Bio-Hazard
- Jun 8, 2004
Thanks for the update videomasterz, great thread..............![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Skull, I think your cpu is throttling or something... got to disable it in bios I think
I know something is wrong. Do you know what is causing it? Its not overclocked. THe only changes I made is that I enabled some functions like use max cpu blah blah stuff...
your CPU multiplier is set to 6 instead of 8. disable CPU throttling or whatever it is you tweeked in the bios.Is this the ordenary not-overclocked 6400 pc??
(it runs a litle slow on Vista, thats why im asking)
Skull@
It's not out yet and only a few poeple have engineering samples.First post so I'm a bit of a newbie to the forum, but why is the Q6600 missing from the OC database? I've heard it isn't much of an overclocker but surely it still deserves a place on the list?![]()
M3_Dust, how do I change the multiplier?
Thanks for the update videomasterz! Appreciate all the effort you have put forth in this thread... and it has inspired me to overclock more!
Thanks.
ziddey said:apologize, videomasterz. I must be a real pain in your ass.
Bio-Hazard said:Thanks for the update videomasterz, great thread
TehQuick said:Videomasterz, I got a third cpu, same week as 2nd entry, different code I'm gonna install watercooling and see how high I can take this baby. 2nd cpu runs too hot to my liking..
Hey videomasterz seems as though you put down a different mobo than the one I have. I have the P5N-E SLI, not the P5N32-E SLI.
I hope you can fix it without too much trouble, I just don't want misleading info up there and I dont see any other of the same mobos as mine that high![]()
That's weird how Orthos shows 3600 MHz and CPU-Z shows 3200 MHz. I've never seen that before.
code is etched on the cpu's ihs
Meh. Not pulling off this Tuniq, just to get the code. Hopefully I can still make the list w/o it. I see some entries up there w/o it.![]()
nice. a lot of people have had a hard time breaking above the mid-high 300's with l2's. also, if you want to just capture a window, use alt-printscreen![]()
