaking the bios![]()
HeavyH20 said:OK, how about a stock SLI Ultra clock run. 425/1100 with the AMD 64 3200 @ 2.4 GHz.
80,944
http://arc.aquamark3.com/arc/arc_view.php?run=1762062255
Check out the CPU score![]()
HeavyH20 said:The ASUS board really limited the VCore options. Now, 1.55 is the max. I could not get the CPU much past 2.4 GHz, and the DDR woudl not do 1T past 250 FSB. But, I have the MSI in place now, so i will give that a go.
EDIT: The MSI board helped quite a bit.
6800 U @ 470/1200 - still have to BIOS mod and volt mod card
A64 3200 @ 2.65
89,510
http://arc.aquamark3.com/arc/arc_view.php?run=17284063
That is with less CPU and less video clocks. So, SLI does help. I want to see what these things will do with 500 on the core and 1300 on the memory.
So your CPU is still 200MHz slower than it could be if the boards would cooperate? Seems a bit strange they would release something like SLI (made for benchers/enthusiasts) and it doesn't hold good voltages in things like the CPU (which you know needs a good overclock to keep up with 2 diesel cards like that)....bah.
Ultra Extreme bois should get you much more. I get up to 485/1300 on air.
lol....I did didn't I....sorry man.....and I still am not done yet...I'm shooting for 80k this weekend....standby to standby....................lmfaotsuehpsyde said:lol, your score made me push my rig a bit further so I could feel comfortable @ 73k to be at least CLOSE when you surpassed me...but you just walked all over me![]()
